Results 1 to 5 of 5
    Reputation: brightsky's Avatar
    Dec 2008
    PF30 Bottom bracket options for GXP cranks
    I have a 2012 Jet9 RDO on the way
    I plan on running some old GXP cranks on it.
    What is my best option to get these cranks to work on the PF30 frame.
    Reputation: manwithnoname's Avatar
    Apr 2005
    For your GXP cranks your best bet is to run a PF30 to English Thread Adapter like the one here - Sram PF30 to English Thread Adapter and then run a standard GXP bottom bracket.
    But, if you want to take full advantage of the PF30, I'd go with a PF30 bottom bracket and pick up a BB30 crankset off ebay for cheap. X0's can be found for around $200. If you go this route I recommend the FSA PF30 BB over the SRAM, it is much better.
    Dec 2008
    If I go with the threaded adapter, am I stuck with it? Can it be removed from the frame later without damage?
    Apr 2005
    You can remove it without damage to the frame, but the adapter might get a bit hammered. its basically just plastic.
    Dec 2008
    Quote Originally Posted by manwithnoname View Post
    Cool, thanks for the info.
    Anyone here running one of these adapters? Any issues?
    I really want to get some BB30 cranks, but I promised myself I would keep this build on a budget and reuse the components I already have.
