Page 20 of 20 FirstFirst ... 10 16 17 18 19 20
Results 476 to 479 of 479
Thread: RDO pics!
  1. #476
    Reputation: HouseNotes's Avatar
    If you have a pre-2013 (Kermit) Jet 9 with the CTD shock, it is recommended to leave in the Trail mode although I prefer the Descent mode which really makes it eat up the small stuff and unless you are hitting some BIG drops it will handle the hard hits as well(if you get your sag set right) Even in that mode it still climbs great. For some of the LONGER climbs like out west you might want to use the climb mode. If you have an older Jet 9 with the RP23 shock I would never do anything with it other than leave it in the Open mode and forget the Pro-Pedal mode. Then you can fool around with the dampening to get it right for your trails. BTW, I sent mind to Push and they asked about my Trails, riding style, weight, and bike, etc. and when I told them it was going on a Jet 9 RDO they told me the Pro-Pedal setting was designed to almost do nothing because that bike is so efficient at climbing that the Pro-Pedal is not necessary. Hope this helps.
    Single Track Rules!
  2. #477
    I have a V1.1 with the RP23. I leave mine with the ProPedal in position 1 all the time. It matches my Fox Float CTD fork in Trail mode nicely. I just ride and never touch the suspension when on the trail.
    Also depends on where you live and what your climbs look like. Here in AZ suspension that works and actually helps you climb versus being locked out is a benefit.
  3. #478
    Rockie is checking out the new RDO fork soon to be installed on my One9
    Pivot Mach 5.7 27.5
    Flash29C2
    Scalpel 29C1
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
  4. #479
    IMBA special edition Jet RDO
    I won this beauty at this years Sea Otter Classic. Small frame 23.4 pounds with pedals.RDO pics!-img_0433-resize.jpg
  1. Replies: 18
    Last Post: 11-19-2010, 06:43 AM
  2. Replies: 8
    Last Post: 10-02-2008, 02:58 PM
  3. Replies: 6
    Last Post: 08-08-2006, 04:22 PM
  4. ! PICS ! mountain bonanza day ! PICS ! PICS ! PICS !
    By nobody242424 in forum Downhill - Freeride
    Last Post: 02-12-2006, 08:35 PM
  5. Replies: 4
    Last Post: 05-20-2004, 02:41 PM
