Page 10 of 10 FirstFirst ... 678910
Results 451 to 479 of 479
Thread: RDO pics!
  1. #451
    Reputation: kakachi's Avatar
    Nov 2008
    delete
    delete having problems with forum
    A trophy bike is easier to maintain than a trophy car. Both are easier to maintain than a trophy wife.
  2. #452
    Nov 2008
    Shrek
    Meet Shrek. Weighed in at 10.85kg/ 23.9lbs
    Large Jet 9 RDO
    Fox Talas 29 120mm
    SRAM XX1 Drivetrain
    Magura MT6 brakes with Shimano Ice-Tech 180/160 rotors
    Enve 29XC wheelset (DT 240S)
    Schwalbe Nobby Nic 2.25F, Racing Ralph 2.25R
    Thomson X-4 50mm stem
    Niner Seatpost and 710mm flat top bar
    Selle Italia SLR Superflow 145
    ODI TLD lock-on grips
    HT ME03T pedals
  3. #453
    Nov 2008
    nice to see so many Jet 9 RDOs here!
  4. #454
    Nov 2008
    2013 Jet 9 RDO in Niner Green
    Meet Shrek. Weighed in at 10.85kg/ 23.9lbs.
    Large Jet 9 RDO
    Fox Talas 29 120mm
    SRAM XX1 Drivetrain
    HT ME03T pedals
  5. #455
    Quote Originally Posted by muzzanic View Post
    Mine has some pretty good gear on it & it's not down in the weights that some claim.
    Maybe I need new scales.
    Maybe i should remove the bottle top off the YAWYD and re weigh it.
  6. #456
    USED2COULD
    Reputation: NS2000X's Avatar
    Mar 2005
    Quote Originally Posted by Andrewfuzzy View Post
    My medium is right at 23lb [EDIT: it was at 22.9 as in my sig, but I switched to a wider bar, and need to update], I have one "heavy" component on the entire bike, where I could save ~90-100g. Loosing a chainring and a shifter would "possibly" get me to 22.5 lb's. Any JetRDO that is at 22.0lbs is incredible.
    <Insert Quiver>
  7. #457
    Dec 2012
    Here she is. 95% Complete. Hope she rides as good as she looks.
  8. #458
    My Large RDO freshly built a few month ago..
    Bathroom scale test right at 25.5lbs
    XX1
    XT Brakes
    Flows / i9 Torch Classic hubs
    Nobby Nic / Racing Ralph
    Fox 32 CTD 120mm
    Easton Haven Bar n Stem
    Thomson Elite Seatpost
    WTB Volt Team
    ODI Rogue Grips
    Attached Thumbnails Attached Thumbnails RDO pics!-20130525_152201_4_bestshot2.jpg
  9. #459
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Nice bike.
    I have a 6 Berth Motorhome that I rent out . It is based in Tauranga, New Zealand
  10. #460
    It's just a blast to ride. Trying to resist getting a dropper post and going with a shorter stem. hate my OCD
  11. #461
    Carbon & Ti rule
    Quote Originally Posted by schocka View Post
    Don't fight it, I put a dropper on mine & a shorter stem.
  12. #462
    Ya, i know.. the boss lady beats me home every day after work. so it's tuff to sneak in new toys. Bday is coming up so maybe i can get a pass
    Depending on the day i am between 6'2-6'3 so i may try out 70mm stem on my L RDO.
    Been looking at droppers for a while, leaning towards the KS Lev or the Thomson.
  13. #463
    Carbon & Ti rule
    Sell her on the added safety on down hills.
    I use Reverbs, But have a look at the fox doss as well.
    It has a double lever so you can drop a little when needed or a lot, Most of the time when I drop mine I only drop it 1 1/2 inches & the full amount now and again.
  14. #464
    Reputation: five5's Avatar
    RDO pics!
    XX1
    XT Brakes
    Fox 32 CTD 120mm
    WTB Volt Team
    ODI Rogue Grips
    Looks Bad Ass!!! Really like the white ones! I love the set up, XT brakes are awesome!
  15. #465
    Rothrock state forest in Pennsylvania. The RDO is perfect for the rock gardens and terrain here.
  16. #466
    Reputation: Brazilianbreeze's Avatar
    Loving my Niner
  17. #467
    I have some more around here somewhere.. Fun Bike!!!
  18. #468
    Reputation: JammerNinerBoxx's Avatar
    My RDO
    This is my current fast XC ride. Love it.
  19. #469
    Reputation: pat@bike.orbea's Avatar
    RDO pics!
    Quote Originally Posted by JammerNinerBoxx View Post
    Me gusta tu bicicleta jammer!!
    apparently share the same taste!
  20. #470
    Carbon & Ti rule
    Nice bike.
  21. #471
    Reputation: HouseNotes's Avatar
    How are those torch wheels holding up?
    Single Track Rules!
  22. #472
    Great! I'm 185 all suited up and haven't had any problems. Stiff and lite weight.
  23. #473
    Nov 2013
    great pics here!
    I find it strange that almost nobody installs a remote for their rear shock on their Jet.
    Do you guys change the lever manually every time or do you keep it on trail modus all the time?
  24. #474
    Trail setting unless there's a stupid steep climb, or a long fast fire road.
  25. #475
    Reputation: jboyd122's Avatar
    I keep mine in trail mode most of the time. I never use the climb setting since I find the CVA suspension to do an adequate job on minimizing bob in the trail setting and I like a little squish for technical climbs. I will throw in over to descend mode if I know I'm going to bomb down a gnarly technical descent.
  26. #476
    If you have a pre-2013 (Kermit) Jet 9 with the CTD shock, it is recommended to leave in the Trail mode although I prefer the Descent mode which really makes it eat up the small stuff and unless you are hitting some BIG drops it will handle the hard hits as well(if you get your sag set right) Even in that mode it still climbs great. For some of the LONGER climbs like out west you might want to use the climb mode. If you have an older Jet 9 with the RP23 shock I would never do anything with it other than leave it in the Open mode and forget the Pro-Pedal mode. Then you can fool around with the dampening to get it right for your trails. BTW, I sent mind to Push and they asked about my Trails, riding style, weight, and bike, etc. and when I told them it was going on a Jet 9 RDO they told me the Pro-Pedal setting was designed to almost do nothing because that bike is so efficient at climbing that the Pro-Pedal is not necessary. Hope this helps.
    Single Track Rules!
  27. #477
    I have a V1.1 with the RP23. I leave mine with the ProPedal in position 1 all the time. It matches my Fox Float CTD fork in Trail mode nicely. I just ride and never touch the suspension when on the trail.
    Also depends on where you live and what your climbs look like. Here in AZ suspension that works and actually helps you climb versus being locked out is a benefit.
  28. #478
    Reputation: StumpyElite2010's Avatar
    Rockie is checking out the new RDO fork soon to be installed on my One9
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
  29. #479
    IMBA special edition Jet RDO
    I won this beauty at this years Sea Otter Classic. Small frame 23.4 pounds with pedals.RDO pics!-img_0433-resize.jpg
  1. Replies: 18
    Last Post: 11-19-2010, 06:43 AM
  2. Replies: 8
    Last Post: 10-02-2008, 02:58 PM
  3. Replies: 6
    Last Post: 08-08-2006, 04:22 PM
  4. ! PICS ! mountain bonanza day ! PICS ! PICS ! PICS !
    By nobody242424 in forum Downhill - Freeride
    Last Post: 02-12-2006, 08:35 PM
  5. Replies: 4
    Last Post: 05-20-2004, 02:41 PM
