Results 1 to 3 of 3
    Mar 2013
    Rip 9 RDO - Revelation RCT3 setup
    Any thoughts out there on setting up RS revelation forks? 5'5" 160lbs fully geared up.
    Currently running 80psi in the solo air. Tried 75, 85, 90. If I tune for full travel but not bottoming out on the open setting - the threshold setting is very harsh. If I tune for a less harsh ride on the threshold setting, I bottom out on the open setting.
    I have played around with the rebound settings and LS comp. Starting in the middle of both settings and working each direction 1 click at a time but just can't seem to get it right.
    trail "cleaner"
    Don't know if I can help much since my Revelation RCT3 is the dual air version but I'm running 80 psi + and 70 psi -. Leaving it in the full open position with 3-5 clicks of LSC. Feels great for my 175-180 fully geared up weight. Getting full travel on the big hits but the O-ring usually ends up about 1/2" from the top on most rides in the AZ chunk.
    Quote Originally Posted by Bcbert-4 View Post
    Mar 2013
    Thanks the info. Looks like around 75 is good with in full open with just a bit of LSC.
  1. Rockshox Revelation RCT3 vs RLT
    By Brendan J in forum Shocks and Suspension
    Last Post: 07-15-2015, 03:10 AM
  2. RS Revelation RCT3 Dual Air
    By kaiser2 in forum 29er Components
    Last Post: 03-25-2013, 01:05 AM
  3. Revelation RCT3 or Float 32 CTD?
    By Killdozer in forum Shocks and Suspension
    Last Post: 12-08-2012, 02:36 PM
  4. Know the best deal on a Revelation RCT3?
    By rxsenduro in forum Shocks and Suspension
    Last Post: 08-03-2012, 01:53 PM
  5. Replies: 0
    Last Post: 08-03-2012, 01:51 PM
