Page 10 of 10 FirstFirst ... 678910
Results 451 to 500 of 500
  1. #451
    Oct 2010
    I've been wanting to build a sir 9 for years. Finally pulled the trigger a few weeks ago.... Man i Love the way this bike rides.Show your SIR 9's!-2015-12-26-16.31.06-1.jpgShow your SIR 9's!-2015-12-26-16.38.06.jpg
  2. #452
    Reputation: Shooter McGavin's Avatar
    Feb 2007
    So a couple months back I helped my brother in law purchase a moondust grey sir 9. Completely corrupted me. The stand over. The rider compartment. Good ol' 853. Ended up selling my touring rig, a moots ybb 29er and picking up a white sir9. Reminded me a lot of the Gunnar Rockhound 29er I parted with when I purchased the moots.
    So far- way more tire clearance and the 142 makes it ultra stiff in the rear, which is nice when you elect to run BB7s. Those were my two beefs with the Mootsie (and Gunnar).
    Haven't ridden it excessively to say whether it feels as supple as the Moots, nor would I expect it to- but the feeling of owning blue collar steel again...
    So I built a soma wolverine with the xt 9 and then used the wheels, fork, stem bars and pretty much just scrounged the rest from the parts bin or friends to get the sir9 up and running.
    The compatibility and interchangeability of the 240s hubs is truly remarkable.
    Sir9 frame- medium
    Fox rlc 100mm fork
    Stans arch hoops w/ 240s hubs
    Moots post
    BB7 brake set
    Thomson 90mm stem
    The rest is Johnny Stock and fill in wabi sabi. Will purchase an m8000 grouppo before the touring begins this season.
    Pink grips were my daughter's and are just awesome.
    Attached Thumbnails Attached Thumbnails Show your SIR 9's!-e9f4b2f4-16db-4ca4-8873-151b2b859ff9.jpg
  3. #453
    Reputation: aybee's Avatar
    Feb 2014
    Stripped, sandblasted and clear coated frame and fork for that utilitarian, toned-down look.
    Originally an arctic white frame, size small with a salsa Cro-moto tapered and Thru-axle fork
    Easton Arc rims, Hope Pro 2 Evo 40T hubs, DT swiss comp spokes, Maxxis Ardent 2.4 tires
    XT M780 groupset modified to a 1x10 setup, raceface 32T narrow-wide chainring, Wolftooth 42T giant cog, Wolftooth 16T cog, Wolftooth GoatLink direct mount replacement for improved shifting and chain wrap
    Niner RDO cockpit, ESI grips, WTB Silverado Team saddle
    Shakedown ride this afternoon and noticed the rear rotor rubbing with the calipers while the frame is flexing during hard climbs. Anyone experience this? Shouldn't the maxle stiffen the rear and avoid such flex?
  4. #454
    Reputation: KevinGT's Avatar
    Dec 2012
    Anyone know the weight of the Sir 9, small? I'm on a One 9 Hydroformed right now and thinking about changing to a Sir 9 or a One 9 RDO. I know the Sir 9 is the heaviest of the bunch but just curious about how heavy.
  5. #455
    Reputation: jas76's Avatar
    Oct 2014
    I know this isn't an exact answer to your question but I have both the current SIR 9 and current One 9 RDO and they are built up identically (same forks, wheels, tyres, bars, brakes drivetrain, saddles, seat post) and there is 1kg difference between the two bikes. Both medium frames.
  6. #456
    Dec 2012
    Quote Originally Posted by jas76 View Post
    Wow. a 2.2 lbs. difference just from the frame? Makes sense...I hear estimates that the SIR is 5 lbs. and the RDO is 2.7 lbs. The hydroformed One 9 is right in the middle at 3.5. Not sure if the extra weight is worth the improved ride quality over the hydroformed.
  7. #457
    Pull the Maxle and check that the axle in the hub isn't broken. Check for play in the freehub. I've broken 2 Hope SS hub axle in the last year. Both have been replaced under warranty and the last has been replaced with a steel axle
    '16 Cannondale Scalpel Carbon 2
    '15 Niner SIR 9 SS
    '14 Cannondale F29 Carbon 3
  8. #458
    Oct 2014
    Quote Originally Posted by KevinGT View Post
    Yeah, its a difference but hey, I ride both the One 9 RDO and the SIR 9 equally. I don't notice the weight persee (only if I am carrying them) its the difference in the steel and the carbon I notice. One 9 is sharper, accelerates quicker but the SIR 9 takes less concentration and can sometimes be more comfortable (and faster as a result) when I'm not completely in the "racer" mindset.
  9. #459
    Feb 2014
    Quote Originally Posted by jdinsj View Post
    Thanks, went ahead and checked, and my problem was the maxle wasn't tight enough! There wasn't any play with the hub or the wheel, but when I tried unthreading the maxle the tension of the QR lever wasn't as tight as it should, it came off easily. Re-threaded and re-tightened and made sure the QR was tight enough to leave an imprint on my palm. A quick run through our local trails and no more rubbing.
  10. #460
    santa cruz tallboy 3 29er
    yeti asrc
  11. #461
    23lb 6oz
    niner sir 9 large
    niner rdo fork
    sram gx 1x11
    raceface affect cranks
    easton ec70 carbon lo rise bars
    niner trail 50mm stem
    niner aluminum post
    sdg bel air saddle
    formula t1 brakes 180/160 rotors
    sram roam 30 wheels set up tubeless
    schwalbe thunder burts 29x2.25
    yeti asrc
  12. #462
    OOOOOOOh Gee Are Eee
    Reputation: Ogre's Avatar
    Feb 2005
    @tony - nice setup. Everything I love about SS, super clean and sharp.
  13. #463
    Reputation: offrhodes42's Avatar
    Picking it up tonight. Got a great deal on a NOS small SIR 9 in moondust. It was originally going to be a single speed, but decided to sell the JET 9 and go back to a hardtail for the first time in over 13 years.
    The build:
    Small moondust frame
    X-Fusion Slide with 15mm thru
    Chris King Headset
    XT cranks with Absolute Black 34t oval ring
    SRAM GX gripshift and rear derailleur
    Niner aluminum post and bar (710 width)
    Notubes Crests with Kenda Karma 2.2 SCT (holding air for a month with no sealant in them yet)
    Ashima 160R and 180F rotors w/pink highlights
    Older Deore brakes (will eventually upgrade those)
    Sunrace 11spd MX8 11-42 cassette
    Photo has an old, beat up San Marco ERA but will have an old, beat up San Marco Aspide on it when I pick it up while I search for what I want for my next saddle.
    I am looking forward to riding a hardtail again and seeing if I am faster, slower, or no difference on my local trails.
  14. #464
    Reborn/rebuilt after scoring some wheels. Good to have her rolling again after a couple years hanging in the garage.
    Would like to score a suspension for for it though.
  15. #465
    Got mine out on it's maiden trail ride on Saturday. After almost 14 years on full suspension it was definitely different being back on a hardtail.
  16. #466
    Dec 2015
    My SIR. Few things have changed since these pics, I got a niner carbon seatpost, oval ring, put a fat b nimble 3.0 on the front and moved the ralph 2.4 to the back. Love this bike!!
    Niner RIP 9 Alloy
  17. #467
    I have always wanted a Niner 853 bike, used to be the MCR, but since that was discontinued the SIR has been the only option. Currently looking at a few used MCR's as well as a few SIR's, and started thinking about possibly trying singlespeed. Anyone with an SIR ever convert back and forth? I am curious how much time that takes, not that I plan on doing it daily or anything.
    These things are gorgeous, post more photos!
  18. #468
    Reputation: el_burras's Avatar
    Mar 2011
    Had a SIR9, 80% of the time SS, changed it every two months for a weekend only, fairly easy, took me around 20 minutes (when I had to mess around with the rear derailleur), if not 10 minutes top.
    get it, you wont regret it
  19. #469
    Reputation: plussa's Avatar
    Haven't posted mine in a while:
  20. #470
    Sep 2012
    Haven't run mine geared but I ran an Inbred that I used to swap regularly.
    Left the shifter bracket on the bars. Was 1x9, (eventually 1x10), with a front chain guide left on all the time. Easier these days with thick/thin rings obviously. One of the cable guides needed splitting.
    Swap wheel, mount the shifter & mech, slot cable into guides, swap chains.
    Took 10 mins tops.
    But, why on earth would you want to run gears... 😉
    Nice to see some action on this thread...😀
  21. #471
    Quote Originally Posted by takisawa2 View Post
    Took 10 mins tops.
    But, why on earth would you want to run gears... 😉
    Honestly, never tried an SS, so I can't yet say whether I like gears more or less than SS. One reason I like the SIR, is if I don't like SS, its just a couple parts shy of a 1x11 (which I want to try as well).
    When you are swapping from geared to SS, you can reuse the shifter cable, correct?
  22. #472
    I'm using a full length outer gear cable attached with zip ties, so it's even easier and faster to change from SS to geared. You never need to adjust it, just put it on or take it off.
    I was using the same shifter-cable-derailleur combo in my previous One9 which was specced for full length outer.
  23. #473
    Quote Originally Posted by plussa View Post
    Well, that is pretty brilliant. Do you have to switch the derailleur hanger? I don't see any reason that the SS wheel would have an issue, but just curious.
    Hoping it all works and I don't NEED to switch, we will have to see how well the setup agrees with the foothills here in Boise.
  24. #474
    I switch the hanger together with the derailleur, so I just need to open the two tiny screws to remove it...
  25. #475
    Well, I ordered a white medium, and received a white large... and they don't have another one, but they do have a yellow, which I don't really like. So, the shop is going to order the new grey/white for me it looks like. Anyone have any photos of one in the wild?
  26. #476
    Reputation: manwithnoname's Avatar
    Apr 2005
    Here is my blazing yellow. Those new grey scheme bikes do look nice, would like to see one in the wild as well.
  27. #477
    New Silver/White SIR
    Apologies for the steerer, had it cut today but am sick and haven't had time nor motivation for a proper photo. I can assure you I will take a better photo, and that it does in fact look WAY better without the periscope.
    Niner SIR, medium, Stan's Rapid wheels, Maxxis Icon 2.35's, XT 8000 crank, XT8000 brakes, Thomson Masterpiece seatpost (stolen from another bike to get enough post), Ritchey WCS Stream saddle (jury is still out, only 10 miles on it so far), Ritchey alloy bar and stem. I plan to try some sort of alt bar like the Answer 20/20 or Origin 8 UL8, not sure which, but I know I want carbon since its a rigid.
    After I test the waters on gearing, I plan to get an absolute black oval ring, but I want to determine what size and what cog I will want to go with it, I am thinking 32/19, but we will see.
  28. #478
    Aug 2016
    Hi All,
    I've wanted a SIR for quite some time, and finally got around to building one. Easily the best bike I've ever ridden.
    SIR 9, arctic white, L
    Manitou Tower Pro 100mm
    WTB st i23s, Hope Pro 2 Evo hubs
    WTB Trail Boss 2.4(f), 2.25(r), tubeless
    SLX brakes
    XT 1x10 drivetrain
    Wolf tooth 30t n/w
    Niner flat top alloy bar w/ESI chunky
    Niner Carbon post
    WTB Rocket saddle
  29. #479
    Quote Originally Posted by manwithnoname View Post
    What dropper are you running in your SIR? I am almost convinced to go the dropper route and have been looking at the PNW Rainier and X-Fusion Hilo.
  30. #480
    Apr 2005
    Quote Originally Posted by offrhodes42 View Post
    Its a 27.2 KS LEV, but I can't say that I'd recommend it. It has a very slow return rate and sometimes gets stuck down requiring a 'butt bump' to get it to return. This was after KS rebuilt it under warranty. I'm now rocking a Niner RDO post on the SIR 9.
    I have a 30.9 Thomson dropper on my bigger bike which I love, and I think they also make a 27.2 version, but its $$$$.
  31. #481
    Reputation: karyg's Avatar
    Do you have any pictures showing how you run the dropper post cable?
    Apr 2005
    I don't have any pictures unfortunately and I've since removed the post, but basically I ran the cable down the downtube just as you would for a front derailleur, and then up the NDS side of the seattube. I used a zip tie to anchor it right at the base of the seattube above the bottom bracket. Worked pretty good.
  33. #483
    Reputation: JUSTINAZ's Avatar
    Dec 2004
    sir 9
  34. #484
    Apr 2005
    Decided to put the dropper back on and give it another try. Applied some Slick Honey and operation is a bit smoother, but still slower than I like return. Gotta say a dropper on a fully rigid single speed is a lot of fun, feels like a giant BMX bike
  35. #485
    Feb 2007
    Cable clamps
    Do you still have the 3 Downtube cable clamps and the cable clamps that bolts to the bottom of the bottom bracket for the SIR9? I am also looking for the chainstay protector.
    Thank you
    tuned
    Quote Originally Posted by Shooter McGavin View Post
    Sir9 frame- medium
    Fox rlc 100mm fork
    Moots post
    BB7 brake set
    Thomson 90mm stem
  36. #486
    Reputation: patski's Avatar
    Dec 2005
    Fender Action
    After all the rain, fender'd up expecting lots of slop but it was great...
  37. #487
    Reputation: seat_boy's Avatar
    With a B+ conversion:
  38. #488
    Dec 2005
    Awesome, tell us more!
    Quote Originally Posted by seat_boy View Post
  39. #489
    Quote Originally Posted by patski View Post
    Honestly, not much to tell right now. We've had a bit of snow and cold, and then warm and rain... meaning our trails are muddy and unrideable right now. Clearance is good with the tires, you can see some pictures here:
    https://bikingtoplay.blogspot.com/20...s-and-new.html
    For instance, the rear clearance is still fine with the "2.8" TrailBlazer on a Blunt 35 rim:
  40. #490
    I am contemplating getting a SIR 9 to be used for bikepacking. I wanted to get some opinions of actual owners before pulling the trigger. Do you guys think this would be a good choice? I am planning on riding the Great Divide Route, not racing it just touring it. I found a good deal on a really clean bike but want to make sure it will fit the bill.
  41. #491
    Sep 2012
    There have been a few do the Tour Divide on SIR.9's.
    Imagine doing it single speed... :-)
    2012 Tour Divide Rider: Mel Liebling - Drunkcyclist.com
  42. #492
    Monster cross mode!
  43. #493
    Reputation: joshhan's Avatar
    Mar 2011
    Haven't had a chance to take it out on the trails so I rode it into work this morning. Felt pretty good over the potholes. LOL.
    Bikes, lots'o bikes
  44. #494
    Reputation: terrible's Avatar
    I told my wife a few weeks ago this this is probably my favorite bike I've ever owned. After working out seat post issues (replaced carbon with a thomson post and clamp) I have had zero issues. Upgrades since last pics include some carbon cranks, xtr brakes and egg beater 3 pedals. I went to a RS reba fork and I am really happy with it. I had a sid on it for a minute but that went on the other sir I bought for my wife (the white on white looks better any way). Any how....
    "I'm the fastest of the slow guys"
  45. #495
    I've been riding my BNiner a bit more, and I'm really enjoying this wheel size:
    The clearance is generous with a WTB TrailBlazer on the rear:
    No tire rub at all, I could probably go a bit bigger, even.
    I have a Jones Plus (29+), as well a Karate Monkey with a 29+ front/2.4" rear. I think this smaller wheel size has the grip and confidence of the bigger wheels, but turns noticeably better due to the lower inertia of the smaller, lighter wheel. Maybe a sweet spot, for me.
  46. #496
    My SIR9
    Here is my 2014 SIR9, large, Full XT, Sun-Ringle Charger Pro wheels, Ardent 2.4 front and Ikon 2.35 rear, SQlabs seat, KS Crux dropper.Show your SIR 9's!-niner.jpg
  47. #497
    Reputation: poorboy006's Avatar
    On my second Sir9 now and they just keep getting better
  48. #498
    You did a good job of hiding seatpost cable on that one!
  49. #499
    The snow has melted quickly in Central NH over the past 2 weeks. I took my SIR 9 out on my local trails for the first time this Spring. Put on a new saddle, my "training" wheelset, and new SLX 11-42 cassette. While skiing was good this winter, I really missed riding this thing.
  50. #500
    My SIR 9
    Scored a great deal on a NOS Sir 9 frame. Transferred all the parts from my SJ HT with the sliding dropouts. Such a great bike. I also have a ROS 9. And the difference between them is crazy. ROS great at smashing through stuff, SIR great at threading the needle.
