Results 1 to 3 of 3
Thread: Norco Rampage
    Norco Rampage
    Is anyone running a short travel fork on a Rampage? Any issue with BB height?
    Feb 2010
    The optimal geometry of the bike was designed around a 150-160mm. Putting a shorter travel fork will have negative effect on the geometry, think much steeper headangle and indeed a lower bottom bracket.
    A general rule i've adopted over the years is for every 10mm you add or subtract off the front end could cause as much as 1degree of change either way.
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    I ran my Rampage with everything from a rigid fork through a 180mm. Even with the uber short (for the Rampage) 470mm rigid fork I still had better than 12" of bb clearance and a neutral feeling front end.
    Well, it was a good try.
