Results 1 to 18 of 18
    Nov 2007
    SRAM PF30 to English Adaptor
    Is anyone using one of these on an RDO (or other)?
    I have an RDO on the way and I hope to use my standard 24mm spindle XX cranks. This adaptor seems simple and I could also use my King external BB.
    I'm just not that familiar with these new BB "standards" and adaptors. Is the adaptor easy to install? Remove? I know the aluminium BB30 to English adaptor is more or less permanent. I certainly don't want that. Anyone have any experience?
    thanks
    Jun 2010
    If you dunnot want something permanent and less heavy look at this
    c-bear.com/en/pf30-en/press-fit-30-sram-truvativ-gxp.php
    Dec 2010
    i have the sram version of the adapter for mine and it is in no way permanent. it just presses in and out. one thing to mention, you have to install the bb in the adapter before putting it into the frame. with the pf30 adapter there is no loctite included or needed.
    Nov 2007
    Quote Originally Posted by FoCo29er View Post
    Great -- that's what I was hoping to hear. Knock it out with a headset removal tool?
    Zak
    Zak is offline
    Discernibly Turgid
    Had one in my RDO test mule since spring - works fine. As said before, cups thread in first (adapter has flats for vise or big wrench), then it presses in.
    I have just built an RDO with this adapter but after the first ride the drive side adapted and bearing has partially worked it way out of the frame. Has this happened to any one else and dose the problem continue after re pressing?
    I am using Noir cranks, Sram GXP BB and Niner PF30 to BSA BB adaptor
    Dec 2010
    The new Air 9's require this, I've found that to get the BB cups in you allmost have to deform the adaptor while in the vice to make sure they are seated all the way, Other than that the recommended removal method is a Park BB86 tool, I used a 3/4 pipe and worked my way around the adaptor to remove it, I long for the days of the simple bb designs... DO NOT USE GREASE on the adaptor.
    So ends up after finding the adapter instructions, via sram website, there is supposed to be a spring washer, 2.5mm Shim and 0.5mm shim installed on the drive side crank spindle. The shop forgot to mention that to me after they threw the instructions away and said install the cranks as usual.....woops!
    Anyway no harm done will get right on it!
    Dec 2010
    Quote Originally Posted by Shotguns View Post
    So ends up after finding the adapter instructions, via sram website, there is supposed to be a spring washer, 2.5mm and 1mm spacers installed on the drive side crank spindle. The shop forgot to mention that to me after they threw the instructions away and said install the cranks as usual.....woops!
    I called SRAM about the need for these washers, No one could explain to me the purpose of them, ANd the funny thing is if your frame has standard bsa thread in bb you dont have to use any of these washers, Must be a SRAM thing I guess......
    If it was a standard BSA it would be the thread holding the BB to the frame but I guess when the adapters are used the only thing stopping it moving is the pressure of the Press Fit. GXP have no lateral loading on the drive side when fitted to a BSA BB (as discussed in other treads there has been issues with dust seal and shim works it way down the crank spindle with nothing to stop it) But with these washers/shim it would put enough lateral pressure to stop the potential movement of the adapter and bottom bracket. I think if I had installed the cranks as per instructions I wouldn't of had any problems.
    Thanks for the input kracko
    Reputation: plussa's Avatar
    I don't think it's possible use a GXP BB with PF30 to BSA BB adaptor?
    There is nothing in a GXB crankset that keeps the drive side adapter in place. The cranks attach to the NDS bearing only.
    It's only possible to use a GXP crankset with an Niner EBB, because the adaptor halves are held together with a bolt.
    Yes it is with the specific adapter and shim installed correctly. It was incorrect installation not incompatibility that failed for me. I will install correctly and report any problems.
    This is the link to installation instructions
    http://www.sram.com/sites/default/fi...bb_adapter.pdf
    See here: http://www.ninerbikes.com/downloads/NIN_CYAchart.pdf
    NOTE: Niner bikes does not recommend SRAM threaded GXP bottom brackets with the CYA system, they are not compatible. Call Niner Customer Service with any questions related to this recommendation. 1.877.NINERXC
    Lucky I don't have to worry about the CYA system and just the PF30 BB as required on a Jet 9 RDO. The CYA system is irrelevant to my needs as i believe it is for the A9C and have solved any issues I had!
    Apr 2014
    Hi there.
    I have Specialized Stumpy fsr EVO frame, where I want to use my XX1 GXP crank. Therefore I have installed this adaptor in the frame together with a Hope MTB Stainless Steel Bottom Bracket (gxp conversion shims included). Here is a link to the current progress kortlink.dk/gs49 So fare so good. But before I install the crank I am wondering about point 9 10 and 11 in the manual previously linked to.
    First I find the picture confusion, as I donít see the GXP botton bracket on picture 10?
    What is the purpose of the wave washer? I dont want to add to much space between frame and crank, as I want to keep the chain line closer to the big sprocket on the cassette.
    And in the manual for installing the Hope Botton bracket there is no mention of this wave washer https://www.youtube.com/watch?v=NufgDt2zwXk I understand that, that manual off coarse does not consider that it is used together with this Sram PF30 to GXP adaptor. But none the less, I donít see the point of the wave washer?
    Apr 2014
    Okay i guess that my quistion is quite irellevant, since this has been covered in above posts. I truly dont understand why i did not see that. I guess my mind was locked on something else.
    Quote Originally Posted by kracko View Post
    Well I have two bikes with GXP bottom bracket. One with the threaded (ROS 9) and one PF (AnthemX 29er) with the same S1000 Cranks. The PF one required the wavy washer and the spacer, while the threaded did not.
    Jun 2012
    I am using this for my GXP in a BB30 needs. I had the old standard GXP BB with plastic adapters and it kept slipping and I wanted a permanent solution. So far this is working great on my 2015 A9C
    BB30 Outboard ABEC-3 BB for 24/22mm Cranks (SRAM) - Black
  1. SRAM PF30 to BSA adaptor
    By PlanB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2011, 07:05 PM
  2. SRAM XX crank stuck in press fit PF30
    By tate6969 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-19-2010, 11:30 AM
  3. looking for for Sram 9.0 front disc adaptor?
    By rideit in forum Wheels and Tires
    Last Post: 06-02-2004, 06:32 PM
  4. looking for Sram 9.0 front disc adaptor?
    By rideit in forum General Discussion
    Last Post: 06-01-2004, 12:19 PM
  5. NE1 have a Sram 9.0 disc adaptor REAR?
    Last Post: 04-28-2004, 01:24 PM
