Results 1 to 5 of 5
    1998 Norco Team Issue
    Hi,
    I found a Norco Team Issue for around 150$. i would like to know if it is still worth the 150? The bike is a bit dusty and has been in the basement for 5 years now (per owners say)
    here are the specs. I plan to use this for light trail and bit of XC race.
    I mostlikey have to change the tires and re-bleed the brakes. Just weird that it has front disc and rear v-brakes. It is XTR's but its a 10 yr old bike
    Frame & Fork
    Frame Construction TIG-welded
    Frame Tubing Material Reynolds 853
    Fork Brand & Model Marzocchi Bomber Z-2 BAM
    Fork Material Aluminum, triple-clamp crown
    Rear Shock Unspecified
    Components
    Component Group Mountain Mix
    Brakeset Formula Hydraulic disc front/Shimano XTR V-Brake rear brakes, Formula Hydraulic front/Shimano XTR rear levers
    Shift Levers Grip Shift ESP 9.0SL
    Front Derailleur Shimano Deore XT top-swing
    Rear Derailleur Grip Shift ESP 9.0SL
    Crankset Race Face Turbine LP, 22/32/42 teeth
    Pedals Shimano PD-M747 SPD
    Bottom Bracket Shimano BB-UN72, 107mm spindle
    BB Shell Width 68mm English
    Rear Cogs 8-speed, 11 - 30 teeth
    Chain Sachs PC-61, 1/2 x 3/32"
    Seatpost Axiom Pro
    Saddle Selle Italia Nitrox
    Handlebar Axiom butted
    Handlebar Extensions Not included
    Handlebar Stem Axiom Pro
    Headset 1 1/8" threadless Aheadset AC
    Wheels
    Hubs Front: Formula disk, Rear: Shimano XTR
    Rims Sun Rims 0 XC, 32-hole
    Tires 26 x 1.95" Panaracer Duster kevlar
    Spoke Brand DT stainless steel, 2.3mm double-butted
    Spoke Nipples Brass nipples
    Thanks !
    North Van/Whistler
    Beautiful bike. Should be lime green iirc
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    got the bike! did some cleaning and it looks great!
    I did notice a little bit of frame flex but its ok
    Jan 2003
    lets see some pics. Sounds like you got a killer bike!
    Here is the bike after a nice bath. I did notice that some of the parts were carbon composite.
