Results 1 to 6 of 6
    Sep 2004
    08 Norco six 2 vs 09 Norco six 2
    Are there any major changes between the two bikes? I found an 08 that will be substantially less money than the 09. Thanks!!
    09 Specs
    name SIX TWO
    frame Hydraformed AL, 6 travel, 135 x 12mm maxle dropouts
    fork Marzocchi 55 ATA, 160mm of travel, 1-1/8 alloy steer tube
    rear shock Fox DHX-Air 3.0
    headset FSA No. 1 Orbit DL alloy 1-1/8
    crankset Truvativ Stylo, 24/36T, E-13 DRS Dual Ring Security
    bottom bracket Truvativ Stylo GXP
    pedals DMR V-8 flat pedal, red
    chain KMC X 9 SL light Gold colour
    cassette Sram PG-950, 9 speed, 11-32T
    front derailleur Shimano Deore 31.8
    rear derailleur Sram X-9, 9 speed, medium cage
    shiftersSram X-7 trigger, 9 speed front and rear
    barFunn Fatboy triple butted 710x50mm rise, 31.8, custom graphic
    stemFSA Gravity Lite alloy, 31.8mm, 50mm/70 mm ext.
    gripsPro Palm lock on grips
    front brakeAvid Juicy 5, 8 rotor
    rear brakeAvid Juicy 5, 7 rotor
    brake leversAvid Juicy 5
    front hubSun Jumping Flea, 20mm axle, sealed bearing, red
    rear hubSun Jumping Flea 135 x 12mm, 9 spd, sealed bearing, red
    rimsAlex FD-28 welded FR 32 hole
    spokesStainless double butted black
    tires Kenda Nevegal 26 x 2.35, Stick E rubber, kevlar bead
    saddle WTB Rocket V, kevlar corners, chromoly rail
    seatpostTruvativ XR, double bolt, 30.9
    sizesS,M,L
    coloursBlue
    08
    frameHydraformed al, Horst Link 4-Bar linkage, 166 mm travel, Fox DHX AIR 3.0 w/ Boost Valve & adjustable rebound
    forkMarzocchi 55 ATA 2 air, 120-160mm travel, 20mm axle, alloy steer tube
    headsetFSA Orbit DL 1-1/8" threadless alloy cup
    cranks chainguideTruvativ Stylo GXP, 24/36/bash guard, hollow axle, two piece , Black Spire Stinger chainguide lower roller
    pedalsDMR V-8, replaceable pins, grease ports
    chainSram PC-971
    freewheelSRAM PG-950, 9 speed, 11-34
    front changerShimano Deore, 31.8mm
    rear changerSRAM X-9, 9 speed, medium cage
    shiftersSRAM X-9 trigger, 9 speed
    barSyncros Race Gain bar , 35 mm rise , 7075
    stemSyncros Race DH stem , 31.8 mm
    front brakeAvid Juicy 5, hydraulic, 8" rotor
    rear brakeAvid Juicy 5, hydraulic, 7" rotor
    front hubWTB 20mm axle, sealed bearings
    rear hubWTB 135 x 12 mm cassette rear hub with Maxle axle
    rimsSyncros DP-25 , white eyeleted, 32 hole
    spokesDT Swiss Stainless, 2.0, black colour
    tiresKenda Nevegal, 2.35 with kevlar bead , stick E rubber
    saddleNorco Shore, short profile, houndstooth cover chromoly rails
    seatpostSyncros Derived, 30.9
    sizesS, M, L
    coloursDark Purple colour
    Norco-ite
    Pretty much the same beast, the higher price tag might partly be due to increase costs of raw materials in the last year (meaning, they cost more to produce).
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    They've redesigned the frame to lighten it a bit more in 09 but it's the same geo. 1 pound less in 09.
    Check out my SportTracks plugins for some training aid software.
    Norco-ite
    Yeah, I forgot about the bike being lighter... but that pound will hardly be noticeable at that weight.
    Sep 2004
    I got the 08 and it will get its first ride saturday, cant wait. The reviews on Fox DHX AIR 3.0 w/ Boost Valve & adjustable rebound and on the Marzocchi 55 ATA 2 air, 120-160mm travel, 20mm axle, alloy steer tube aren't the greatest. I'm not worrying about that now but just for curiousity what other shocks would work well with this bike? Anyone swap out these for something different? Thanks for your help!!
    Reputation: Cata1yst's Avatar
    Quote Originally Posted by Crippitylip
    Fox 36, Totem, Lyrik, Domain for forks
    DHX 5 DHX air, Roco Air, Rocco
    CC double barrel for shocks
    off the top of my head
    Lean back, Hit both brakes, And ask yourself, Do you feel lucky today?
