Results 1 to 6 of 6
    WFO 9 front derailleur ?
    Do you have to run a Shimano bolt-on or can you use a clamp style ? Thanks.
    Bolt on. Check the Niner WFO specification page. I think it's a FD-M771D or FD-M661D
    Bolt on, Shimano FD-M771D XT Front derailleur, High . You can order them from Niner, call Drew there, have your credit card ready.
    Will that work for a 10 sp setup as well
    Is the 10 sp chain narrower and require a different FD than the 9 sp?
    It's taken care of by the end adjustment stops. But it is narrower, and yes, it will have shorter chain life also, which is already short enough if you are a Clyde running a 9 speed. Run a 9 speed and save yourself the headaches.
    Reputation: david8613's Avatar
    May 2005
    Keen I sent you a pm...
