Brown Santa dropped off the first parts of my winter project yesterday! I'll be building this up over the next few months, and hope to have it on the trail by the first weekend in March!
The (medium) frame, as most of you already know, is a work of art! I threw it on my (Park Tool) scale last night, and it weighed in a 2.5 pounds. Wow! I knew it was light, but I was honestly expecting it to be little heavier!
I'll post updates and pics (and probably stupid questions) as I get it built up!
How can you wait until March? I built my licorice RDO up on Halloween & I've got nearly 400 miles on it now. THE most grin inducing bike I've ever owned. You will love it!
I'm looking at an Air9 RDO build myself, so I'll have to follow your build and see if I can learn anything Do you already know exact specs you'll go with, or still researching parts?
Nice looking bike! I'm just taking my time with it...and trying to stay in the green with the boss. I still have two other mountain bikes to ride in the meantime! I can't wait to get it built up though! I demo'd one a few months ago, and couldn't believe how great the ride was. And the acceleration felt like my road bike.
Yep! Here's how I will be building it up. I've already received the frame, bar, stem, and saddle. The post, fork, and grips are currently on the way. I'll slowly acquire the rest of the parts over the next couple of months.
FRAME: Niner Air 9 RDO
FORK: Rock Shox SID XX
RIMS: Stan's No Tubes ZTR Crest 29er
HUBS: DT Swiss 240s
TIRE - FRONT: Maxxis IKON
TIRE - REAR: Maxxis IKON
SHIFTERS: SRAM XX1
FRONT DERAILLEUR: N/A
REAR DERAILLEUR: SRAM XX1
CRANKS: SRAM XX1
BOTTOM BRACKET: Truvativ PF30 Ceramic
CASSETTE: SRAM XX1
CHAIN: SRAM XX1
DERAILLUER CABLE: Jagwire Ripcord
PEDALS: Shimano XTR
BRAKES: Magura MT-8
BRAKE ROTORS: Magura Storm SL
HANDLEBAR: Niner Flat Top 9 RDO
STEM: Niner RDO
HEADSET: KSA that came with the frame
GRIPS: Ergon GA1 EVO
SADDLE: Ergon SM3 Carbon Pro
SEAT POST: Niner RDO
BOTTLE CAGES: Bontrager RL
Reason: Changed my mind on the drive train...going with XX1.
Very Nice! What do you expect the weight to come in at ... 20'ish lbs?
I'm hoping to build a h/t at 22lbs or less (including everything). Still researching bikes and parts, but if I do go with the Air9 RDO frame I've got a few things picked out already:
FRAME: Niner Air 9 RDO (licorice)
FORK: Rock Shox SID XX, 15mm maxle (remote lockout)???
RIMS: Crest, Arch EX, maybe carbon???
HUBS: Hope Pro II Evo
TIRE - FRONT: Conti Race King 2.2 ???
TIRE - REAR: Conti Race King 2.2
SHIFTERS: SRAM XO/X9 (probably trigger)
FRONT DERAILLUER: E13 chain guide ???
REAR DERAILLUER: SRAM XO/X9
CRANKS: SRAM XO/X9 (1x10 w/ bashguard)
BOTTOM BRACKET:
CASSETTE: SRAM XO/X9
CHAIN: SRAM PC 1091R
DERAILLUER CABLE: ???
PEDALS: Shimano XT
BRAKES: SRAM XO/X9
HANDLEBAR: Niner RDO
STEM: Niner RDO
HEADSET: ???
GRIPS: ESI Chunky
SADDLE: WTB Rocket V
XO or X9 parts will come down to budget vs weight advantage. I currently have a full X9 1x10 setup on my Jet9 and it works great, but I'd really like to go lighter with an Air9 if I can afford it. Still undecided on wheels, and while I'd like to go light here, I don't want to give up too much durability as I do some longer races too. Keep hearing about these "Chinese" carbon wheels and wonder how they compare? For tires I'll probably go with Race Kings but I've also had great luck with Specialized XC tires (FastTrak, Renegade) ... which are especially easy to set up tubeless!
Originally Posted by chrisgardner73
Yep! Here's how I will be building it up. I've already received the frame, bar, stem, saddle, and cassette. The post, fork, headset, and grips are currently on the way. I'll slowly acquire the rest of the parts over the next couple of months.
This build will match most of the kit that I used on my R.I.P. 9, which has been solid, lightweight, and very reliable!
HUBS: DT Swiss 240s
SHIFTERS: SRAM XO
FRONT DERAILLUER: SRAM XO
CRANKS: Truvativ XO
CASSETTE: SRAM XG-1099
CHAIN: SRAM PowerChain 1091
PEDALS: Shimano XT
BRAKES: Magura MT-8
STEM: Niner RDO
HEADSET: Cane Creek 110
BOTTOM BRACKET:
PEDALS: Shimano XT
BRAKES: SRAM XO/X9
STEM: Niner RDO
HEADSET: ???
GRIPS: ESI Chunky
I don't (personally) know anyone running the Chinese rims, but from what I've read here and there on MTBR, some people seem to like them. Me personally, I MIGHT pick up a set of Roval's once the dust settles on me making it rain for this build. I'll have to see how the Crest's do first before I spend the money though.
I'm also a big fan of Specialized tires! I run The Captain (F) and Fast Trak (R) on both my RIP 9 and SIR 9. That combo has worked really well for me all along the Front Range here in Colorado! I will likely run that same setup on the Air 9 RDO for everyday use...and swap to the IKON's (or second set of wheels with IKON's mounted) for racing...which has also worked really well for me.
When I built up my Jet9 in 2010, my first choice for tires were Ikons, but none were available (local or online). Went with the Conti Race Kings and I was pleasantly surprised! Fast rolling and MUCH better traction then I expected with the low-profile treads (especially as a rear tire). Not completely sold on the RK's as front tire though? Captain front with Fast Trak rear is a nice combo, but probably too heavy for racing? I've heard nothing but good about the Renegades too and this year they added 2.3's to the mix, so might try them as a light race tire? So tell me about the Ikons ... how do they compare to a tire like the Fast Trak (front and/or rear)?
I'm also looking hard at the Crest wheels but I see a lot of posts about them being too flexy? Arch EX would be an easy choice for me, albeit heavier then I prefer for xc racing? I assume the Rovals would be VERY pricey to purchase individually ... not sure I can justify the cost?
The Captain/Fast Trak combo is a little heavy, when compared to the IKON's. I definitely notice the weight difference up front. Maybe a tad heavy for my taste for racing, but a ton of fun for regular riding! I run the Fast Trak backwards, and found that it grips pretty well here on the Front Range. However, the IKON's hook up well too...but do suffer a little in the front, as compared to The Captain. For racing though...IKON's!
As for wheels, it'll be a little trial and error. I run Arch's on my other bikes, and this will be my first experience with the Crest. I have a buddy (who is slightly heavier) who runs the Crest in the same type events that I race, and he loves them! I guess we'll see how it goes!
The Rovals are actually reasonably priced ($1700) when compared to other wheels, such as ENVE ($2500), and have a pretty good reputation. I'm definitely gonna give the Stan's a shot first!
The rovals rock. Two seasons of hammering and still true as an arrow. Never touched a spoke.
Roval Carbon SL or basic Roval Carbon? Out of curiosity, what do they weigh ... while I'm sure they're much stiffer, wondering how much lighter they are compared to Crest?
SL'S. They are fast. The weight is published on their site, but i think they are 1400? BTW i also weigh 185 and ride some rough singletrack. New ikon's where i ride lasted one ride. The rivals are strong.
Good to know about the Rovals. Light, stiff, and durable ... sounds like a real nice upgrade!!
Still making up a build list and looking at SRAM site to get an idea of price/weight options. Regarding components like shifters and brakes ... is the listed price and weight for a set, or only one of each??
For example SRAM lists XO brakes at $245 and 315g ... I assume double that for front and rear brakes?
XO 10 spd shifter lists price for a "pair", but not sure if weight (232g) is for pair or each??
Chris,
About the drive train: Can you tell me what Q-factor and crank length you chose?
I've bought me also an air 9 rdo frame and I want also a sram xx1 drive train, but I'm not sure which q-factor would be the best (regarding clearance whith chainstay).
