    Weight 2014 jet 9 w/4 star build X0
    Anyone have the new Jet 9 alloy with the 4 star X0 build. What is the actual weight?
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by dnb711 View Post
    You could toss all the components into an Excel Spreadsheet (easily researched for all the components in that build - and I typed in a few for you easily found on the net) to get an idea if you can find the frame weight for the size of JET 9 alloy you would ride.
    Just looking at the spec sheet - I would guess at least 27-28 pounds for my size (XL).
    FRAME: NINER JET 9 TAMALE RED
    FORK: ROCK SHOX SID XX SOLO AIR 100MM, 15mm, TAMALE (1575g with the TA)
    WHEELS: AMERICAN CLASSIC RACE29,
    QR/15MM FRONT, 142 x 12MM REAR (1437g)
    TIRES: SCHWALBE RAPID ROB EVO TL 2.4/ RACING RALPH EVO TL 2.25 TIRES (800+g/535g)
    BRAKES: SRAM XO, RED, 180/160MM ROTORS
    LEVERS: SRAM XO CARBON, RED
    R/SHIFTER: SRAM XO, MMX, RED 10SP
    F/SHIFTER: SRAM XO, MMX, RED 2SP
    R/DER: SRAM XO, MEDIUM CAGE, TYPE 2, RED 10SP
    F/DER: SRAM XO, 10SP DIRECT MOUNT
    CASSETTE: SRAM PG1070 11-36 10SP (359g)
    CHAIN: SRAM PC1051 10SP
    CRANKSET: SRAM XO, 38/24, PF30
    BOTTOM BRACKET: SRAM PF30
    SADDLE: WTB VOLT TEAM, NINER GRAPHIC (229g)
    SEATPOST: NINER CARBON SEAT POST, RED GRAPHIC (260g)
    BAR: NINER FLAT TOP CARBON, RED GRAPHIC (175g)
    STEM: NINER ALLOY STEM, RED GRAPHIC (130g)
    I would toss that heavy Rabid Rob front tire first thing to ditch 100-200+g.
    I have this bike in a size medium, but it is not quite stock.
    Has a 120mm Rockshox Sid RCT3 fork instead of the FOX, and Maxxis Ikons instead of the Racing Ralph and Rapid Robs, set up tubeless.
    WITH Shimano SPD XT pedals it weighed exactly 25 pounds at the bike shop when I picked it up.
    Just so you know it comes with an alloy X1 crank (not carbon XO1) and alloy bars, I was a little surprised that they weren't carbon, but it is my fault for not reading the spec sheet close enough. It is a great handling bike, hope this helps.
    Whoops, I need to pay better attention, my bike is carbon version so disregard the last post.
    I demoed the Alloy version, the front wheel was not stock (AM Classic all mountain not Race), it weight 26 pounds on my bathroom scale.
  1. 2014 Trance advanced 27.5 frame weight?
    By V-Tach in forum Giant
    Last Post: 11-17-2014, 01:50 PM
  2. 2014 S-Works Camber frame only weight
    By Mazukea in forum Specialized
    Last Post: 04-21-2014, 01:40 PM
  3. Weight - Anthem X 29er 1 2014
    By darkpromenade in forum Giant
    Last Post: 10-08-2013, 01:59 PM
  4. 2013 jet 9 rdo 3 star build weight?
    By vegan_warrior in forum Niner Bikes
    Last Post: 05-05-2013, 08:22 AM
  5. Need weight on star fangle
    By 1SPD in forum Weight Weenies
    Last Post: 03-21-2011, 07:59 PM
