Results 1 to 6 of 6
Thread: SIR9 questions
    Reputation: SeaBass_'s Avatar
    SIR9 questions
    I'm 6'3 with 34" inseam - Currently riding a 21" Dambala with 120mm stem & FuBars, 180mm XT cranks, and a setback seatpost.
    Would I be better off with the Large or X-Large SIR9 frame?
    Anybody encounter foot strike or ground clearance issues with 180mm cranks on the SIR9?
    Thanks for your help!
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    I would guess XL.
    I'm 6ft, 32" inseam and have been riding a Large with 90mm stem. They do have longer top tubes though, so you might want to see if you can get a test ride on a Large with a longer stem to see how it feels.
    Reputation: honkonbobo's Avatar
    Nov 2006
    i am 6' 4" on a XL MCR with 120mm stem.
    you are a little shorter than i am but i am a long ways away from a L. i would put you on a XL without question unless your arms and/or torso are quite short.
    Aug 2010
    I'm 6'1, 175 lbs and I ride a large MCR 9 if that helps.
    I'd say you need an XL.
    Thanks all! XL it is.
    northern soul
    Reputation: yo gomez's Avatar
    Brett from Niner answered the exact same question with "L" to me... :-/
    good night, good ride ...
