Results 1 to 19 of 19
Thread: RIP 09 vs 10
    Feb 2010
    RIP 09 vs 10
    i am looking to purchase a rip frame either an 09 or 10. there does not seem to be any difference between them. can someone please confirm if there is any differences between the 09 and 10 RIP frames. also, my height is about 5"7' would you recommend a small or medium frame? thanks in advance!
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Hi the frames are the same,the rear shock on the 10 has different valving & bost valve the 09 doesn't
    I have both.
    At 5'7 you could ride both med & small but I think you will find most people at your height are on small.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Feb 2010
    thanks mate!
    COMBO - President
    Reputation: FASTK's Avatar
    I am 5'6.5", small frame for sure.
    fux
    fux is offline
    Scooterist
    Reputation: fux's Avatar
    I`m 5`7 on a medium and it doesn`t look too big on the pictures. I also like somewhere to have a bottle.
    Disclaimer. I now sell bicycles and bicycle tyres.
    instacrap ----> http://instagram.com/manx71/
    Depends on your inseam length too.
    fux
    fux is offline
    Scooterist
    Yeah, mines 29".
    COMBO - President
    Mine is 29 1/2" inseam, use a 100mm stem. I really think a medium would be too big.
    Small is quick, stable
    fux
    fux is offline
    Scooterist
    There isn`t realy that much in it, It must come down to personal preferance.
    Iv`e slightly less post showing and have an 80mm stem.
    Carbon & Ti rule
    I think the Med frame looks nicer.
    Carbon & Ti rule
    But don't forget that the Tang Rip's are faster as are the Green Jet's
    Reputation: TheGreek's Avatar
    Quote Originally Posted by muzzanic
    That is dirty pool AND rubbing salt in the wound!
    Carbon & Ti rule
    And I thought someone was going to tell me to mow the lawn
    You don't just ride over it to cool down and kill two birds with one stone? Hmmm....
    Carbon & Ti rule
    Quote Originally Posted by TheGreek
    Now see that is thinking outside of the square
    Early 2009's don't have the notched chainstay, and can have chain suck issues with Shimano brand cranks, due to the offset /Q factor. They seem to function OK/better with Truvative Stylo cranks with a 51mm+ driveline.
    Apr 2005
    I have both.
    I'm curious, does the different valving and boost valve on the 10 make that big a difference? How do you like it?
    Carbon & Ti rule
    Quote Originally Posted by larsbaby
    With the boost valve the ride is a bit more plush & the lock out doesn't work as good, I never use the lock out & both are good.
    Reputation: fire_strom's Avatar
    Quote Originally Posted by RandyBoy
    Any pictures of the differences, the notch that is?
    Scott
