RDO pics!
Printable View
  • 12-09-2012
    muzzanic
    I really like your build, i have put a dropper seat post & 2.35 Nobby Nic's on my Jet9 RDO as well.
    Originally Posted by IP_Ale View Post
    Got my RDO a little over a month ago. Love it. Wheels are on the upgrade list, but still in recovery from sticker shock.
    Frame Niner JET 9 RDO
    Fork Fox 32 Talas 29 CTD-ADJ Fit
    Brake Shimano XT M785
    Shifter Shimano XT SL-M780 i Spec
    Cable Shimano Stainless
    Housing Shimano Housing
    Crank Shimano XT M785
    BottomBracket SRAM/TruVativ PressFit 30 to 68/73mm English Thread Bottom Bracket Adaptor
    FrontDerailleur XT-M785-E2 2x10 TS F-derail, 66-69 T/B-pull E2-Type
    Cassette Shimano XT CS M771 10
    RearDerailleur Shimano XT M786 Shadow +
    Chain Shimano XT HG94
    FrontWheel Easton EA70 XCT 29 | 100X9 | FRONT WHEEL
    RearWheel Easton EA70 XCT 29 | 135X9 | REAR WHEEL
    Tire Schwalbe Nobby Nic
    Pedal Shimano XT M780
    Headset Chris King InSet 2 Black
    Stem Easton EA70
    Handlebar Easton Haven Carbon
    Grip Ergon GP-1
    Seatpost RockShox Reverb
    Saddle WTB Silverado Pro
    Attachment 743745
  • 12-10-2012
    AZmtncycler
    5 Attachment(s)
    I took the plunge into carbon.....
    This is my first round into the world of carbon frames... Vanna is her name.. This must be the 2nd rev. of frames as the headset is drop in like the original '09 RIP's. Running full length cable housing to prevent all of the horror stories I read about ghost shifting. For me, a svelte 25.4 pounds is the lightest bike I've ever owned. The specs are...
    med. size frame
    combination of XTR/XT drivetrain (9speed)
    XX SID 120mm 15mm axle fork
    Hayes Prim Pro brakes with Alligator serrated rotors 180mm
    Light Bike AM carbon rims laced to CK hubs (rear has 10mm Hadley bolt on thru axle) converted to tubeless
    WTB Bronson up front and Kenda Small Block 8 in the rear
    Answer Pro taper AM carbon bars with Oury grips
    Niner carbon RDO seatpost
    WTB silverado saddle
    lastly Cytoe's lower link bashguard
  • 12-10-2012
    PlanB
    When you say full length cable housing do you mean from the BB to r. derailleur or the entire bike right from the shifter? I'm considering doing a bit of drilling this winter to run one piece of housing so I may be interested in your opinion.
  • 12-10-2012
    azpoolguy
    med. size frame
    Nice build. You will love it.
    P.S.- There is nothing to be afraid of with the internal routing. Mine shifts light and smooth every time.
  • 12-10-2012
    AZmtncycler
    full length...
    I drilled out the little plastic piece down near the BB so the housing slides through.
  • 12-17-2012
    sherwinr
    Where can I buy a protective sticker for the downtube my rdo came with a yellowish color.
  • 01-06-2013
    chewsta
    My 2012 Black RDO build
    I finally managed to build it.. my first Niner. I came from a Specialized Epic Carbon Comp frame 26inch.
    So far I really like it. I've yet to go out for a proper trail ride around my local loop. Only did a small ride this morning to get everything sorted.
    Build list is the following:
    2012 Jet 9 RDO size M
    Rockshox SID RCT3 120mm
    Light-Bicycle Carbon 29er Wide wheelset with Novatec 811/812 hubs (wheelset built by them)
    XTR shadow plus rear der.
    XTR front der.
    XTR shifters
    XT 28/40 Crankset
    XT 11-36 cassette
    XT brakes with 160mm rotors front and rear
    SLX chain (will replace this once worn along with the cassette)
    Specialized 2.1 Ground Control front / Renegade Control 1.95 rear
    3T Extendo LTD bars
    3T Doric team seatpost
    3T 90mm ARX team stem
    ESI chunky grips
    Specialized phenom gel seat
    Crank Bros egg beater 3 pedals
    i did a rough weigh (me on scales with bike minus me on scales) and i estimate the build to be 11.2kg as pictured
  • 01-07-2013
    five5
    Stem Easton EA70
    Grip Ergon GP-1
    Attachment 743745
    Was this a Competitive Cyclist buy? Looks Awesome!
  • 01-09-2013
    Jack Jack
    Specs:
    Frame: Niner Jet 9 RDO size M
    Fork : Fox 29er FIT RLC 100mm
    Hubs: Chris King
    Spokes: Wheelsmith DB
    Rims: ZTR Crest
    Shifters: M980 XTR
    Derailleur front: M985 XTR E 2 type
    Derailleur rear: M985 XTR shadow plus
    Crank: M980 double Crankset 26/38
    BB: Parlee PF30 shimano Adapter
    Brakes : M980 XTR
    Rotos: Ashima 160mm F/R
    Cassette : M980 XTR 11-36
    Chain : KMC SL-10
    Handlebar : Raceface lo riser Carbon 685mm
    Grip:Richey Ergo Foam Grip
    Stem : Thomson 90 mm
    Seatpost : Thomson Elite
    Seatpost clamb : Niner
    Saddle : Selle Italia SLR XC Flow
    Tires : Geax AKA 29er
    Paddles: M980 XTR
  • 01-23-2013
    Wildebeast
    3x front der
    Sorry if this has been answered elsewhere, if it is then I don't know how to use the google machine appropriately. What front derailleur would I need to run for a 3x10 shimano drivetrain? It seems there are a lot of options for the 2x10 but not the 3. I promise to post pics as soon as she arrives. Switching from Jet9 alloy to the RDO. Couldn't pass on the sweet deals.
    Would this work? Shimano SLX M661-10 Oe Front Derailleur > Components > Drivetrain > Front Derailleurs | Jenson USA Online Bike Shop
  • 01-23-2013
    onobed
    Originally Posted by Jack Jack View Post
    Specs:
    Hubs: Chris King
    Rims: ZTR Crest
    Shifters: M980 XTR
    Brakes : M980 XTR
    Chain : KMC SL-10
    Paddles: M980 XTR
    Beautiful. How much does it weigh?
  • 01-23-2013
    Cerberus044
    I hope so because that's the same derailleur I just ordered to go with my new Jet 9 RDO
  • 01-23-2013
    Jack Jack
    about 25lbs.
    not the lightest,
  • 01-24-2013
    PlanB
    Any issues installing the Parlee PF30 adapter?
    I'm thinking of trying one with XTR cranks but they seem to market it as for road set-ups only. I believe external road BBs are something like 2mm wider than external MTB cups so I'm a little concerned.
    thanks
  • 01-24-2013
    Jack Jack
    yeah i know it was label at roadsetup but so far it been holding up great..
    no issue on chain clearance.
    its pretty simple to install.. i had my headset tools and i just install it as per what i done with my other BB30.
  • 03-23-2013
    go2go2
    Anyone have pictures and toughts on the Jet Carbon in moondust.
  • 03-24-2013
    lanceasprec
    hi im from philippines,want to share my niner
    this is the build list
    niner jet 9 rdo
    rockshox sid xx
    shimano xtr gruopset 38/26 2x10
    niner rdo stem
    niner rdo handlebar
    niner rdo seatpost
    selle italia slr carbonio
    mavic crossmax slr 29er
    scwalbe furious fred/racing ralphs
    esi grips
    arundel carbon bottle cage
    mavic skwers(temporary)
  • 03-24-2013
    muzzanic
    Nice looking bike.
    niner jet 9 rdo
    rockshox sid xx
    niner rdo stem
    niner rdo handlebar
    niner rdo seatpost
    esi grips
  • 03-25-2013
    HouseNotes
    Very sharp looking.:thumbsup: Welcome to the group. You'll love it.
  • 04-04-2013
    five5
    RDO pics!
  • 04-12-2013
    Brazilianbreeze
    My RDO
  • 04-12-2013
    Brazilianbreeze
    Vegas Niner
  • 04-12-2013
    Brazilianbreeze
  • 04-12-2013
    Brazilianbreeze
    Vegas Niner Specs
    I have had my Jet9 RDO now for a year. It has been great. I have raced it a couple times and mainly just enjoyed it as a weekend warrior.
    Specs:
    M Frame
    I9 Hubs
    Stans Flow Rims
    IKON/Nobby Nic
    Race Face Turbine Stem
    Niner Carbon Bars
    ESI Racer Grips
    Taiwan Seat Post
    Tioga Spyder Saddle
    XT Pedals
    The wheelset weights this bike down, however vegas trails are rough and can go from a decent cross country trail to a nasty down hill section quickly and I didn't want to have any issues with the wheels. I also weighed 30lbs more when I bought the bike. If I were to do it over I would have gone with the ArchEX rims.
    Total Weight w/pedals is just under 26lbs
  • 04-23-2013
    onobed
    RDO pics!
    Build Question:
    I am about to build my Jet 9 RDO. Do I use grease or carbon paste on the integrated headset?
    Same question on the press fit bottom bracket - grease or carbon paste?
    Thanks in advance.
