Results 1 to 8 of 8
    Rip9 RDO lowers shock mount play
    My lower shock mount seems to have some side to side play...as if the width where the shock bolts to the frame is too wide. This causes the rear end to not feel solid and also causes a clunk. If I take off the top shock mount, the play at the bottom mount is really obvious. Anyone else experiencing this? I guess I'll spin by Niner tomorrow
    Reputation: danvar's Avatar
    My Jet 9 RDO's shock bolts constantly keep loosening and I start getting that clunk. I'm pretty sure you probably already checked this but have you checked that the torque is up to spec?
    yup, the bolt is torque to spec (12nm). I suspect the shock bushing axle is not flush with the sides of mount (on the frame). I'll post back what Niner says.
    Yeah let us know. It would be good to know if there is an upgrade for these bushings.
    This is why I bought a Niner! Ralph swapped out the lower shock bushings with a slightly wider one. No frame/company is perfect...it's how they handle issues that matter.
    Awesome!!! Now....., I just noticed the the Niner encyclopedia states that all CVA model shock mounts should be torqued to 6nM. That,s what I torque mine to and it keeps coming loose. Do you know if Niner has changed this spec to 12NM instead like they have in the past with other torque specs?
    12NM is printed on the shock bolts on my Rip9 RDO. Niner upped the recommended torq spec on the Jet9 RDO (v1) to 8 or 9 NM...at least for the pivots. I'd also use some blue lock-tite.
    Reputation: kuykendallc's Avatar
    Re: Rip9 RDO lowers shock mount play
    Quote Originally Posted by cytoe View Post
    My pivot bolts would back out constantly until I added blue loctite and upped the torque to 9 nm
  1. Rune Shock Mount Play
    By Shampoo in forum Banshee Bikes
    Last Post: 03-02-2012, 08:41 AM
  2. Side to side play in front shock mount on LTC
    By raycje5 in forum Santa Cruz
    Last Post: 11-02-2011, 04:21 PM
  3. Disc brake post-mount stripped on fork lowers
    By derockus in forum Tooltime
    Last Post: 08-03-2011, 09:28 AM
  4. Replies: 5
    Last Post: 06-28-2011, 05:48 PM
  5. Is a little bit of play in the lowers normal?
    By dkbikes4life in forum Shocks and Suspension
    Last Post: 01-29-2011, 08:18 AM
