Results 1 to 9 of 9
    RIP 9 RDO grease pivot bearings
    I have a 2014 RIP 9 RDO that I have been riding for a couple of months. A clicking noise developed recently when the rear suspension compressed. I decided to take the linkage apart and clean and put in fresh grease. Does the bearing for the upper linkage stay in the rear triangle? Should it be pressed into the rear triangle? Mine came out along with the black linkage part. I packed in grease into the cutout hole and bolted everything back. The clinking noise is gone but just wanted to double check about that bearing.
    I would call Niner. They are superb. My gut tells me they should be pressed into the frame.
    Quote Originally Posted by onobed View Post
    I think they are pressed in as well. I got a link to a service video from Niner:
    RIP 9 RDO Hardware from Niner Bikes on Vimeo
    The video shows the bearing staying in place when the bolt was removed. I'll give them a call.
    Feb 2015
    I have the same frame and my non-drive side bearing has started to push outward as well so there's a visible gap between the rocker arm and rear triangle (1 - 2 mm). Do I need to have that bearing replaced?
    Thanks.
    Quote Originally Posted by niner_marin View Post
    Thanks.
    Can you move the rocker side to side at the seat stay? Mine had some play, about a mm or two. This is what motivated me to take the suspension apart. I found the bearing in mine to be lose from the frame.
    I suggest you email service@niner.com and warranty@niner.com.
    Feb 2015
    There was some play in mine as well.
    I took the bike to my mechanic and the bearing had moved out a bit. Niner recommended using a little blue loctite and if it happened again, they'd look into a possible warranty replacement for the rear triangle. All has been good so far after a couple of rides.
    Reputation: rafalmtb's Avatar
    Oct 2013
    To be honest I think I have the same problem. I have this clicking noise and I did a lot to eliminate that but so far, with no luck. I have RIP 9 alloy 2014. The clicking noise started after about a year since I bought the bike. I started with rebuilding the rear Rockshox, then I took the pivots apart, re-greased them (bearings looked good). In the meantime I contacted my local mechanic, they suggested to contact Niner. I have been in touch with Niner for the last couple of months but no results of this conversation. The advise different things but nothing works. I even offered that I could drop my bike at their location in Fort Collins but there was no response. I feel like there is some loose in the pivots or that is a fault of my Rock Shox but at this point I am clueless.
    Just to update on the progress of this issue. I spoke with Niner on the phone and the bearings in the rear triangle near the seat-stays are pressed into the rear triangle. It's a tight fit and held in place with green loctite which is a bearing\sleeve retainer solution. I got small bottle from a local autoparts store. I cleaned the bearing and bearing hole in the rear triangle. I placed a bead of green loctite around the outside perimeter of the bearing and pressed it back into the frame. I allowed the loctite to cure overnight and reassembled everything the next morning. This fix didn't hold and the bearing backed out. After contacting Niner, they sent me a new rear-triangle as replacement.
    Thanks to Nate and Ralph at Niner. Great customer service!!
    Oct 2010
    Glad you could still get a Blue rear end!
  1. Best grease for repacking bearings?
    By FriendlyFoe in forum Giant
    Last Post: 12-22-2014, 10:24 AM
  2. Best Grease for VPP Bearings?
    By nowlan in forum Intense
    Last Post: 08-24-2014, 05:05 PM
  3. How Often Grease Wheel Bearings?
    By stumpbumper in forum Wheels and Tires
    Last Post: 08-06-2012, 06:10 PM
  4. Grease for cup-n-cone hub bearings?
    By mkrause in forum Tooltime
    Last Post: 03-02-2012, 06:05 PM
  5. T2 when & how to grease bearings
    By Pure in forum Intense
    Last Post: 10-04-2011, 10:11 PM
