Results 1 to 3 of 3
    Rear shock setup - Fluid LT 2009
    Hi ,
    How much PSI at the rear DHX 3 on the Fluid LT for a 80Kg rider (=173 lbs).
    PM
    I have a DHX5 on mine. You really should go by sag as not all pumps are accurate. My old pump said 150psi and the new one says 165psi. So currently I am running 18mm of sag at 165psi and I weigh about 170lb
    AndesJack
    You can also go to the Fox Website follow this link and it'l tell you all about the set up and the how to: http://www.foxracingshox.com/fox_tec...009_OM_eng.htm
