Results 1 to 6 of 6
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Using a Y.A.W.Y.D. top cap w/
    A carbon fork.
    I recently picked up a Niner carbon fork for my 2011 E.M.D. The expansion nut inside the stem doesn't accommodate my YAWYD top cap. What do I need to get to make it work with this fork?
    Let's make like a Bike and get the Huck outta here...
    greedy
    Reputation: have2ride2day's Avatar
    Niner Forks come with a carbon top cap. I've never tried my yawyd with my carbon fork, but I would assume that is the difference. Call up Niner and check with them. They can get you what you need.
    Addicted to the Classifieds
    May 2012
    I dont see where your issue is. The niner compresison plug uses an M6 bolt (standard for 99% of top caps) and the yawyd cap comes with an M6 bolt. What is your specific issue? I have one on my rigid niner fork and it works easily. Perhaps you should check out their new video, YAWYD 1 from Niner Bikes on Vimeo
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    is it an issue with the yawyd top cap not seating on the expansion nut? if so a 2.5 mil spaced between the top of the stem and the top cap should take care of it.
    Reputation: quelocotony's Avatar
    I have one on my SIR / Carbon fork. No issues.
    Bandit 29 FTW!!!
    I'll take some pics and post them.
