Results 1 to 3 of 3
    May 2005
    Sram XX1 11-SPEED Chainring durability....on Jet9rdo
    So after about 600 miles, I put a new chain on my bike and now when I pedal with effort in (any gear/ left and right), I get this grinding sound from crank area. I had my old chain checked by shop and they said it was close, still OK, but I replaced any way. Could it be that the larger teeth on the chainring are much "sensitive" ? Easy pedaling, forward or backward seems just fine.
    May 2005
    Just an update after visiting LBS.....tried a couple of different fixes, but in the end it was the chainring. When pedaling with effort, it was not releasing the chain, causing it to "stick" for a micro-second. After checking my records, actual mileage was closer to 900 miles.
    Quote Originally Posted by Surfdog93 View Post
    Did it resolve with a new chain ring?
    I was wondering about chain tension when I read the initial post but I guess that wasn't the case.
    What kind of lube are you running on the chain? I wonder if that could of been a factor as well?
  1. 9 vs 10 speed - durability?
    By panzer07 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-02-2012, 08:56 AM
  2. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
  3. 32 chainring x 11-36 cassette 10 speed sram rear derailleur advice...short or med.
    By AMCAT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-22-2011, 12:36 PM
  4. SRAM XX durability on RIP 9...
    By Dirt Dude in forum Niner Bikes
    Last Post: 02-24-2011, 10:34 AM
  5. SRAM XG-999 durability
    By rockyuphill in forum Weight Weenies
    Last Post: 02-13-2011, 08:34 AM
