Results 1 to 3 of 3
    Reputation: silent713's Avatar
    Feb 2006
    RIP 9 (alloy) rear axle options
    Quick question for everyone. I'm sure it's been discussed before, but I didn't see it. Is it possible to run a 135x12 thru-axle on the back of the allow RIP9 frame? I'm looking at picking up a frame, and would like to build the wheels up with some King hubs that I already have. I can get axle conversions to take it from a Q/A to T/A, but apparently only while maintaining the 135mm spread and not utilizing the 142mm drop outs that I see Niner advertise. Is it possible to get this to work? Thanks!
    A man who carries a cat by the tail learns something he can learn in no other way.
    Reputation: Qfactor03's Avatar
    Dec 2005
    I purchased my RIP9 with the 142 x 12 maxle option and converted an old Chris King ISO rear hub with standard 9mm axle to a 142x12 through axle. I ordered the 142x12 axle and end caps directly from Chris King. It was an easy swap out and mated up perfectly with the frame. What type of King rear hub is it? I don't see why you can't convert it to the 142x12.
    Feb 2006
    Thanks for the info. I guess I failed to see the 142x12 upgrade option when I looked on the site earlier. I also looked on Competitive Cyclist, and they were only selling the 135x12, so I thought that was all there was. Looks like I'm back on track with the original plan. Now all I have to do is convince myself that the RIP9 isn't too much frame for what I need.
    Thanks again!
  1. 135mm x 10mm nutted rear axle options
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2012, 10:43 AM
  2. '11 Sultan rear axle options
    By Where2 in forum Turner
    Last Post: 05-07-2012, 07:10 PM
  3. rear axle options for Mavic Crosstrail on my Camber
    By madsedan in forum Wheels and Tires
    Last Post: 04-24-2012, 01:54 PM
  4. Replies: 1
    Last Post: 10-04-2011, 09:40 PM
  5. options for 12mm Thru-axle rear hub ?
    By DG5 in forum 29er Bikes
    Last Post: 02-15-2011, 07:13 PM
