Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 76 to 100 of 118
  1. #76
    Reputation: chrisgardner73's Avatar
    Winter Project - Niner Air 9 RDO
    Quote Originally Posted by NSSage View Post
    Any chance you could post a photo of clearance between the chainstay an chainring. I want to build a Air 9 with the xx1 but I think the 32T chainring will be too small. Any Better options for 1x cranksets with better clearance?
    Here you go! Kinda hard to tell in the photo, but there's about 1.5-2mm of clearance.
    As for other cranks, I don't believe there are any other options for cranks for XX1 at this time. However, at the NAHBS this weekend, I saw one or two bikes using different cranks with XX1 rings.
    Winter Project - Niner Air 9 RDO-imageuploadedbytapatalk1361797622.482769.jpg
    U.S. Military Endurance Sports - Twin Six - Skratch Labs - SPY Optic
  2. #77
    Duplicate post...
  3. #78
    Oct 2010
    Quote Originally Posted by chrisgardner73 View Post
    I emailed Niner a while back about Air 9 RDO/XX1 compatibility, and here is the response that got:
    "We have been testing the XX1 drive train from SRAM and are finding that we will likely need to put a limitation on the front chainring size of 32 teeth to avoid frame interference. Either of the Q factors will work I just warn folks on narrow Q factors and mountain bikes that heel strike can be an issue if they have any abnormality in their pedal stroke."
    I will be running the wide Q factor with a 30T chainring.
    Now that you've got a few rides in, any updates on the wide vs narrow Q-factor? I plan to go with the 168Q on my Air9 RDO, but thought I'd check in and see how you feel with the wider Q ...
  4. #79
    I actually ended up going with the narrow Q factor, and it seems to be working just fine. I've only gotten two rides (~40 miles) in on it though. As soon as I got the bike finished up, our weather went to crap. I'm hoping to get it back out this weekend!
  5. #80
    Oct 2010
    What made you switch to the 156Q?
  6. #81
    Quote Originally Posted by kfb66 View Post
    Feel free to make fun of me, but I didn't notice that they were the 156Q until I was checking the bike over after my second ride. I just never noticed, even with it written right there on the crank arms. I had requested the 168Q version, but my LBS must've made a mistake when they placed the order. To be honest though, they feel great, with no heel strikes, etc...so I'm gonna roll with it!
  7. #82
    Oct 2010
    Just checked my alloy Jet9 with X9 cranks, and it's ~142.875mm from inside of l/h crank arm to inside of r/h crank arm. According to SRAM specs, the XX1 is:
    168Q = 141mm
    156Q = 129mm
    I've always felt comfortable on my Jet9, but I like the idea of more pedal strike clearance with a narrower Q ... decisions, decisions!?
  8. #83
    Reputation: AKRC78's Avatar
    Great thread. I picked up a Med Air 9 RDO frame and I should have it in the next day or so.
    I'd love to go with the xx1 but due to $$ I'm getting roval wheels for my ride and using 2x10 I already have. Stoked!!
    I'm wondering about seatpost length, niner specs 400mm but I already have a thomson setback, and was thinking about that or an exotic carbon or easton.
    Any thoughts?
    Reputation: limba's Avatar
    I'd get a carbon post with setback if you need it and for the added flex. A couple nice ones -
    Syntace Hiflex. It's designed to flex a little.
    Niner has their own RDO which would match your frame.
  10. #85
    Thanks, I'll look into the Syntace
    I meant to ask if a 350mm post would be too short, I don't need the setback I just happen to have it.
  11. #86
    Hmmm, you'll have to try it and see. Sometimes there's a minimum insertion mark recommendation.
  12. #87
    Mar 2012
    New build I've been working on for a while, just finished today.
    8.44kg (18.6 pounds).
    First ride tomorrow!
  13. #88
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    That's a great looking bike.
    Quote Originally Posted by rotorua View Post
    Raising money, my friend broke his neck Mtbing, Please Share link. http://givealittle.co.nz/cause/elliottkeys/donations
  14. #89
    Very nice!
  15. #90
    I've been meaning to get a "review" of my build up here for quite a while, but I got sidetracked.
    Here is what the final build came out to:
    FRAME: Niner Air 9 RDO
    FORK: Rock Shox SID XX
    RIMS: Stan's No Tubes ZTR Crest 29er
    HUBS: DT Swiss 240s
    TIRES: Continental X-King
    SHIFTERS: SRAM XX1
    REAR DERAILLEUR: SRAM XX1
    CRANKS: SRAM XX1
    BOTTOM BRACKET: Truvativ PF30 Ceramic
    CASSETTE: SRAM XX1
    CHAIN: SRAM XX1
    PEDALS: Shimano XT
    BRAKES: Magura MT-8
    BRAKE ROTORS: Magura Storm SL
    HANDLEBAR: Niner Flat Top 9 RDO
    STEM: Niner RDO
    HEADSET: KSA (came with the frame)
    GRIPS: Ergon GA1 EVO
    SADDLE: Ergon SM3 Carbon Pro
    SEAT POST: Niner RDO
    Weight (with pedals, cages, and seat bag): 20.4 lbs
    First off, wow...WOW! This thing is fast! I've been riding a R.I.P. 9 for the past year, and the (obvious) differences are noticeable right away...mainly the lack of effort required to build up speed. I almost died on my first ride, because I was on a section of trail where I usually hammer it on the R.I.P., but with the same effort, I had built up an insane amount of speed. More than I was used too on that section!
    Frame: The Air 9 RDO frame is awesome, and I can't really think of anything to complain about. If I were forced to find something to whine about, it'd be the rear brake mount. While it works just fine, there's not a lot of space to adjust the rearmost caliper bolt. My medium frame weighed in at 2.5 lbs.
    Fork: The Rock Shox SiD XX is sweet, it's lightweight and simple, and does its job. I wasn't sure how I'd like the new graphics, but once I saw them in person, I really like them. One thing to note, is the remote lockout. I have three XX forks with the X-Loc remote, and while it works great, it MUST be bled before use. All three of my forks required it in order to get the full travel. Maybe this is because I live at 7100 feet. Not sure. Read the instructions on this, because while the process is simple, there are a lot of steps. Something to also keep in mind, is that when the lockout system fails, the fork will be locked out.
    Wheels: I went with Stan's NoTubes ZTR Crest rims and had them laced to DT Swiss 240s hubs. I've used these hubs on my R.I.P. for the past year without one issue. They, along with the Stan's rims, are great products! This is my first crack at the Crest rims (I run Arch's on my other two Niner's), and the seem fine so far. I was a little concerned how they would hold up on the rocks, but so far, so good.
    Tires (sponsor disclaimer): I've been eyeballing the Continental X-King for quite a while, but for some reason, never tried them out. Our team picked Continental up as a sponsor, so since we got a great price on them, I decided to give the 2.2, tubeless-ready offering a shot! I will say that these were probably the easiest tubeless tires I've ever set up. They took a little work to get onto the rim, but the bead set with less than 35 psi and has held ever since. As for grip, they seem to do just fine on hard-pack, stone/rocks, and slightly loose tread. However, while not a show-stopper, they do require a little extra attention in the really loose stuff.
    Drivetrain: What can I say about SRAM XX1 that hasn't already been said? One word; awesome! I am running the stock setup, 32x10-42, and honestly, I don't feel like I miss my 2x10 at all (I run XO 39/26x11-36 on my R.I.P.). The shifting is smooth and precise, and like I'm sure you've read in other reviews, it's dead silent. Setup was easy and straightforward. Two words of advice though; follow the instructions for setting the chain length, especially if you are running it on a full suspension and get your derailleur hanger straightened. Do that, and you'll be golden!
    Brakes: I've been running Magura MT8's on my R.I.P. 9 for the past year, so they were the obvious choice for my Air 9 RDO. These have got to be the best (BEST) brakes I have ever used, and Magura's customer service is second-to-none in the industry. I've used other systems from Shimano and Avid, and have never felt the modulation and control that I get from my Magura's. After I got about 25 miles on the bike, I found out that the MT8's on both my Air 9 RDO and R.I.P. 9 were affected by the recall. I immediately sent the brakes off, and in just under 3 weeks, I was up and riding again! Magura even included four sets of fresh pads! Again...customer service!
    Niner Bits: While they make great 29er's, Niner also does a kicka$$ job with their components! I went with their RDO bar, stem, and seat post, and there's not a lot to say other than they do their job. They're lightweight and match the frame perfectly. I do get a slight flex from the seat post, as well as the frame and wheels, which does provide a little bit of relief on rough trails.
    Ergon Bits (sponsor disclaimer): I picked up Ergon as an individual sponsor this year, so going with the SM3 Pro Carbon was a no-brainer in my opinion. I've used Specialized saddles on my other two MTB's and CX bike for the past couple of years, and love them! However, Ergon has definitely changed my perspective! The SM3 Pro Carbon (while slightly pricey) is a great product. The longest ride I've gotten in on it so far, is about 45 miles, and I haven't had any issues; no numbness, no chafing, no sore butt. I also use their GA1 Evo grips and HX2 gloves, which are a great combo! The gloves fit perfect and hold up really well to abuse, and the grips, while slightly tacky, work like a champ...for well...grips! I also switch to GX1 grips from time to time. I'm trying to figure out which ones I want to use for endurance racing. I'm also looking forward to trying the new SR3 road saddle when it comes out this summer!
    Well...that's it! I've only got a ~250 miles on the bike right now, but so far, I'm really happy with it! So much, that I'm pretty sure Chris Sugai thought that I was going to hug him when I met him at the NAHBS in February and babbled on about how much I loved Niner bikes!
    Let me know if you have any questions!
    (I know I've posted these pics before, but wanted to add them here too)
    Attached Thumbnails Attached Thumbnails Winter Project - Niner Air 9 RDO-64555_10200954553292936_750149825_n.jpg
  16. #91
    I couldn't wait any longer so I threw some old tires with tubes on, but it's pretty much finished. At least it's rideable. I'm hoping to loose a few pounds going tubeless and cutting down the hydraulic lines and bars but its a rocket ship as is!!
    21.1lbs
    w/ pedals and bike computer
    Attached Thumbnails Attached Thumbnails Winter Project - Niner Air 9 RDO-rdo2.jpg
  17. #92
    Jun 2005
    Looks fantastic. About the chainstay/-ring issue and XX1: Have anyone tried a 34T/36T on a Air Carbon? Im too afraid 32T will be to small, even with a 10 back. I run XTR 40/28 on my Air Carbon today with no issues.
  18. #93
    Quote Originally Posted by baardi View Post
    I can't speak to the Air 9 Carbon, but on the Air 9 RDO, there is no chance of running anything larger than a 32T with XX1. There is just over a mm of clearance between the ring and stay.
    According to the Niner Encyclopedia, the max you can run on the Air 9 Carbon is a 32T as well. I would assume that Niner has checked it out, and that this is accurate.
  19. #94
    The Air 9 Carbon looks to have the same clearance as the RDO, I was thinking S-work cranks might have a different chain-line but it seem they are the same. I think the only way to go single chainring with the bigger rings will be to run the 104 bdc spider with a 34 or 36 tooth ring and a guide. Or maybe one of these, 104 BCD Chainrings | wolftoothcycling.com I've been meaning to call and talk to them about it.
  20. #95
    Reputation: VanillaEps's Avatar
    Aug 2010
    Nice write-up and beautiful bike. If I ever decide to upgrade my frame, the A9C RDO is my frame of choice over an S-Works frame.
  21. #96
    Ride or Die!
    Reputation: CasinoKiD's Avatar
    Yep! Here's how I will be building it up. I've already received the frame, bar, stem, and saddle. The post, fork, and grips are currently on the way. I'll slowly acquire the rest of the parts over the next couple of months.
    HUBS: DT Swiss 240s
    TIRE - FRONT: Maxxis IKON
    TIRE - REAR: Maxxis IKON
    SHIFTERS: SRAM XX1
    FRONT DERAILLEUR: N/A
    CRANKS: SRAM XX1
    CASSETTE: SRAM XX1
    CHAIN: SRAM XX1
    DERAILLUER CABLE: Jagwire Ripcord
    PEDALS: Shimano XTR
    BRAKES: Magura MT-8
    STEM: Niner RDO
    HEADSET: KSA that came with the frame
    BOTTLE CAGES: Bontrager RL
    Was hoping you could explain the crankset options.
    Do they make a GXP BB compatible with our Air 9 RDO's or are we forced to go with the BB30/PF30 option or does a GXP fit a PF30 BB? All this BB crap confuses me
  22. #97
    Carbon & Ti rule
  23. #98
    Ride or Die!
    So if I bought the GXP version of the XX1 crankset could I use a regualr PF30 BB?
  24. #99
    Carbon & Ti rule
    Quote Originally Posted by CasinoKiD View Post
    No, you can use the GXP crank but you will need to run an adaptor.
    My wife Air9 RDO is running a GXP crank with This adaptor
    Wiggle | SRAM PressFit 30 to BSA Adapter | Bottom Brackets
    & a standard GXP bottom bracket.
  25. #100
    Ride or Die!
    Quote Originally Posted by muzzanic View Post
    A standard GXP BB wont fit the Air 9 RDO frame right?
