Results 1 to 5 of 5
    Sep 2012
    Tire clearance on EMD 9
    So I bought an EMD 9 frame last fall and originally tried a Specialized Ground Control 2.3" tire in the back and it rubbed paint off of the left inside chain stay after 2-3 12mi. rides. I touched it up this spring and switched to a 2.1" tire, same model. I've notice I have rubbed the paint off again after 3-4 rides. I have custom built ArchEX's from an LBS and the wheel is centered between the chain stays when eyeballing it. I run 28-30 lbs. tubeless at about 210 lbs. geared up. What have other EMD owners been able to get away with in the back without rubbing? Do I question wheel build/flex?
    Trek Stache 7
    9:Zero:7 Whiteout
    Ibis Ripley LS
    Santa Cruz Bronson
    May 2012
    QUESTION EVERYTHING!!! Really though, you should probably question more in life. Are you only rubbing paint off on one side with both tires? I would start with making sure everything is tight, QR, hub bearings, spokes. Don't tighten your spokes, just see if they feel tight.
    That will give you a little more direction.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Reputation: aybee's Avatar
    Feb 2014
    I used to own a small EMD9 with Fulcrum Red Power XL wheels and 2.1 crossmarks in the rear and I used to have tire rub on both sides of the chainstays - this was when I still weighed 240lbs. Lots of wheel flex when mashing hard. When i went down to 180lbs the flex and rubbing went away :P
    Reputation: LeftyNiner's Avatar
    May 2014
    I run specialized ground control 2.2 and have no tire rub. My EMD is a large frame and I'm 245 kitted out.
    Specialized Enduro Comp 650b
    Santa Cruz Tallboy LT
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    I am running a similar set up. Stan Arch tensioned properly and everything tuned properly. With a Schwalbe R. Ralph and a Kenda Slant Six they rubbed the stays under hard up hill efforts.
    I put a Conti X-King 2.2 and no further issues. Seems like they could crimp the chainstays around this area for more clearance.
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
  1. Anyone know what tire clearance is like
    By Harryonaspot in forum Pivot Cycles
    Last Post: 10-11-2012, 08:20 AM
  2. CS-to-Tire Clearance?
    By TrailMaker in forum Frame Building
    Last Post: 06-11-2012, 03:59 PM
  3. Tire Clearance
    By CS2 in forum Cyclocross
    Last Post: 02-09-2012, 12:07 AM
  4. Big Top Tire Clearance/Tire Choice
    By TheFCuddy in forum Yeti
    Last Post: 10-07-2011, 06:51 AM
  5. Replies: 2
    Last Post: 07-12-2011, 07:39 AM
