Results 1 to 29 of 29
    Reputation: kellijayne's Avatar
    New question here. Question: RIP RDO vs Jet 9 RDO
    Question regarding RIP RDO vs Jet 9 RDO. I currently have the Jet9 RDO carbon and am thinking of selling the frame and fork for the RIP. What is the weight difference and will I notice a disadvantage in climbing ability? I miss my 140mm suspension of my previous bike however, I LOVE the climbing ability of my Jet9
    Kelli
    Attached Thumbnails Attached Thumbnails Question: RIP RDO vs Jet 9 RDO-4413.jpg
    Reputation: five5's Avatar
    I think it will be exactly what you'd expect. Tad heavier, tad tougher on the climb, and can take a rougher go downhill.
    Muzzanic has a good thread with some comparables, check that out.
    If Muzz replies here, lets make it a little more objective.
    Scale 1-10, 10 being best!
    Climbing -
    Decending -
    Weight -
    Handling -
    Overall -
    I know it doesn't make sense on the weight one, but I think it does! Weight is relative sometimes.. People focus too much on the number. How does the weight feel when you ride it? Being they are different bikes, for different riding, is the weight appropriate for its purpose?
    What do ya think?
    Looks like the RIP frame weight is 6.45 lbs as opposed to the 5lbs of the Jet 9 RDO. My bike is currently at 22+ lbs
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Hi
    If you are missing the longer travel you will be surprised how little you will have to give up if you go Rip9 RDO.
    I will sit down late tonight & write more about what I think between the 2.
    One of my friends that I ride with 2 to 3 times a week that has been on a Jet9 RDO for almost a year has decided to go for a Rip9 RDO because he thinks i'm no slower on the climbs.
    His weakness is on the down's so he is hoping to bridge some of the gap I have on him on the down's
    This is not taking a 22lb Jet9 RDO & a 28lb Rip9 RDO, This is if they were all built with the same build apart from fork travel.
    Jet9 RDO climbing 10
    Rip9 RDO 9.5
    Jet9 Alloy 8.5
    Rip9 Alloy 7+
    On a long the difference between 7 & 10 is approx. 2 gears.
    Down hill.
    Rip9 RDO 10
    Rip9 Alloy 9
    Jet9 RDO 8.5 to 8.75
    Jet9 6.5 to 7
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Quote Originally Posted by muzzanic View Post
    Rip9 RDO 9.5
    Jet9 Alloy 8.5
    Rip9 Alloy 7+
    Thanks Muzzanic!!!
    So would you say the difference with the same build would be about 2 lbs? (so basically new frame, fork and shock)
    I truly enjoy the climbing of my Jet9, it's fantastic!!! I've actually increased my climbing times from my past 26er 21lbs. Downhills are certainly not as forgiving as the 140mm, and being over 50 I notice it on the longer more technical descents.
    I guess I'm still not sold on the switch, but have not ruled it out for sure
    Carbon & Ti rule
    For me the switch was only a little over 1 Ib
    I can't really feel the weight difference, I have only ridden my Jet9 RDO once since I got the RIp9 RDO & that was because someone wanted to ride my Rip9 RDO so I took them both out.
    I think you should put how it climbs out of your mind because it really is very very good & that is not a deal braker .
    I would think more about no bottle cage bolts inside the frame on the small & what fork you would put on it & a little .
    FWIW if I was building a new bike for my wife today it would be the RIP9 RDO, Even though there is no was she could use 1/2 the extra down hill this bike would give her.
    I have watched lots of people on the Alloy Rp9 over the years & it just lifts there ridding so much, Now the Rip9 RDO will do the same but not at the cost of climbing & the bike still keeps most of the Jet9 RDO's snappy ness out of the corners, were as the Alloy rip9 lost a lot of that over the Jet9 Alloy in this feel.
    All that said the Jet9 RDO is still an awesome bike & can be made very fast down hill with bigger tyres, Dropper seat post & things like that.
    The Jet9 RDO back end does buck a bit more off sharp jumps & is not as good in the air & landings as the Rip9 RDO so it has a lot to do with how you like to ride.
    Thanks Muzz,
    I have a question for you. I just ordered a RIP9 RDO to go with my Jet9 RDO, my question is are you running the RS revelation fork on it; and if so what are your thoughts? I know that you have a Pike on order and I'm considering that as well. I come from a DH back ground and I plan on building the RIP up to be an aggressive all mountain/Enduro machine; and I just wondered if I should plan on upgrading the fork.
    Carbon & Ti rule
    Yes I have a RCT3 140 Revelation fork on my Rip9 RDO & like it a lot, But the Pike is just more like what I have wan'ted for a long time
    Quote Originally Posted by cdsdad View Post
    Thanks Muzz,
    I loved my Jet9RDO and bought it because of Muzz reviews. I was going to buy the Rip 9 RDO because I loved my Rip 9. It was the best bike I had ridden until I got my Jet9 Rdo. I haven't pulled the trigger due to too much cross over and for me honestly the JEt9RDO helps me where I need it (climbs) so I would say if you are a much better climber then the Rip is your kit but if you need help on the ups then go with the Jet. I am sure you will be very happy with either but for me and the guys I ride with we were more accomplished on the dh side so the Jet is perfect (obviously I am guessing since I haven't ridden a Rip9Rdo)
    Carbon & Ti rule
    Quote Originally Posted by tws_andrew View Post
    You have pretty much nailed it.
    Awesome advise everyone! Thank You!
    I would like to sell my Jet9 RDO frame &"fork and pick up a RIP9 RDO frame & Fork
    I heard through the grapevine... Some components are not compatible!
    Such as:
    Bottom Bracket
    Seat Post
    Head set
    Is there anything else???
    Quote Originally Posted by kellijayne View Post
    Such as:
    Bottom Bracket
    Seat Post
    Head set
    rear hub? The Rip 9 RDO is 12x142 (1st gen Jet 9 RDO is 135)
    Quote Originally Posted by cytoe View Post
    Hi cytoe... I already have a wheelset (shown in my original post in this thread)... I don't think that would apply?
    The Jet9 RDO (v1) used 135 rear spacing. The Rip9 RDO use 12x142 rear spacing. I think Easton has a conversion kit...
    Excellent! Thank you Cytoe, I'll look into that!
    New question here. Anyone know if it's possible to get a black Float?
    My current bike I run the Float and love it, I would like to continue running the Float on the new RIP however, I want to go with the 140mm. I wonder if Niner or Fax would offer a "black" option for the Float, since white "will not" work with the blue/black RIP theme ( I realize Talas comes in black however, don't like the Talas as much).
    It would suck to have to strip the brand new Float fork and powder coat it, id rather not if i don't have to.
    I assume it's not possible to order a Talas with Float internals??? In a perfect world
    Carbon & Ti rule
    Forget the Fox, Order a Rockshox 35mm Pike in 140mm travel.
    You really think the Pike will perform better than the Float or Talas? I'm asking because my Talas has been good to me so far.
    Do you happen to know the weight? Can't imagine better than the float!
    Jun 2010
    Pike 2013:
    MODEL: RCT3
    WHEEL SIZE: 26, 27.5, 29
    WEIGHT*: 26 1835g (4.05 lb), 27.5 1861g (4.10 lb), 29 1876g (4.14 lb)
    TRAVEL: 26/27.5 150mm, 160mm; 29 140mm, 150mm
    STEERER:Tapered only
    AXLE: Maxle Lite 15mm
    ADJUSTMENTS: External rebound, low speed compression, 3-position compression (Open/Pedal/Lock)
    SPRING: Dual Position Air, Solo Air
    CROWN: Forged, hollow 7075 Aluminum
    LOWER LEGS: Magnesium, disc only
    MAXIMUM ROTOR SIZE: 200mm
    COLORS: Black, White
    MSRP: $980-1085 (878-949)
    New question here. Why is the Pike better than the Float or Talas?
    Hey Muzzanic... Pike with NO Kashima coating, both seem similar as far as internals , why is it better?
    ... other than it's a tad lighter and it comes in black
    Talas 140 4.6 lbs
    Float 140 4.49 lbs
    Pike 140 4.14 lbs
    Float 130 9.96 lbs (Rally Blue)
    The oh so cool looking Revelation RCT3 in BLUE is only 130mm travel, why didn't they go 140 on that??? Lame
    Talas 140 4.6 lbs
    Float 140 4.49 lbs
    Pike 140 4.14 lbs
    Real low speed compression, bigger stanchions, (probably) a better damper, lower stiction. Kashima is overrated. The Rock Shox forks I've used, all with normal anodized stanchions, were noticeably smoother than the Fox forks I've used. I have a Float 34, and it's not a bad fork, but the Pike seems better in every respect.
    Carbon & Ti rule
    The Pike is lighter,has 35mm legs not 34 & I have heard very good things about the damper.
    The Pike is ment to ride higher in its travel to.
    My friend has a Fox 34 on his 1st Gen Rip9 ( Talas ) & although its a nice stiff fork, I didn't feel much stiffer than my White brother Loop & don't feel the damper is as nice as My RCT3.
    I'm sure the Float is better than the Talas, But The pike looks like it offers a lot of what I like.
    As for the Blue 130 RCT3, Well 1st up I have tended to swap out forks a lot & the Blue would limit who I could sell it to & wouldn't go with any of my other bikes.
    Until I got the Rip9 RDO, I couldn't see why you would want to put on a 130 fork.
    I was thinking if you aren't putting on a 140mm fork build a Jet9 RDO.
    But then I wasn't thinking the Rip9 RDO would pedal like a fast XC bike.
    Now I think that if I was to race a 6 hour event, a Rip9 RDO with a shorter fork might be my choice over the Jet9 RDO.
    Talas 140 4.6 lbs
    Float 140 4.49 lbs
    Pike 140 4.14 lbs
    May 2012
    Buy the 130MM and change it to 140MM. 10 minute job. Solved.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Quote Originally Posted by PeopleForScience View Post
    I didnt know you could do that. That would keep the weight down as well I assume
    Also... Someone brought up a good point about resale.... best to go with a black or white that would appeal to more people
    Hi everyone. I am also facing this dilemma. RIP or JET. Factors include: im 6'-4" 215lbs, committed to XL frame. Currently I ride an all mountain hardtail (Banshee Paradox) XC stans wheels, Fox Float 120mm fork, with very slack geometry (probably too slack for my interests frankly) For cost reasons I want to first look at stripping this bike and building up a new Niner Jet or Rip, so the 120 fork will work with either. My local bike shop is pushing me toward a RIP, saying the JET will be too twitchy and the RIP will fit my riding style better. I am not a racer, but also not a DH extremist either. In some ways they might be right. BUT I have an angle on a closeout JET9 RDO which is very affordable. And looking at the numbers, with a 120 fork the geometry is virtually identical. What do you all think? Will the JET be a good trail bike, or is too racy? Is my weight a factor, will i break it? Im i better off biting the bullet and getting the RIP and buying new burlier parts and a longer fork? Thanks!
    Carbon & Ti rule
    1st up I have never found the Jet9 RDO with 120mm fork to be twitchy.
    Set up right the Jet9 RDO can be quite a good trail bike.
    For me the only problem I found with the Jet9 RDO is on sharp rise jumps that the rear of the bike flicked up a little harder & you have to use a little more body English to stop it coming down front wheel 1st.
    That said, I like the Rip9 a bit more over the Jet9 RDO, Because I like trails that are a little ruffer.
    The Rip9 gives up very little to the jet9 RDO with a similar build on the climbs & XC type trails.
    With the Rip9 it is much more care free on the down hills & much easier to push your limits.
    At your height & weight I think that the Rip9 would be a better bike for what you are looking for.
    Quote Originally Posted by ixxyquick View Post
    Reputation: HouseNotes's Avatar
    Listen to your local bike shop! If they truly know your riding style they know what is best. I had the good fortune to be able to ride with the owner of my LBS & he steered me towards the RIP RDO. I'm not a racer and like to go "straight line" thru the burlier stuff. Ride lots of rocks and roots and I couldn't be happier. P.S I was previously on a Jet 9 RDO!
    Single Track Rules!
    Sep 2012
    Looking at Jet 9 Carbon but was waiting as I think I'd like the 15' model. Just not sure as I have no dealers near me. I did ask Niner when the 15's would be out as it seems dealers don't have them yet. Per email from Niner this morning I was told they just received the first run of Jet 9 Carbon frames and they will start shipping them within the next week.
  1. Bottom Braket Question, yet another pf30 vs bb30 question.
    By ntm1973 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-21-2013, 09:30 PM
  2. Replies: 4
    Last Post: 11-06-2012, 04:02 PM
  3. Replies: 4
    Last Post: 02-07-2012, 07:10 PM
  4. iBis HD owners.. i have a question..(noob question)
    By superunknown222 in forum Ibis
    Last Post: 08-07-2011, 09:59 PM
  5. Forest City Trails Question: Sandusky Question?
    By bycyclist in forum California - Norcal
    Last Post: 07-26-2011, 11:43 AM
