Results 1 to 8 of 8
    Reputation: kragu's Avatar
    XX1 Crank on alloy RIP 9
    Because I'm an endless tinkerer, I'm thinking about running an XX1 crankset on my full XT RIP 9. Anyone doing this on the RIP? What Q factor are you running, if so?
    Also, anyone know if the MRP AMg fits on a RIP?
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    If you go XX1 crank on the rip9 & use a clutch type rear derailieur on it there is no need for a chain guide.
    My friend has put a 156 Q on his Rip9 & it works ok for him but he may have been better with the 168Q as his feet just touch the stays once in a while in the ruff.
    Quote Originally Posted by scvkurt03 View Post
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Thanks for the reply, muzz. Do you mean pedaling up technical climbs or descending?
    Carbon & Ti rule
    It's more just random because he has a bad pedaling style.
    The Q factor on the XT double is 172. Seems as though 168 might be better, then.
    Carbon & Ti rule
    Yes I think thats a good bet.
    Do you happen to know if I can use my XT bb for the GXP XX1 cranks?
    Carbon & Ti rule
    The difference is that the GXP cranks have a step down on the crank spindale on the non drive side that locks onto the BB bearing & the LH crank arm locks to the other side of that same bearing.
    You can buy a adaptor to press inside the XT BB to use GXP cranks but for the price & mucking around I always just get a GXP bottonm Bracket.
    Hope Bottom Bracket Truvativ GXP Converter | Buy Online | ChainReactionCycles.com
    This is the adaptor, Many outfits make them.
  1. Alloy Freehub/alloy cassette carrier
    By c_trail_biker in forum Wheels and Tires
    Last Post: 02-11-2013, 06:38 PM
  2. Replies: 6
    Last Post: 08-27-2012, 08:04 PM
  3. Replies: 1
    Last Post: 07-24-2012, 05:28 PM
  4. Replies: 1
    Last Post: 10-04-2011, 09:40 PM
  5. Lezyne Alloy Drive vs Alloy Drive CFH
    By Metamorphic in forum Beginner's Corner
    Last Post: 05-12-2011, 11:58 AM
