Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 401 to 450 of 479
Thread: RDO pics!
  1. #401
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    I really like your build, i have put a dropper seat post & 2.35 Nobby Nic's on my Jet9 RDO as well.
    Quote Originally Posted by IP_Ale View Post
    Got my RDO a little over a month ago. Love it. Wheels are on the upgrade list, but still in recovery from sticker shock.
    Frame Niner JET 9 RDO
    Fork Fox 32 Talas 29 CTD-ADJ Fit
    Brake Shimano XT M785
    Shifter Shimano XT SL-M780 i Spec
    Cable Shimano Stainless
    Housing Shimano Housing
    Crank Shimano XT M785
    BottomBracket SRAM/TruVativ PressFit 30 to 68/73mm English Thread Bottom Bracket Adaptor
    FrontDerailleur XT-M785-E2 2x10 TS F-derail, 66-69 T/B-pull E2-Type
    Cassette Shimano XT CS M771 10
    RearDerailleur Shimano XT M786 Shadow +
    Chain Shimano XT HG94
    FrontWheel Easton EA70 XCT 29 | 100X9 | FRONT WHEEL
    RearWheel Easton EA70 XCT 29 | 135X9 | REAR WHEEL
    Tire Schwalbe Nobby Nic
    Pedal Shimano XT M780
    Headset Chris King InSet 2 Black
    Stem Easton EA70
    Handlebar Easton Haven Carbon
    Grip Ergon GP-1
    Seatpost RockShox Reverb
    Saddle WTB Silverado Pro
    Attachment 743745
    I have a 6 Berth camper van that I rent out . It is based in Tauranga, New Zealand
  2. #402
    trail "cleaner"
    Reputation: AZmtncycler's Avatar
    I took the plunge into carbon.....
    This is my first round into the world of carbon frames... Vanna is her name.. This must be the 2nd rev. of frames as the headset is drop in like the original '09 RIP's. Running full length cable housing to prevent all of the horror stories I read about ghost shifting. For me, a svelte 25.4 pounds is the lightest bike I've ever owned. The specs are...
    med. size frame
    combination of XTR/XT drivetrain (9speed)
    XX SID 120mm 15mm axle fork
    Hayes Prim Pro brakes with Alligator serrated rotors 180mm
    Light Bike AM carbon rims laced to CK hubs (rear has 10mm Hadley bolt on thru axle) converted to tubeless
    WTB Bronson up front and Kenda Small Block 8 in the rear
    Answer Pro taper AM carbon bars with Oury grips
    Niner carbon RDO seatpost
    WTB silverado saddle
    lastly Cytoe's lower link bashguard
    No dabs allowed!
  3. #403
    Nov 2007
    When you say full length cable housing do you mean from the BB to r. derailleur or the entire bike right from the shifter? I'm considering doing a bit of drilling this winter to run one piece of housing so I may be interested in your opinion.
  4. #404
    Quote Originally Posted by AZmtncycler View Post
    med. size frame
    Nice build. You will love it.
    P.S.- There is nothing to be afraid of with the internal routing. Mine shifts light and smooth every time.
  5. #405
    trail "cleaner"
    full length...
    Quote Originally Posted by PlanB View Post
    I drilled out the little plastic piece down near the BB so the housing slides through.
    No dabs allowed!
  6. #406
    Dec 2008
    Where can I buy a protective sticker for the downtube my rdo came with a yellowish color.
  7. #407
    Dec 2009
    My 2012 Black RDO build
    I finally managed to build it.. my first Niner. I came from a Specialized Epic Carbon Comp frame 26inch.
    So far I really like it. I've yet to go out for a proper trail ride around my local loop. Only did a small ride this morning to get everything sorted.
    Build list is the following:
    2012 Jet 9 RDO size M
    Rockshox SID RCT3 120mm
    Light-Bicycle Carbon 29er Wide wheelset with Novatec 811/812 hubs (wheelset built by them)
    XTR shadow plus rear der.
    XTR front der.
    XTR shifters
    XT 28/40 Crankset
    XT 11-36 cassette
    XT brakes with 160mm rotors front and rear
    SLX chain (will replace this once worn along with the cassette)
    Specialized 2.1 Ground Control front / Renegade Control 1.95 rear
    3T Extendo LTD bars
    3T Doric team seatpost
    3T 90mm ARX team stem
    ESI chunky grips
    Specialized phenom gel seat
    Crank Bros egg beater 3 pedals
    i did a rough weigh (me on scales with bike minus me on scales) and i estimate the build to be 11.2kg as pictured
  8. #408
    Reputation: five5's Avatar
    Stem Easton EA70
    Grip Ergon GP-1
    Attachment 743745
    Was this a Competitive Cyclist buy? Looks Awesome!
  9. #409
    Specs:
    Frame: Niner Jet 9 RDO size M
    Fork : Fox 29er FIT RLC 100mm
    Hubs: Chris King
    Spokes: Wheelsmith DB
    Rims: ZTR Crest
    Shifters: M980 XTR
    Derailleur front: M985 XTR E 2 type
    Derailleur rear: M985 XTR shadow plus
    Crank: M980 double Crankset 26/38
    BB: Parlee PF30 shimano Adapter
    Brakes : M980 XTR
    Rotos: Ashima 160mm F/R
    Cassette : M980 XTR 11-36
    Chain : KMC SL-10
    Handlebar : Raceface lo riser Carbon 685mm
    Grip:Richey Ergo Foam Grip
    Stem : Thomson 90 mm
    Seatpost : Thomson Elite
    Seatpost clamb : Niner
    Saddle : Selle Italia SLR XC Flow
    Tires : Geax AKA 29er
    Paddles: M980 XTR
  10. #410
    3x front der
    Sorry if this has been answered elsewhere, if it is then I don't know how to use the google machine appropriately. What front derailleur would I need to run for a 3x10 shimano drivetrain? It seems there are a lot of options for the 2x10 but not the 3. I promise to post pics as soon as she arrives. Switching from Jet9 alloy to the RDO. Couldn't pass on the sweet deals.
    Would this work? Shimano SLX M661-10 Oe Front Derailleur > Components > Drivetrain > Front Derailleurs | Jenson USA Online Bike Shop
  11. #411
    Quote Originally Posted by Jack Jack View Post
    Specs:
    Hubs: Chris King
    Rims: ZTR Crest
    Shifters: M980 XTR
    Brakes : M980 XTR
    Chain : KMC SL-10
    Paddles: M980 XTR
    Beautiful. How much does it weigh?
  12. #412
    Reputation: Cerberus044's Avatar
    Quote Originally Posted by Wildebeast View Post
    I hope so because that's the same derailleur I just ordered to go with my new Jet 9 RDO
  13. #413
    Quote Originally Posted by onobed View Post
    about 25lbs.
    not the lightest,
  14. #414
    Nov 2007
    Any issues installing the Parlee PF30 adapter?
    I'm thinking of trying one with XTR cranks but they seem to market it as for road set-ups only. I believe external road BBs are something like 2mm wider than external MTB cups so I'm a little concerned.
    thanks
  15. #415
    yeah i know it was label at roadsetup but so far it been holding up great..
    no issue on chain clearance.
    its pretty simple to install.. i had my headset tools and i just install it as per what i done with my other BB30.
  16. #416
    Anyone have pictures and toughts on the Jet Carbon in moondust.
  17. #417
    Mar 2013
    hi im from philippines,want to share my niner
    this is the build list
    niner jet 9 rdo
    rockshox sid xx
    shimano xtr gruopset 38/26 2x10
    niner rdo stem
    niner rdo handlebar
    niner rdo seatpost
    selle italia slr carbonio
    mavic crossmax slr 29er
    scwalbe furious fred/racing ralphs
    esi grips
    arundel carbon bottle cage
    mavic skwers(temporary)
  18. #418
    Carbon & Ti rule
    Nice looking bike.
    Quote Originally Posted by lanceasprec View Post
    niner jet 9 rdo
    rockshox sid xx
    niner rdo stem
    niner rdo handlebar
    niner rdo seatpost
    esi grips
  19. #419
    Reputation: HouseNotes's Avatar
    Very sharp looking. Welcome to the group. You'll love it.
    Single Track Rules!
  20. #420
  21. #421
    Reputation: Brazilianbreeze's Avatar
    My RDO
  22. #422
    Vegas Niner
  23. #423
  24. #424
    Vegas Niner Specs
    I have had my Jet9 RDO now for a year. It has been great. I have raced it a couple times and mainly just enjoyed it as a weekend warrior.
    Specs:
    M Frame
    I9 Hubs
    Stans Flow Rims
    IKON/Nobby Nic
    Race Face Turbine Stem
    Niner Carbon Bars
    ESI Racer Grips
    Taiwan Seat Post
    Tioga Spyder Saddle
    XT Pedals
    The wheelset weights this bike down, however vegas trails are rough and can go from a decent cross country trail to a nasty down hill section quickly and I didn't want to have any issues with the wheels. I also weighed 30lbs more when I bought the bike. If I were to do it over I would have gone with the ArchEX rims.
    Total Weight w/pedals is just under 26lbs
  25. #425
    RDO pics!
    Build Question:
    I am about to build my Jet 9 RDO. Do I use grease or carbon paste on the integrated headset?
    Same question on the press fit bottom bracket - grease or carbon paste?
    Thanks in advance.
  26. #426
    USED2COULD
    Reputation: NS2000X's Avatar
    Mar 2005
    Build Question:
    Thanks in advance.
    I installed both of mine dry. No creaks after a year.
    <Insert Quiver>
  27. #427
    Build Question:
    Thanks in advance.
    Grease.
  28. #428
    USED2COULD
    Mar 2005
    Quote Originally Posted by cytoe View Post
    Grease.
    To be clear, I installed the PF cups, and the headset cups dry, but I use grease on all the contact points - lavishly.
    <Insert Quiver>
  29. #429
    Reputation: kellijayne's Avatar
    Hope all around fantastic bike... and LIGHT!
    22lbs
    and the 2012 frame and fork is for sale
    also comes with BB, headset, niner carbon seatpost
    Graphics have been removed!
  30. #430
    Quote Originally Posted by NS2000X View Post
    I used grease when installing the cups and contact points...
  31. #431
    RDO pics!
    Can you please let me know what you mean? I don't understand installing it dry versus grease on the contact points. Thanks
  32. #432
    USED2COULD
    Mar 2005
    I pressed the non-moving surfaces (the cups) in to the carbon head tube and bottom bracket shell without grease. The PF BB was especially easy.
    But I apply grease to all the sealed bearings so the contact point between the bearings and the cups is greased, as is the contact point between bearing and crank/steerer tube.
    Sorry for any confusion.
    <Insert Quiver>
  33. #433
    Nov 2008
    Sorry for the crappy cell phone pics but finally finished up with just about everything. Hands down the best bike I've ever ridden in the XC/trail category. I have a 28 tooth ring on it now for long climbs, but the 32T is a little more versatile for majority of our trails. Currently weighs 23 lb 10 oz with a few stronger components...plan on getting a lighter wheelset for racing.
    Jet9 RDO Black Licorice - Large
    American Classic All Mountain Wheelset
    Ikon 2.2 3C/exc/exo rear tire
    Schwalbe Rocket Ron 2.25 Evo Snakeskin front tire
    XX1 BB30 Crankset (swap between 28t and 32t ring)
    XTR rear der, chain, and shifter
    Sram XX 11-36 cassette
    XT brakes with ice-tech rotors and pads
    MRP 1x Chainguide
    Ritchey WCS Trail Bars 740mm
    Ritchey Trail Stem 70mm
    Niner Carbon seatpost
    WTB Silverado saddle
    Eggbeater 3 pedals w/ Ti spindles
    ESI Chunky Grips
  34. #434
    Moosehead
    Reputation: moosehead's Avatar
    2012 J9RDO v1.1 Large, Fox Float 120 CTD, Stans Arch EX wheelset, XO 24/38 crankset, XO FD and RD, XX 2x10 Gripshift, Sram PG1070 12-36 cassette, XT Brakes, Easton Haven Carbon Bar and 70mm Alu Stem, Thomson post, WTB Pure V SLT Saddle, front and rear Conti MK 2.2's tubeless, Raceface crank boots, XTR pedals, Cytoe guard, full rear housing and latest Niner shift kit.
    25 lbs 11 ozs with pedals. Could lose a few grams trimming seatpost and steerer and using less tire sealant, all else stays for trail versatility.
    Huge thanks to this board for helping score a no brainer frame closeout, detailed cable routing discussion, and setup tips. Shakedown launch will be 18 hrs of Fruita, hope my wrenching is good enough to avoid dental work.
  35. #435
    RDO pics!
    Got a weak ride in this weekend, and my KS LEV dropper post showed up today!
    http://i56.photobucket.com/albums/g1...psc4890d9e.jpg
  36. #436
    Reputation: Bailey44's Avatar
    Dec 2010
    Count me in, Picked up mine today. Man, what a bike!
    23.46lbs
    Jet 9 RDO or Jet 9 Carbon
  37. #437
    RDO pics!
    24 pounds. I am surprised its that weight given I spared little expense:
    Enve wheels, post, bar and stem
    XX1 Drive train
    XTR Trail brakes
    Float CTD 120 Fork
    XTR Pedals
    When I make this set tubeless I guess I will crack the 24 pound barrier.
    Now I need to heal to ride it.
  38. #438
    Carbon & Ti rule
    That is a very nice build.
    XX1 Drive train
    XTR Trail brakes
    Float CTD 120 Fork
    XTR Pedals
  39. #439
    RDO pics!
    Thanks. I learned a lot from your build.
  40. #440
    Dec 2010
    Good looking bike. Mine came in at 23.46lbs(large frame). I assume your wheels are lighter but my fork and brakes are lighter.
    XX1 Drive train
    XTR Trail brakes
    Float CTD 120 Fork
    XTR Pedals
  41. #441
    Reputation: quote's Avatar
    Recon Gold TK Fork, Fizik Tundra 2 Saddle, Crossmax ST Wheels, Maxxis Ardent(f) and Ikon(r) Tires, XT Brakes, XT Crank w/ 38t Ring, SLX Shifter, Zee D-Rail, ENVE Bars, e*Thirteen Guide, Egg Beaters, YAWYD Cap, ESI Chunk Grips.
  42. #442
    New Jet9RDO
    Got my new Jet9RDO a few days ago. Love the XXI and grip shift.
    Much improved over my Ibis SL. Need to cut the steerer tube and waiting
    for new saddle otherwise it's at 22.5 lbs with pedals and stans.
  43. #443
    Carbon & Ti rule
    Nice bike.
    Quote Originally Posted by mtbmig View Post
  44. #444
    Some great looking builds on here....and they're all so light!
  45. #445
    22.5 lbs!
    22.5! Do my Arch EX's, RS Revelation 120 fork, and 2x10 gearing really add 4+ LBS?! All else looks the same. oh yeah, I forgot the boat anchor I carry so I can drop it when I realize how fast I'm going.
    Single Track Rules!
  46. #446
    Carbon & Ti rule
    Quote Originally Posted by Andrewfuzzy View Post
    Mine has some pretty good gear on it & it's not down in the weights that some claim.
    Maybe I need new scales.
  47. #447
    Next time I am at the shop I will weigh and take a photo. Don't have a scale myself. The build has formula R1's (all titanium hardware), Fox float, and everything else as you see plus it's a small size. My medium Ibis SL is at 23.4 lbs.
  48. #448
    Oct 2010
    I realize this breaks all kind of bike runway photos, but here it is anyway:
    Jet 9 RDO Medium V 1.0 Back in Black
    RS Revelation RCT3 reduced to 120MM
    Cane Creek 40
    Thomson 70MM
    Easton EA70 low Rise 685MM
    ESI Chunky Grips
    Thomson Elite Post
    Fizik Gobi
    Shimano XT 785 Brakes (160/160)
    Shimano 2x10 I-Spec shifters
    SRAM X9 BB30 39x26 crank (I'm old and need 22)
    SRAM Press Fit 30 BB
    Shimano XT E2 Front Der
    Shimano 780 XT Pedals
    Shimano XT 11x36 Cassette
    Shimano M786 Shadow+ Rear Der
    Sun Ringle Black Flag Pro Wheels set up tubeless
    Schwalbe Nobby Nic 2.25
    I routed the rear cable housing full length along the brake line and then under the bottom rocker and then into the chain stay. I also have a Cytoe bottom guard.
    26.12lbs. First ride was finally today. Damn fast bike. Slow engine
  49. #449
    Dec 2010
    Can I get a close up of the rear cable set up? If I can't get mine to stop rattling, I may go that route.
    Quote Originally Posted by WoodstockMTB View Post
    Cane Creek 40
    Thomson 70MM
    ESI Chunky Grips
    Thomson Elite Post
    Fizik Gobi
  50. #450
    Oct 2010
    Quote Originally Posted by Bailey44 View Post
    I did it exactly like this guy did: How to cable rear derailler on a Niner Jet9 with 1 outer cable
  1. Replies: 18
    Last Post: 11-19-2010, 06:43 AM
  2. Replies: 8
    Last Post: 10-02-2008, 02:58 PM
  3. Replies: 6
    Last Post: 08-08-2006, 04:22 PM
  4. ! PICS ! mountain bonanza day ! PICS ! PICS ! PICS !
    By nobody242424 in forum Downhill - Freeride
    Last Post: 02-12-2006, 08:35 PM
  5. Replies: 4
    Last Post: 05-20-2004, 02:41 PM
