Results 1 to 2 of 2
    Norco Fluid shock question
    Can someone please help because i just dont get there diagram. Do i get more rear travel using the shock bolt hole that closer to the rear wheel of one that in towards the front wheel on the swing arm?
    thank you!
    chris
    Subject to Whimsy
    Dec 2009
    Quote Originally Posted by etacata
    thank you!
    chris
    The shock is in the longer travel position when installed in the bolt hole - located in the rocker - closest to the rear tire.
    There should be numbers embossed or etched at each bolt hole signifying the amount of travel.
