Results 1 to 2 of 2
    Reputation: larrylund's Avatar
    manitou tower pro on shinobi
    thinking of getting one, any thoughts
    thanks
    Shinobi-Wan Kenobi
    Reputation: kristian's Avatar
    Quote Originally Posted by larrylund View Post
    thanks
    I know nothing about the fork so I can't comment at all about it's quality (I haven't owned a Manitou since the Mach 5 I had in the mid '90s). However, it looks like the max travel is 120mm right? If that's the case, that is 20mm less than the speced 140mm forks so it's going to make the bike feel more XC than stock. This is because your head angle would be about a degree steeper (besides the obvious decrese in travel). The overall handling would be quicker and you'll give up a little stability on descents. It's also going to lower your BB a little bit which is probably the biggest reason to stay with a 140mm fork since the Shinobi already has a very low BB (IMO).
    The Shinobi was originally tested with a 120mm fork and you can find a review on MTBR from LeeL. He quickly replaced it with a 140mm fork in the test, but he is an aggressive rider. If you're looking for more XC than AM, it might be a good thing for you. Otherwise, I would stick with the 140....
Hot Deals
Contests
Latest Mountain Bike Articles
