Results 1 to 6 of 6
    Reputation: brightsky's Avatar
    Dec 2008
    what is the bare weight of your thru axle equipped jet9 RDO
    Reason I ask is that I ended up with the latest rev (besides the carbon rocker). It is significantly heavier than my previous one. ~200 grams heavier not including the maxle.
    My frame is size large and this is the weight of it totally bare with no headset bearings, bottom bracket, seat collar, or maxle installed.
    2500 grams
    the maxle adds 72grams
    Reason I ask is that I'm trying to decide if it is worth trying to get the carbon rocker to get the weight back down. I know the thru axle rear got heavier and was suppose to be offset by the carbon rocker, but I'm not going to bother if it will only save me a few grams.
    TIA
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by brightsky View Post
    2500 grams
    TIA
    Spend your money getting weight out of something else on the bike.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    May 2012
    I was told by our niner rep that the carbon links add stiffness but they are not a huge weight savings.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Jun 2010
    what is the bare weight of your thru axle equipped jet9 RDO-carbonrocker.jpg
    Dec 2008
    Thanks, that is exactly the info I needed. 20grams would not be worth the effort and I seriously doubt it adds any noticeable stiffness.
    Overall I was surprised that the newer frame rev is a half pound heavier, but I can live with it if it is more durable.
    Reputation: danvar's Avatar
    Last time I checked the carbon rockers were still not available. Are they now?
  1. 29er Full-suspension bare frame weight
    By chomxxo in forum Weight Weenies
    Last Post: 10-11-2012, 05:04 PM
  2. 12 mm rear axle weight?
    By gmats in forum Turner
    Last Post: 09-06-2012, 02:42 PM
  3. Replies: 3
    Last Post: 09-03-2012, 10:17 AM
  4. Jet9 with 10mm rear axle - anyone using?
    By db9 in forum Niner Bikes
    Last Post: 08-03-2012, 02:53 PM
  5. Weight of Fox 2011 15mm Thru-axle skewer
    By Onie in forum Weight Weenies
    Last Post: 12-23-2011, 10:09 PM
