Results 1 to 2 of 2
    _
    Fluid LT2 shock mount hardware replacement bolts...
    Can these be ordered through the NORCO site? Mine are basically stripped. I was thinking of going to a hardware store to try to find something similar, but if i can get the actual ones that would be sweet. BTW, it is for an 08 with a FOX DHXair 3.0
    Hardware store should have almost the exact bolt with options for higher grade as well.
