Results 1 to 3 of 3
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    Question for Jet9 Dropper Post users
    I've been searching around for a dropper post (getting into a couple of Enduros this year), and I've run into a little bit of an issue with finding one to fit my Jet9 Carbon. Because of the bend in the seat tube, the longest post I can use for my seat height is 370mm (I just cut the bottom off of a Thomson now), but that's not really an option with droppers since the inner workings are where I'd be cutting.
    Anyone run into the same issue? To complicate matters, I need an offset post.
    The best option I've come up with so far is to get a Specialized Command Post in the 380 length, but just switch between the "cruiser" middle setting (35mm down) and the fully dropped setting (a difference of 65mm). It's not a huge drop, but it'd definitely make a difference to me given that I'm accustomed to going at everything with a normal seat height.
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Why so short ?
    My wife has a Reverb. 355mm long with 4 inch drop to give her a seat height of 660mm from the centre of the cranks to the top of the seat inline with the seat post, One her small Jet9 RDO.
    Not a set back post I know, Just trying to work out the length.
    What seat height are you running & what frame size ?
    I often only use about 50mm drop on my set & even that can make a big difference.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Oops... meant to say 370mm, not 270. Changed it in the OP
    My seat height is 675mm when measured the same way. Small frame
  1. Dropper Post Question
    By Huntro in forum Yeti
    Last Post: 03-20-2013, 02:35 AM
  2. Newbie dropper post question
    By dwt in forum All Mountain
    Last Post: 08-28-2012, 12:12 PM
  3. Post your 2010 Jet9!
    By Andrea138 in forum Niner Bikes
    Last Post: 10-16-2011, 10:12 AM
  4. Dropper post question...
    By Miker J in forum 29er Bikes
    Last Post: 08-03-2011, 08:14 AM
