Page 3 of 5 FirstFirst 12345 LastLast
Results 201 to 300 of 479
Thread: RDO pics!
  1. #201
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by duffin View Post
    I am 6' 3" and am just starting to ride again after many years; capable, but not competitive yet.
    I ride only on the weekends (no mid-week training) on fast rolling XC trails in Marin County (China Camp and Rush Creek). Love tracking with Strava.
    Six months ago I bought a 2011 Specialized Epic Carbon Comp 29er on impulse because I trusted the brand and heard great things about 29er wheels and Fox brain shock.
    But since then, I've befriended some local pros and shop owners who have been educating me on what is what and I started feeling the deficiencies in the stock Epic. Biggest thing I am frustrated with are 1) the wheelset and 2) stock drive train on hills. Before I go Arch's w DT 240s and XTR group, I heard about the RDO.
    As luck would have it, my new pro friend works at a shop that demos the RDO. I took one out this weekend with fox talas, Arches on I9, and XO group.
    In comparison to my Epic, the RDO floats over roots and potholes, climbs hills like nothing and so nimble on downhills. On a 11 mile loop I frequent using Strava, shaved 2 minutes off each leg and made KOM on the back leg. Wow is this bike fast!
    I have to have one!!
    Now I need to figure out if I can upgrade wheelset to Arch's and DR
    240's on Epic with a rear 135mm hub plus an adaptor to fit my 142mm Epic frame - I want to upgrade Epic knowing I will switch to the RDO when cash is good.
    I envy you RDO owners!
    IMO just hold off on any wheel upgrade untill you learn a bit more about what wheels will work best for you.
    The Current Arch is a bit of a nothing wheel, It's not super light, It's not super strong, It's not super stiff & its not super wide.
    It's kind of a wheel you choose when you cant make up your mind what you should have.
    The Arch is due a make over & the new Arch is going to be much better so if you must go arch wait for that one.
    There are heaps of people on here that will say that They have got the Arch & it's been fine & had no problems with it.
    Wow thats something to strive for ( It's been fine & had no Problems )
    What weight are you ?
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
  2. #202
    My weight is 230.
    Not sure what to look at other than Stan's since I don't have an unlimited budget.
    I can wait for the new model, but when is it due out?
    2012 Niner Jet 9 RDO (Tang, XTR groupo)
    2011 Giant Reign 2 (XT groupo)
  3. #203
    Carbon & Ti rule
    My weight is 230.
    Ok at 230 lb go to the flow, It's only 50 grams more & it's wider, stiffer & stronger.
    It's also the same price.
  4. #204
    Epics are fantastic bikes, excellent race bikes for sure. The model you bought, despite the carbon front triangle, has complete crap parts on it though (to meet the price point). The wheels are really atrocious, heavy with bad hubs. You can always open the brain up a bit more on your epic to get better small bump compliance. I've also found that having a brain rear shock and a non-brain front (like your epic comp has) results in difficulties balancing the front and rear suspension. You can do it, but it takes some work.
    I'd also say go with the stans's flows at your weight. Although the new Arch EX wouldn't be a terrible choice if you don't do anything too extreme and use some Comp spokes.
  5. #205
    Thanks for the advice.
    I am trying to figure out how to build a wheel set in anticipation of buying the RDO but use it on the Epic in short term.
    Frames take different hub widths.
    See this thread.
    135mm rear hub possible to adapt to Epic 142mm space?
  6. #206
    Lots of hubs can be converted. If you stick with Stan's, DT, Chris King, etc you will be fine for going back and forth.
  7. #207
    I9 wheels also offer some of (or the greatest) axle configuration flexible in the industry. Front and rear can be configured for almost any currently available axle. I am running I9 Enduro hubs and Flow rims. Very nice.
  8. #208
    Jun 2010
    Got some new pics. Bike is complete only missing parts are rear derailler, pedals and crank.
    It weighs 8,86 kg. The missing parts weigh 624 gram and 613 gram for the crank so the grand total will be 10,115 kg with pedals. Want to replace the stock RS maxle with a Tune one wich saves 30 grams. Can u cut the RDO seatpost btw? This one is very long for me so can save some weigth there too.
  9. #209
    Reputation: Bunyan's Avatar
    Beautiful build. Nice touch on the red nips. That bike just looks fast.
  10. #210
    Dec 2011
    Quote Originally Posted by sand0kan View Post
    very nice looking bike. I could not figure out the seat post. Who makes it. It is perfect looking for this frame and I would like to switch to it.
    Personally I will cut mine but only have half the amount showing that you do. If my post was up that high, I would fear cutting it and would rather have the neck of the frame protected
  11. #211
    Jun 2010
    Quote Originally Posted by newto29r View Post
    The seatpost is also from Niner.
  12. #212
    My frame was planned for februari but my LBS gave me a call this morning that my frame arrived!!!!
    It will be build up in Januari with a XTR 2 x 10 group
    A XLR lefty carbon with XX lock out.
    DT 240s rear and front hub (lefty)/Crest rims/Sapim D-light spokes
    Framesize is small:
  13. #213
    Jun 2010
    very nice dave!
  14. #214
    Carbon & Ti rule
    Quote Originally Posted by G-Live View Post
    Muzzanic, Is your wife still running the double tap flat bar shifters? Any updates or close ups of that set up? Thanks
    G
    Sorry for the late reply, She really likes the setup but for me I find it better with the std setup.
  15. #215
    My LBS ordered mine Thursday. They were told one month before it comes in. Large in Vana White. Great compliment to my MCR. Will go X.O. 2x10. Unsure on wheels. Currently use Hadley on Arches with the MCR.
  16. #216
    Does the RDO take a center frame direct mount front XTR dérailleur?
  17. #217
    Reputation: pat@bike.orbea's Avatar
    Front derailleur xtr 985 E2 type
  18. #218
    Shimano XTR FD - 985 E2 type or XT FD-785 E2
  19. #219
    Let's ride
    Reputation: rensho's Avatar
    Quote Originally Posted by Edlisjas View Post
    Framesize is small:
    That's the exact build I want. Please send over to me when you're finished building.
  20. #220
    Framesize is small:
    When will it be done? I cant wait to see some pictures and weights.
    I am also builing a Black licorice with a lefty and I really want to see one done so I can see what it will look like and weigh. My frame is due in the next shipment (I hope).
    Are you a road biker that likes hills? Try this Michigan Mountain Mayhem.
  21. #221
    Quote Originally Posted by "Fred" View Post
    I hope it will be finished within about 14 days. I'm waiting for the front derailleur, ENVE handlebar and Gore shifting cables. I hope I have the correct adapter for the lefty.
  22. #222
    USED2COULD
    Reputation: NS2000X's Avatar
    Mar 2005
    Which lefty adapter do you have?
    The project 321 tapered adapter is the most common example.
    I have one of those and also an experimental prototype tapered adapter on order.
    <Insert Quiver>
  23. #223
    Quote Originally Posted by NS2000X View Post
    This is the one I have:
    It's not new. The seller told me it came off an Air9 carbon.
    Can you tell me if I need another adapter part to install the lefty?
  24. #224
    USED2COULD
    Mar 2005
    Yep. The washer is the part that spaces the standard adapter to the tapered width.
    All the pieces are present in that photo. Although I note that it has been cut so hopefully will provide the stack height you want for your stem on top of the lefty.
    <Insert Quiver>
  25. #225
    OK, thank you for your answer.
  26. #226
    Hi,
    I have ordered a Large Tang, but stressing over the finishing kit!!!!!
    Nothing goes with the Tang so my thoughts are going for red Hope evo II hubs black rims and then using the red for all of the small things seat clamp etc, any ideas????
    Also any feedback on the Fox with the new coating please
    Thks
  27. #227
    Carbon & Ti rule
    Quote Originally Posted by MTBkid SA View Post
    Hi,
    Thks
    I have had 2 Tang bikes & have tried many colour themes & IMO Tang with Red looks cheap.
    So Gold Hubs, Gold KMC chain, Gold FSA stem spacers & Orange Jag wire cables etc.
    I will take more pictures of my RDO with different wheels & post tonight.
    The RDO needs colour coding IMO.
  28. #228
    USED2COULD
    Mar 2005
    Quote Originally Posted by muzzanic View Post
    Whats wrong with going all black? The frame & fork should provide enough colour for tang.
    <Insert Quiver>
  29. #229
    Carbon & Ti rule
    Just don't look good IMO
  30. #230
    COMBO - President
    Reputation: FASTK's Avatar
    Small Frame, XTR
    Small Frame, XTR Drive train, Formula R1 brakes, Stans Crest wheels with Hope 2 hubs (20mm axle) Conti Mountain King front, Stans Raven back. Niner RDO seatpost, Edge handle bars and stem. I could have made it lighter in some places for sure but 24lbs for full suspension is pretty good.
  31. #231
    I wanted a black and white RDO but next shipment is a long way off!!!!
  32. #232
    Dec 2010
    Here is my 23.68# RDO.
  33. #233
    Back in the saddle after more than 20 years. This is my 12.6kg (27.7lbs) trail build. Still waiting for the final grips and saddle. Crappy photos - great bike!
  34. #234
    Well i got my RDO at last, rides better than expected. Now it is back to the begining as i need new talent to ride this bike as it is fast!!!!!!!, already fell my A**e off going to fast hit the deck and slid 10 mtrs, bikes ok ego is hurt!!!
    Only one problem? my wheel set is Hope Evo II on Arch rims with XT 6 bolt rotors, but i am having problems aligning the caliper and rotor to sit in the middle, it looks like i may have to shil the rotor out anyone else had this problem?
  35. #235
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    RDO 1x 10 XO
    Built up @ Bear Creek Bikes in Dalton GA. Weight is 25lbs 4 ozs
    Niner RDO Frame, Rock Shox Sid 15mm Tapered Fork, XO 1x 10 11/34 1070 Sram 1050 Chain, Noir Carbon SS Crank, E13 guide, Industry Nine Wheels, Stan's Flow Rims, Slant Six Tires, Ergon Grips, Niner RDO post and Carbon bar, Thomson Stem, Fizik Saddle, Hope Tech M4 Brakes 183/160, Time Carbon Attack Pedals
    ~~~~~~Singletrack Slayer~~~~~~~
  36. #236
    Carbon Lefty
    XTR group
    DT Swiss 240s/Crest Lefty wheels
    ENVE saddlepost and handlebar
    New Ultimate stem
  37. #237
  38. #238
    Carbon Lefty
    XTR group
    New Ultimate stem
    so what's the weight?
  39. #239
    10.7 kg
  40. #240
    OMG!! Nice bike!!!
  41. #241
    Great looking bike .... im dreaming of a black and white in Large......
    How heavy is the large frame? ive searched everywhere but no luck.
  42. #242
    Carbon & Ti rule
    Quote Originally Posted by Andrewfuzzy View Post
    5 Ib 3 oz for my Lge Tang
  43. #243
    Reputation: kellijayne's Avatar
    ... and if we just ... My NEW Custom jet9 RDO - "Ladies Version"
    Just got my Niner Jet9 RDO a few days ago. It's my first "29er" and I LOVE IT!!!
    Initially, I was skeptical as I thought it would feel too big being 5' 4", NOT SO! it's truly "O"mazing
    My build came to feather light 22 lbs
  44. #244
    Carbon & Ti rule
    Here is another 1 I just built up for a riding buddy.
  45. #245
    ... and if we just ... My RDO, in Los Andes Mountain! :D
    RDO pics!
    Color: Tang
    Stans Arch
    HuB CKs
    Handlebar Syntace Vector 680mm
    Stem : Ritchey 90mm
    Saddle: FiziK Tundra Carbon
    Fork: 2012 Terralogic 100mm 15QR
    Shifters: 2012 Shimano XTR
    Rear Derailleur: 2012 Shimano XTR
    Front Derailleur: 2012 Shino XT Type E-2
    Brake disK: Hayes Carbon Gramm
    Rotors: Ashima 160mm
    CrankSet: KCNC + BlackSpire 38-24
    Cassette : 2012 Shimano XT 11-36
    Pedals: Shimano XTR
    chain: 2011 Shimano XTR 10spd
    Tires: Maxxis CrossMark LUST (very heavy)
    Seatpost: Ritchey 31.6 350mm (next-- Thompson Masterpiese 350,)
  46. #246
    Just a reminder. Send me a message if any of you would like to trade. I have a near new Large Tang frame and would like to trade for a Medium Tang or Black.
  47. #247
    Jan 2011
    Shock balance w lefty and fox rp23
    10.7 kg
    Edlisjas,
    How is the balance of the lefty combined with the rp23 fox?
    BTW Nice build. I am considering pretty much the same thing just with enve wheels.
  48. #248
    Me too...
    Have the Lefty and the wheels (picture below...P321/Enve w/cutom red decals.) Hopefully my medium black frame will be arriving in the next month or so...was told March back when it was ordered last year.
  49. #249
    USED2COULD
    Mar 2005
    Quote Originally Posted by rwitte View Post
    There will be a few of us with Lefty RDO's. My Vana RDO should ship this week. My Experimental Prototype carbon lefty steerer will hopefully ship in the next week ish. Then I'll build it up.
    My wheels are I9's on Crests I built up from a set of 26" I9 Ultralite's I had.
    <Insert Quiver>
  50. #250
    Toro negro!
  51. #251
    Dr. Power que detalles!!
    Saludos
  52. #252
    She's 22.7 lbs :)
  53. #253
    Quote Originally Posted by bmcslt01 View Post
    Edlisjas,
    Hello, I haven't had the chance to ride the bike...
    November 25th, I had a surgery at my left knee. Yesterday, I had a surgery at my right knee. So, i hope i can ride the bike within 4 or 5 weeks.
  54. #254
    22.7 lbs - sick!!
  55. #255
    Jun 2010
    Finally ready!
    Specs:
    Frame: Niner Jet 9 RDO size M
    Fork : Rock Shox Sid WC
    Hubs: Chris King
    Spokes: DT Swiss Super Comp
    Rims: ZTR Crest
    Shifters: SRAM XX
    Derailleur front: SRAM XX
    Derailleur rear: SRAM XX
    Crank: Tune Smartfoot
    Chainrings: Tune 39 en Carbon Ti 25
    Brakes : Avid XX WC
    Cassette : SRAM XX 12-36
    Chain : KMC SL-10
    Handlebar : Niner Carbon flatbar 65 cm
    Stem : Tune Geiles Teil 4.0 85 mm
    Seatpost : Niner RDO
    Seatpost clamb : Tune
    Saddle : Selle Italia SLR Carbonio Flow
    Tires : Swalbe Racing Ralph en Rocket Ron
    Bottlecage: Tune Wassertrager uni
    Paddles: Xpedo M-Force XMF 08TT Titan
  56. #256
    Reputation: fastmq's Avatar
    Mar 2006
    that's a sexy bike whats the weight?
  57. #257
    Jun 2010
    10.14 kg / 22,35 LBS
    Will post a pic on the scale later today.
  58. #258
    Some better pics:
  59. #259
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Edlisjas, I love your J9RDO! Probably my favorite in the thread, hope you can ride soon.
    JMH
  60. #260
    Quote Originally Posted by fastmq View Post
    22.7 lbs
  61. #261
    Feb 2007
    Here's a Large RDO I built up for my riding buddy. I've shown it because of the Lefty and how it fits on the Large frame. Very tight. I bought a red ano King headset but couldn't make that work. The Cane Creek works fine once you take apart the upper cap.
    Wheelset is Project 321 with Crests, CX-Rays, and AC red ano valve stems . Front travel is 120mm. Weight is 23.5 pounds including the 360g Adamo saddle and Candy's. Crank is a 22-32-bash with a 22-36 double FD.
  62. #262
    May 2005
    Quote Originally Posted by craigsj View Post
    Very cool Craig.
    Hope you get a chance to switch off and compare to your TB
  63. #263
    Feb 2007
    Quote Originally Posted by Surfdog93 View Post
    Very cool Craig.
    Me too. Will have to ask really nicely.
  64. #264
    Reputation: 1-bar's Avatar
    As an owner of a 22.3lb Tallboy I've noticed there are not nearly as many killer Tallboy builds like there are as J RDOs. I didn't come here to crash the party but to give it up to Edlijas, Keillijayne, SandOkan, and Dr. Power- All of you have insanely sick builds! I like each one for different reasons.
    Kellijayne- I love the attitude in the graphics! The build is the most sensible with XO and Easton carbon wheels. $$ Spent in all the right places...
    SandOkan- All blacked out with the RDO cockpit and SRAM XX/WC setup is sick. The Tune Smartfoot is unique. And at 22.3lbs you know it's fast.
    Edlijas- Full XTR, ENVE and Left.. WoW, that is the sickest build! Man I'd love to test ride that machine...
    Dr.Power- Rotor cranks, XX and full fox rear and front is text book smart.
    2017 Spec Epic Expert WC
    2016 Trek Superfly SS (32x21)
  65. #265
    Some better pics:
    Which lefty is that... 120mm? 130MM? or 140mm?
  66. #266
    USED2COULD
    Mar 2005
    Quote Originally Posted by kellijayne View Post
    Looks the same as mine. A lefty Max PBR (140mm). With 29'er spacers max it could be is a risky 120mm, or a more common 110mm.
    EDIT: I was wrong - see post below, is an XLR at 90mm
    <Insert Quiver>
  67. #267
    It's a 90 mm lefty XLR solo air.
  68. #268
    COTA member
    Reputation: Dry Side's Avatar
    Niner Jet 9 RDO on the way
    Fork: Fox 32 TALAS 29 120 FIT RLC
    Headset: Cane Creek
    Tires: Geax AKA
    Wheels: Enve Twenty9 XC w/DT240s
    Drivetrain: SRAM X0
    Brakes: Avid X0
    Seat Post: Niner RDO
    Saddle: WTB Silverado SLT
    Handlebar: Niner Flat Top Carbon
    Stem: Thomson Elite X4
    Pedals: Shimano M540
  69. #269
    Which fork did you put on?
  70. #270
    Carbon & Ti rule
    Quote Originally Posted by Dry Side View Post
    Headset: Cane Creek
    Tires: Geax AKA
    Drivetrain: SRAM X0
    Brakes: Avid X0
    Very nice.
  71. #271
    RDO Tang with Industry Nine Hubs
    Hi,
    Thks
    This is how you make a Tang look good. I rode this demo bike and cut 2 minutes off my 15 mile loop time.
  72. #272
    RDO with Pink
    This is making a RDO Pink friendly.
    I didn't do it.
    Breakaway Bikes in Rohnert Park, CA did it.
  73. #273
    Carbon & Ti rule
    Headset: Cane Creek
    Tires: Geax AKA
    Drivetrain: SRAM X0
    Brakes: Avid X0
    Have you ridden it yet ?
    Ride report please.
  74. #274
    COTA member
    I get it Thursday, but even then snow might be an issue as it is middle of winter. Will post a ride report ASAP.
  75. #275
    Carbon & Ti rule
    Ok
    I need to shift my thinking then, I think I'm hard done by if it rains for 4 days in a row in winter.
    Any way nice bike & I'm sure you will love it when you do get to ride it.
  76. #276
    Black RDO w/ Chinese carbon rims:)
    Finally got my RDO built after months and months or collecting parts. Here she is:
    * Frame: medium, 3M "helicopter tape" applied, rock protection plate on the bottom
    * Fork: Fox Talas RLC
    * Bar: Syntace Vector 31.8 carbon
    * Brakes: xtr 988 trail, xtr center lock rotors
    * Shifters: X9 10s
    * Rear Der: X9 med
    * Front Der: Shimano SLX
    * Cranks: X9 BB30 (PF30 BB of course). 3x10, but with a RaceFace Light bash guard.
    * Seat: Terry Fly Carbon
    * Seat post: Niner RDO
    * Chain: KMC 10SL
    * Cassette: XT 771 (being replaced w/ Sram XG 1080 this week)
    * Wheels: DT 240s hubs, Sapim Race spokes, Chinese carbon rims (light-bicycles)
    * Tires: Ardent 2.4 front, Ikon rear
  77. #277
    Tame the Penguin!
    Reputation: El Beastro's Avatar
    Quote Originally Posted by cytoe View Post
    Sweet RDO!
    I'm helping a friend build her RDO this week. Where do we get one of those rock guards for the lower linkage?
    --El Beastro
  78. #278
    Quote Originally Posted by El Beastro View Post
    Sweet RDO!
    --El Beastro
    I custom make these link protection plates. Here's my ad:
    Rock protection for the Santa Cruz Tallboy and Niner Jet9 RDO and RIP9 (all sizes and model years) - Buy and Sell and Review Mountain Bikes and Accessories
  79. #279
    Tame the Penguin!
    Damn....that's cheap protection! I'll forward her the link so she can order one tonight.
    Are they in stock and available to ship for the RDO?
  80. #280
    Yes, I have these ready to ship
  81. #281
    Bad Case of the Mondays
    Reputation: Jdub's Avatar
    Sweet RDO!
    --El Beastro
    She got her frame?
    I need one of those frame guards, order coming.
  82. #282
    Quote Originally Posted by Jdub View Post
    She got her frame?
    The link is in Cytoe's signature line.
  83. #283
    Tame the Penguin!
    She got her frame?
    She never got a dime back from Mountain High Cyclery...Larry just stiffed her and now he's going out of business. She's got a backcharge filed through Discover which should be resolved this week. Hopefully she'll get her full $5k+ back from them and they can go after Larry.
    In the meantime, she ordered a white RDO from BikeBling.com - 1-800-BIKEPRO is Bike Bling. She ordered it on Thursday, had it on her doorstep the following Tuesday. We are just waiting for the fork to arrive from Fox tomorrow....and we'll start the build. We've been accumulating parts over the past month....should be a sweet build.
    The frame guards are sweet. She'll get one for her frame as well.
  84. #284
    Total suck. I was afraid to ask after all the stories popping up on here lately. Really, really bad situation. Feel quite fortunate to have gotten my frame, guessing I may have been the last lucky one.
    cytoe - Order is placed. Do I get a discount if I pick it at DBB?
  85. #285
    Doh! Surely, but I already put it in the mail
  86. #286
    Quote Originally Posted by Andrea138 View Post
    Tis finished! Summary of my first ride report: HOLY SH1T, THIS BIKE IS FAST!
    Who makes the seat post clamp, stem cap, and head set in the orange that matches the hubs?
  87. #287
    Always Learning
    Reputation: BruceBrown's Avatar
    Where does one get a SID World Cup that is black?
  88. #288
    Answered my own question, photo shows Chris king gold pieces.
  89. #289
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    Yeah- King headset, Hope hubs & seatpost collar, Nokon housing, and a local person in Memphis anodized my hardware & pivots
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
  90. #290
    Would this be the thread to let people know that there's one in stock at a shop in Chicago? Large, licorice.
    If there's a different place to post info, my apologizes and I'll move the info there.
  91. #291
    COTA member
    Better thread to post RDO availabllity here ..
    RDO delivery dates?
  92. #292
    Carbon & Ti rule
    Quote Originally Posted by brandonecpt View Post
    Leaving it here is good to.
  94. #294
    Tame the Penguin!
    Got the rock guard installed.....man, it fits like a glove. Great workmanship....very happy with it. Thanks Cytoe!
    --El Beastro
  95. #295
    Tame the Penguin!
    25.2 lb medium Vanna White RDO
    Just finished up helping my friend build up her RDO. 25.2 lbs w/pedals....pretty impressive rig.
    Went out with her for a shake down ride.....she was blown away by how the bike just felt 'right' for her. Damn, she was fast on it. Had to keep my WFO uncorked to keep up..
    --El Beastro
  96. #296
    So when you upgrading from the WFO?
  97. #297
    Tame the Penguin!
    LOL! Never......no interest in snapping one of those frames in half with my fat arse......
    Regarding the WFO....I'm just happy I didn't snap a wheel in half today.....PHEW!
  98. #298
    We'll be watching if those white grips turn to brown...
  99. #299
    Trail/All-Mountain Jet 9 RDO
    After a few months of wait on frame and 2012 components, it's time to ride!
    * Frame: large Tang
    * Bar: RDO carbon
    * Stem: Thomson Elite X4
    * Brakes: Shimano XT, 180mm
    * Shifters: Shimano XTR
    * Rear Der: XTR Shadow Plus
    * Front Der: XT
    * Cranks: XT 24/32/42
    * Seat: WTB Pure V Team ti, for now
    * Seat post: Specialized Command Post Blacklite 125mm
    * Chain: XT HG94
    * Cassette: XT 11/36
    * Wheels: Stans ArchEX, DT 240s hubs, DT Comp spokes
    * Tires: Specialized Purgatory 2.2 front, Ground Control rear
  100. #300
    Feb 2010
    Hello and congratulations, you are so high, how far you seat - BB
    Quote Originally Posted by mike_mtn View Post
    * Frame: large Tang
    * Bar: RDO carbon
    * Front Der: XT
    * Chain: XT HG94
  1. Replies: 18
    Last Post: 11-19-2010, 07:43 AM
  2. Replies: 8
    Last Post: 10-02-2008, 02:58 PM
  3. Replies: 6
    Last Post: 08-08-2006, 04:22 PM
  4. ! PICS ! mountain bonanza day ! PICS ! PICS ! PICS !
    By nobody242424 in forum Downhill - Freeride
    Last Post: 02-12-2006, 09:35 PM
  5. Replies: 4
    Last Post: 05-20-2004, 02:41 PM
