Results 1 to 7 of 7
    Range Killer-B shock reducers and fork a-c
    Tried to look for, but coulnd't find yet...
    ...that what might be the size for rear shock mounting HW/reducers for Range Killer-B frames?
    ...and what is the recommended and maximum A-C measure for the Range Killer-B?
    Also would be interesting to know what are the default tunes for rear shock. The complete builds seem to be with high volume air cans, but what about compression tunes, Low/Medium/High..?
    Banned
    Re: Range Killer-B shock reducers and fork a-c
    I have a 2011 Range, but there number is:
    800 663 8916
    Talk to customer service and see if they know.
    Sent from my Desire HD using Tapatalk 2
    Well, I would be more interested in the actual size figures, something like "Upper Pin 22.2mm x 8mm"...
    I'd love to talk with customer service, but there isn't any (direct)contact info on their website, only links to dealers sites... I've contacted nearest dealer(Germany) but no answer so far...
    Banned
    If you're outside of the US and Canada, call them at (604) 552 2940
    Okay, finally got some info regarding the reducers:
    Top pin: 39,37 x 8mm
    Bottom pin: 21,84 x 8mm
    In case if someone else is wondering the same questions...
    Quote Originally Posted by Verttii View Post
    Top pin: **,** x 8mm
    Bottom pin: **,** x 8mm
    I got these values from one dealer, but those were incorrect... I received now reply from Norco that the correct sizes are:
    39.88MM x 10mm
    22.19MM x 10mm
    Also got confirmation that longer single crown fork than what stock builds have won't void warranty of the frame, so I'm planning to try X-Fusion Vengeance HLR at 170mm first...
    Reputation: jhtopilko's Avatar
    Oct 2012
    10098624 and 10098627 from Fox.
    TCX advanced SX
  1. Replies: 6
    Last Post: 02-18-2013, 10:32 PM
  2. 2013 Norco Range Killer B
    By bobsaget in forum 27.5
    Last Post: 01-31-2013, 12:46 PM
  3. cube stereo vs norco range killer b
    By loolilon in forum 27.5
    Last Post: 10-02-2012, 11:10 AM
  4. Shock Reducers for Jet 9 RDO
    By PlanB in forum Niner Bikes
    Last Post: 08-14-2012, 11:34 AM
  5. Replies: 3
    Last Post: 02-08-2011, 05:53 PM
