ROS 9 BB compatibility question
Hey guys,
Done a bit of reading on the forums but just want to check with someone smarter than me before i purchase.
Have a new purple ROS 9 frame on order but want to run my PFBB30 Sram X01 cranks from my Air 9 RDO on it. From what I can work out I won't be able to use the EBB supplied with the ROS but will have to buy the Niner CYA PFbb30 specific cups and then run a normal PFBB30 bottom bracket in the CYA cups. Is this correct?
Thanks in advance for your help.
Cheers
 Originally Posted by meltingfeather
If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
Thanks mate. Just wanted to be sure.
By NorcoCanuck in forum Downhill - Freeride
Last Post: 02-03-2014, 09:03 PM
By sandyeggo in forum Beginner's Corner
Last Post: 02-05-2013, 05:39 AM
By ksechler in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 11-13-2011, 12:30 AM
By Leprechaun in forum Trek
Last Post: 09-22-2011, 06:33 AM
By mutascan in forum Brake Time
Last Post: 04-26-2011, 01:47 PM
- You may not post replies
- You may not edit your posts
Forum Rules
