Results 1 to 10 of 10
Thread: RDO fork
    Reputation: StumpyElite2010's Avatar
    RDO fork
    Does the RDO fork comes with a crown race ?
    If not, what crown race is recommended, including the diameter I need please.
    Any other items that I need in order to install it in lieu of my SID on my Hydro One 9 ?
    S.C. TB2
    Flash29C2
    Niner One9 SingleSpeed RDO fork
    Supersix Evo 1 Hi Mod D/A
    Jun 2010
    No because the crown race depends on wat bearings you use.
    I think you mistake a crown race for an expander. The fork comes with this expander plug.
    You have to remove the crown race from your sid and place it on the rdo.
    Thanks,
    No I am not mistaken. I know what is a compression plug.
    If it require a special tool to remove it, I rather leave the crown race on the SID
    I am planning to alternate between the 2 forks.
    S.C. TB2
    Flash29C2
    Reputation: honkonbobo's Avatar
    Nov 2006
    Quote Originally Posted by StumpyElite2010 View Post
    the crown race needs to be compatible with your headset (specifically the lower bearing as sandokan said). there is a specific crown race remover tool or you can remove it the ghetto way but if you want to quickly swap forks your best bet is to buy another compatible race since they are cheap and stick it on the RDO.
    My headset is the standard one that came with the 2012 Niner 9 frame
    1.125-1.5 taper head tube with integrated (Campy style) headset (FSA headset included) Cane Creek standard description: IS42/28.6|IS52/40
    What crown race do I need ?
    S.C. TB2
    Flash29C2
    Go ride!
    Dec 2011
    I don't have the exact part number handy, or the price, but I know we have them at the shop. Just email me at mark@probikesupply.com and we can get one out to you on Monday.
    i also want to know which one i need.
    Go ride!
    Dec 2011
    What frame do you have?
    air 9 carbon
    Go ride!
    Dec 2011
    Been getting a lot of emails about replacement base plates for Niner's so we created a product for them.
    FSA Niner Orbit Xtreme Pro 1.5 " Crown Race - Pro Bike Supply
