Page 4 of 5 FirstFirst 12345 LastLast
Results 301 to 400 of 474
  1. #301
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by KTMwoodsrider View Post
    Much appreciated enthusiasm!
    I did buy a front fork for the bike. After a lot of investigative reading on forks and a great price that I could not match with another brand, I bought a manitou tower pro 100mm fork. I read an interview on twentynineinches.com where the chief engineer talked about the company. Two things impressed me and was half the reason I bought the fork. One was customer service and the other was rider adjust ability with shimming the fork. The other half was price! I need to buy cranks, which I would like to get XO1, seat post(still thinking), stem and bars. From the money I saved on the fork, I can spend on the cranks.
    As yourdaguy stated, I too am amazed that this frame will hold up to my riding. However, I don't have any jumps or big drops in our riding or racing courses. I have a friend who broke is specialized carbon stumpy, then a S works replacement frame last year. Specialized upgraded him to a epic at a replacement price and told him this was the last bike frame he would get from them! Cant blame them. Not sure what happened but he is an aggressive rider that is not to smooth.
    I wouldn't buy X01 cranks, Because the spider is bigger bolt circle than the XX1 & will only go down to 30 tooth chain ring.
    Were as the XX1 can go down to 28 tooth Chain Ring, Sure you may not need to go that low but it is nice to have that option.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
  2. #302
    Reputation: Acko's Avatar
    Feb 2014
    Quote Originally Posted by muzzanic View Post
    What gradients are you riding a singlespeed on that you need a chainring smaller than 30t?
  3. #303
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by Acko View Post
    Somebody we know has just ordered a 26t for sand dunes.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  4. #304
    Feb 2014
    Quote Originally Posted by ozzybmx View Post
    Not singlespeed though?
    And in that case, you can go the direct mount chainring route with that crank and ditch the spider anyway
  5. #305
    Fat & Single
    No XX1, i still reckon its a bit low, my max is about 42kph 30:11 on 1x10.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  6. #306
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    Trail Blaze Yellow SIR 21.07 lbs.
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
  7. #307
    Mar 2014
    Here is mine.
    Large frame.
    Fox teralogic
    Easton carbon bars
    Thomson stem
    King headset
    Formula RX brakes / formula rotors
    XX1 crank with a 32 direct mount bling ring
    XTR pedals.
    Hope hubs laced to light bike 35mm wide rims.
    Schwalbes front and rear set up tubeless
    NIner RDO seat post. Won't ride a hardtail without one.
  8. #308
    Feb 2014
  9. #309
    Scandium One 9 at 17 lbs. Still haven't been able to ride it because it's been raining for a week.
  10. #310
    my bike gained weight
    Reputation: MrBiggs's Avatar
    Jun 2005
    DAMN. 17! I'm impressed. My Scandium is between 22 and 23 depending on how much water is in the bottle. Of course I'm running a five-year-old RockShox fork. But that would still not get it below 20.
    The snow has finally departed Philly. I took the One9 out last night for a hard 9 miles with 1500' of hills and the bike felt like it, um, gained some weight over the last two or three months...
  11. #311
    Feb 2014
    Quote Originally Posted by Bwick84 View Post
    Sounds like perfect SS weather to me
  12. #312
    Dec 2012
    I am working on finishing my air 9 carbon build 2013 model. I have a question on the BB. I am running the Ebb II with a Hope BB for a SS set up. XX1 cranks with AB spiderless chainring. Am I suppose to use the spacers on the hope BB? If yes, which side and how many? Thanks. I am planning on posting a picture when I finish it. Need to get a couple more parts.
  13. #313
    kgraham11
    Reputation: kgraham11's Avatar
    Jan 2005
    The A9C BB shell width is 73mm with CYA inserts or EBB installed. Install your BB per Hope instructions for that size shell (should be 1 spacer on the drive side).
    I've got the same frame on the way for geared setup. Can't wait!
  14. #314
    Unfortunately, our trails (Boise) have a lot of clay and riding when it's muddy really tears them up so we try not to ride much when it's been raining a lot.
  15. #315
    Feb 2014
    Ahhh that sucks!
  16. #316
    Finally finished tweaking details on mine:
    Frame: RDO
    Fork: RDO
    Wheels: Stan's ZTR Crest, Ikon 2.35 front, Ground Control rear
    Cranks: modded M960s
    Brakes/rotors: Formula R1
    Bars: Niner carbon w/ Ergons
    Stem: Thomson Elite
    Seatpost: RDO
    Pedals: XTR SPD
    Bell: Spurcycle (and yes, it's an awesome, made in the US bell).
    Weight: no clue, (I don't have a scale) but it feels pretty light!
  17. #317
    Bicycle Addict
  18. #318
    Jan 2013
    Has anyone tried running a Beer Components or other eccentric BB on the new Air 9 frame at all and does it work?
    I was going to go for a One 9 but since Niner have shuffled the range around they seem to have discontinued the One 9 and now only do a One 9 RDO which bumps the price up from 820 to 2100
  19. #319
    Jan 2013
    It will work on the Aluminum Air 9 but not on the carbon Air 9. The new A9C is basically the same mold as the old air 9 RDO so it doesn't have the aluminum reinforced bb area.
  20. #320
    4 Niners
    Dec 2008
    I have an Air9 and the Beer adapter. I was originally going to use the adapter rather than buy the Niner adapter and the SRAM adapter since I was going to start running it geared but wanted to be able to convert to SS. I put everything in loosley with the 3 ring crank I was going to use and found that there was a very small range of movement with that big ring on there before I would be hitting the chain stay with the big ring. I took everything apart and went the other way. If you are running SS and stick to 34 tooth or smaller, I would think you would be fine. I love the Air9 by the way.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  21. #321
    Jan 2013
    Thanks for the info guys, it's the aluminium Air 9 that I'm interested in.
    I've just received a reply from the Niner distributors after I emailed them, there response was that an S.I.R. or ROS would run singlespeed, not really that helpful!
  22. #322
    Reputation: vick's Avatar
    Official Niner Single Speed Thread
    My new Air 9 Carbon single speed . Got the frame on close out from Competitive Cyclist and got Arches w/I9 hubs built by Dave at Speed Dream. Didn't weigh it but it rides pretty damn nice, looking forward to putting some miles in on it.
  23. #323
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    Rootbeer classic SIR9 on blue
  24. #324
    kgraham11
    Jan 2005
    Godzilla Green One9. It took me awhile to find that fork...
  25. #325
    Jun 2005
    Nice!! Godzilla Green! I have the same frame. When I bought mine used, the eBay dude said it was Moondust, but that never seemed quite right.
    I've thought about putting on of those nice Niner forks on it for racing and just assumed I'd get black. It looks great with the matching color. Where did you end up sourcing the fork?
  26. #326
    Jan 2009
    Quote Originally Posted by kgraham11 View Post
    Official Niner Single Speed Thread-dsc_0461.jpgOfficial Niner Single Speed Thread-dsc_0440.jpgOfficial Niner Single Speed Thread-1867.jpg
    I had a Godzilla Green SIR 9, bought it used. Now I have a Rootbeer SIR 9, bought it used as well. I also have a Rootbeer EMD 1x9. LOVE my Niners...
    "...quit hitting me with your hammer"
    www.msmtb.org
    Niner EMD 1x9 ~ Niner SIR9 SS
  27. #327
    kgraham11
    Jan 2005
    Quote Originally Posted by MrBiggs View Post
    Scored it on ebay last week from a gentleman in Boise. Oddly enough, I tracked down the frame last year on Craigslist from a different guy in Boise.
  28. #328
    Here's my A9C, 18 lbs of loveliness! Maiden voyage today.
    Crossmax SLR's
    Racing Ralphs
    Modded M960 Cranks
    Carbon, seatpost, bars and stem
    I can't wait to try it out!
    Quick question for those running the Bio-Centric 2. I just installed a brand new one in this bike, but did not put any of the Carbo spray or teflon tape because I thought I recalled seeing a reco to use these dry unless riding in extreme wetness. I couldn't find the thread where I saw this.
  29. #329
    4 Niners
    Dec 2008
    I would follow the instructions on the Niner site. I have had spotty results running them dry. Although I have had less problems on my Sir than the carbon frames with aluminum insert.
  30. #330
    Jun 2005
    I didn't read a question, but I assume you're asking if that's okay to run without the Carbo? I think it's Niner itself that recommends the Carbo only if running dry causes noise or movement. So I think you're right.
    However, I've never run dry. I bought Carbogrip when I got the BioCentric2 and I've never had any problems in a year, with a lot of winter riding on my SS.
    Might as well ride the thing and if you notice any issue, order some Carbogrip. Have fun. Looks great.
  31. #331
    i talked to a Niner Demo guy 2 days ago. He said they now recommend dry
  32. #332
    Jun 2014
    ...NINER Build (almost finished!!!) (need 140 mm rear rotor)
    NINER Build
    Niner S.I.R. 9 White Frame - S.I.R. 9 - 2,730g
    Niner RDO Carbon Fork - NINER RDO FORK - 630g
    Niner RDO Seatpost - Niner RDO Seatpost - 210g
    Shimano XTR Disk Brakes - Shimano XTR BR-987 Race Brake | Competitive Cyclist - 244g
    Shimano XT- Saint Ice-Tech Disk Rotor 180 mm - Shimano XT SM-RT86 Rotor - 6-Bolt | Competitive Cyclist - 155g ea.
    Shimano XT Cranks - Shimano XT Dyna-Sys FC-M785 Double Crankset | Competitive Cyclist - 700g (est)
    RaceFace 34t Chainring - Race Face Single Non-Shift Chainring | Chain Reaction Cycles - 42g
    Kick Ass Cog 17t - Endless Bike Company | Anodized Kick Ass Cogs - 30g / 20g spacer
    Easton Lock-On Grips - Easton Lock-On Grips | Chain Reaction Cycles - 115g
    Easton Haven Stem - HAVEN | Easton Cycling - 145g
    Easton Haven Carbon Riser Bars - HAVEN CARBON | Easton Cycling - 186g
    Easton Haven Carbon 29 Wheels - HAVEN CARBON 29" | Easton Cycling - 1590g x2
    Deity Compound Pedals - deity Compound Pedals - 339g
    North Shore Billet 180 mm Adapters - Post Mount Disk Brake Adapter | North Shore Billet
    KCNC Stem Spacers - KCNC Hollow Headset Spacers : Fairwheel Bikes, Cycling Boutique
    Official Niner Single Speed Thread-photo-1.jpgOfficial Niner Single Speed Thread-photo-2.jpgOfficial Niner Single Speed Thread-photo-4.jpgOfficial Niner Single Speed Thread-photo-5.jpgOfficial Niner Single Speed Thread-photo-11.jpgOfficial Niner Single Speed Thread-photo-22.jpgOfficial Niner Single Speed Thread-photo-44.jpgOfficial Niner Single Speed Thread-photo-55.jpgOfficial Niner Single Speed Thread-photo-111.jpgOfficial Niner Single Speed Thread-photo-222.jpgOfficial Niner Single Speed Thread-photo-333.jpgOfficial Niner Single Speed Thread-photo-444.jpgOfficial Niner Single Speed Thread-photo-555.jpg
  33. #333
    Carbon & Ti rule
    Nice bike, I like it.
ID:	903258Click image for larger version.
ID:	903259Click image for larger version.
ID:	903260Click image for larger version.
ID:	903261Click image for larger version.
ID:	903262Click image for larger version.
ID:	903263Click image for larger version.
ID:	903264Click image for larger version.
ID:	903265Click image for larger version.
ID:	903266Click image for larger version.
ID:	903267Click image for larger version.
ID:	903268Click image for larger version.
ID:	903269Click image for larger version.
  34. #334
    Aug 2013
    Stopped at FATS on the way home from Folly Beach and took my raw scandium one9. Man, I wish Niner would bring back the scandium. Since they're hard to come by these days I picked up a backup one9 in green 'just in case'
    Attached Thumbnails Attached Thumbnails Official Niner Single Speed Thread-image.jpg
  35. #335
    4 Niners
    Dec 2008
    I have a medium scandium One9 I need to sell since I built an Air9C.
  36. #336
    Feb 2005
    Wider rims
    Quote Originally Posted by McGill View Post
    Here is mine. Large frame. Fox teralogic Easton carbon bars Thomson stem King headset Formula RX brakes / formula rotors XX1 crank with a 32 direct mount bling ring XTR pedals. Hope hubs laced to light bike 35mm wide rims. Schwalbes front and rear set up tubeless NIner RDO seat post. Won't ride a hardtail without one. Click image for larger version.
    I just switched out my rims to the Velocity Blunt35s and I have a Nobby Nic 2.3 up front and a Racing Ralph 2.2 on the rear. Wider is Soo much better. I've had the Mavic 729s on my FXR for years but wide on a 29er makes your bike seem like it will stick to walls. The guys at twentyniner.com said the AC Wide Lightnings wouldn't fit on the ROS 9 but with my Sir9 I could easily fit my 35ers with most 2.3's maybe a 2.4. I know it two different frames but I don't think the spacing is that narrow. Do yourself a favor and get wide rims. Stan's flow EX or wider but you'll notice the advantages right away.
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
  37. #337
    May 2010
    Here's mine. But due to recurring foot problems, I'm converting it back to geared.
    Official Niner Single Speed Thread-10537382_10152280159222568_8470721053716001552_n.jpg
    Frame: ROS9 (med)
    Fork: RS Revelation RCT3 140mm
    Bar: RF Atlas 785mm
    Stem: RF Atlas 50mm
    Seatpost: RS Reverb Stealth 125mm
    Saddle: WTB Rocket V
    Brakeset: XT w/ 180mm rotors f&r
    Crankset: XT
    Pedals: XT
    Chainring: RF NW 32t
    Cog: CK 18t
    Wheelset: Hope/Flows
    Tires: CM front, HD rear
    Weight: No idea, have not weighed it. Guesstimate, somewhere around 27#s
  38. #338
    Reputation: quelocotony's Avatar
    Nice Rig! Be sure to post up final specs & complete build weight!
  39. #339
    May 2010
    Quote Originally Posted by quelocotony View Post
    Thanks! Edited my post with specs
  40. #340
    Reputation: boomvader's Avatar
    Nov 2006
    Good job! New steed in the stable...
    Moondust A9c rigid!!
    Attached Thumbnails Attached Thumbnails Official Niner Single Speed Thread-img_2923.jpg
    -boom
  41. #341
    Jun 2005
    I've been loving my One9. It's an old 2008 frame, however, and I'd like to upgrade the bike over the winter with new wheels and fork, and move to the 142x12 and 15mm hubs while I'm at it. I like the steel frame of the Sir9, but boy am I bummed by the color choices of white, red and that goofy fluorescent yellow. Boy I'd like to have one of the newer Sir9 frames in Moondust. I wonder how much it would cost to have one powder-coated...
    (Also, is it weird that the newer One9's seem to be geared bikes? Isn't that an Air9? What's the point of that?)
  42. #342
    Wow... I think this is my third contribution to this thread! Needless to say, I like Niner SS bikes
    Have since tossed on some black ESI chunky grips, just didn't have them for the shakedown ride and the Ergons go on quickly
    I'll post a pic with the matching blue carbon fork up when I get a chance.
    Official Niner Single Speed Thread-10703501_10102454195000489_3451023314867746854_n.jpg
    Official Niner Single Speed Thread-10421626_10102454195075339_9162556555642238720_n.jpg
  43. #343
    Nov 2006
    Good job!
    Quote Originally Posted by briscoelab View Post
    Awesome. I really love that frame! Was going to go that route with a new SS build until a lightly used Air9c fell into my lap! It was too good of a deal to pass up.
    -boom
  44. #344
    Jun 2005
    My beloved One9 SS was stolen off of my porch two weeks ago. Thief with bolt-cutters. So now I'm trying to figure out what to do as I plan a new (sigh) singlespeed.
    I have a geared Ros9, and my first inclination was to start with a Sir9 frame. But I'm just not into these colors that Niner is painting the Sir9 right now. White, bright red, and that bizarre fluorescent yellow are not really anything I want to ride around on (though if I found the red or white used, I'd probably change my mind). AND they don't make the One9 anymore except for the incredibly expensive but gorgeous RDO version.
    So I feel kind of like a turncoat as I look at Chumba's Stella and Ibis' Tranny29.
  45. #345
    Aug 2013
    Sorry to hear that. I can relate after having my one9 stolen last year. I have a Moondust gray SIR9 medium frame set if you're interested.
  46. #346
    Jun 2005
    Thanks, that Moondust is nice. But I'm a large. I'm also kind of in love with the 142x12 and 15mm hubs these days, though putting together a traditional QR set-up with used parts might be in the cards until I spring the $$ for a newer set-up.
  47. #347
    Aug 2013
    142x12 is the way to go. I updated my SIR9 and Air9C to the One9 RDO because of that.
  48. #348
    Jun 2005
    That One9 RDO at $2149 is $500 more than the Ibis and $1000 more than the steel SS frames I'm looking at. I just can't see where it's so much better, especially against the Tranny 29, which is also carbon-fiber. Any thoughts?
  49. #349
    Aug 2013
    One9 RDO Build
    Finally.... I've been building this setup for almost 2 months and rode it for the first time tonight. It sits just under 18 pounds with current components... worth the wait.
  50. #350
    Oct 2014
    Nice bike, SSATL77!
    I posted this in the Singlespeed forum as well.
    My Niner One 9 RDO. 800kms in 2 1/2 months and loving it. No other bike I have owned has got as many comments and questions out on the trail.
  51. #351
    Sep 2012
    Showing off its 29+ front
    Posted this much earlier on but adding a pic of the latest incarnation...
    My first gen SIR.9.
    Niner steel fork.
    Velocity Dually front with 3" Knard.
    18t White Ind freewheel & Goldtech Wobbly elliptical chainring.
    BB7 brakes.
  52. #352
    Quote Originally Posted by SSATL77 View Post
    Loving the colors on the One9 -- would like to see that color combo in the SIR and RIP.
  53. #353
    My latest -- 2nd Gen SIR 9. White / Gold. This is the 5th SS 29er I've owned and by far my favorite. Everything I loved about my 1st Gen SIR 9 plus so much more.
    Niner SIR 9 - Med
    Arch 29er laced to Industry 9 Gold Hubs
    Ardent 2.4 FR / Crossmark 2.1 RR Tires
    Reba RL Solo Air 100mm Fork w/ Niner Stickers
    RDO Seatpost
    Fizik Tundra2 Saddle
    Thomson Stem
    Titec Pluto Carbon Bar
    King 20TSS Cog
    SLX Crank w/ 32T VeloSolo Gold Ring
    XT 785 Brakes
    Official Niner Single Speed Thread-img_6329-1-.jpgOfficial Niner Single Speed Thread-img_6333.jpg
  54. #354
    Carbon & Ti rule
    Nice bike.
    Niner SIR 9 - Med
    RDO Seatpost
    Thomson Stem
    King 20TSS Cog
    XT 785 Brakes
ID:	946920Click image for larger version.
  55. #355
    Nice bike.
    Thanks Muzzanic!
  56. #356
    Reputation: KevinGT's Avatar
    Dec 2012
    I'm just finishing up my Niner One 9 build and noticed that none of you install that little chainstay slap guard that Niner includes with their frames. Is it not needed? My current singlespeed is a conversion from a geared bike so I just left the chainstay guard on. With a properly tensioned chain (1/2" movement up or down) is there no way the chain can contact the stay? I'm guess no, seeing as you all have pristine looking chainstays and no guards.
  57. #357
    Jun 2005
    Yeah, SS bikes don't really need them things. I notice little spots of crap on my chainstay now and then. Maybe chain lube or grease or something mixed with mud flinging off the cog? It's hard to get off. But yeah no reason for a slap guard.
  58. #358
    4 Niners
    Dec 2008
    Niner includes it in case you want to run 1x10.
    Tapatalk upgrade sucks. Be sure to rate this bloatware so they fix it!
  59. #359
    Dec 2012
    (repost from SS forum)
    Maiden voyage today. Fantastic bike!
    Niner One 9 hydroformed aluminum, Small
    RockShox Reba RL 100mm
    Bontrager/Vuelta wheels, Geax tires
    FSA carbon bar, Selle Italia Flite, Niner Seatpost, RaceFace stem, Truvativ Crank, Surley cog
    32x20 gearing
    Haven't weighed it yet but I'm guessing it's around 23 lbs.
    Very solid ride. EBB was creak-free, installed dry per current Niner instructions. Need to shorten the hoses, cut the steerer tube another 10mm, and get that god-awful, needless Pushloc thing off my handlebars. Might go with a longer stem but will decide after a few more rides.
    At 5' 6" tall, the Small fit perfectly. I knew it would, having demo'd the Air 9 RDO a couple of years ago. That demo convinced me that, even at 5' 6" tall, I could be very comfortable on a Niner. That's not true for all brands. I demo'd some other brands 29ers that just didn't fit right. That all said, I still prefer my 26" bike but this is a great backup bike and a fantastic SS.
    Felt very fast. Now I'm looking for a spring XC race with a SS over-50 category!
  60. #360
    Jun 2005
    Good luck. Usually SS is just SS. You'll be racing against 25-year-olds. It's weird.
    Nice ride. I bet it's under 23lbs.
  61. #361
    Sep 2013
    What year is your air9, I have the orange and black, but would love to pick up that color ~~ orange / alloy
  62. #362
    Dec 2012
    Quote Originally Posted by cxboy View Post
    Mine? It's actually a One 9 and it's a 2013. Bought it on Cambria Bike about a month ago. Looks like they still have that color combo (Tangerine/Raw) in Small, Large, and XL.
    *hint* use online chat with Cambria to negotiate. I got my frame for far less than their sale price and got free shipping as well.
  63. #363
    I Have a niner one with EBB however, the chain keeps loosening after about an hour ride, I torque the hell out of the hex bolt but still rolls back on me. Any suggestions??
  64. #364
    Aug 2013
    Quote Originally Posted by bigdog100 View Post
    If you haven't done so already upgrade to their 2 bolt EBB and tighten to 12nm. If it still slips carbogrip is pretty good, but don't over spray or it will be tough to adjust.
  65. #365
    So what you are saying is the 1 bolt ebb doesn't work?
  66. #366
    Aug 2013
    I haven't had much success compared to their newer 2 bolt and have replaced mine on the old scandium one9.
  67. #367
    Sep 2013
    Cool...Thx for the tip !! and the bike looks great !!
    Quote Originally Posted by KevinGT View Post
  68. #368
    Reputation: offrhodes42's Avatar
    Joining the Niner SS crowd
    This will be the project over the winter and spring time, so do not expect it to be completed any time soon. Picked a a great deal on a NOS SIR9 frame and will be going fully rigid single speed.
  69. #369
    Dec 2012
    I also had trouble with the single bolt EBB. The 'Oateys' paste didn't seem to help a lot.
    However, I've since upgraded to their double bolt EBB. I use a little carbo-grip & I've had zero issues since.
    As someone else has written above, don't use too much carbo-grip, or it's too tough to adjust the EBB even with the two bolts loose.
    I now have two SIR9's, one rigid SS & the other with gears & squish. I know the cost of upgrading the EBB is annoying + the cost of the carbo-spray, but it's worth it!!!
  70. #370
    May 2012
    Here's my One9. I love it but am thinking about selling it to fund my recent RIP 9 order.
    Has anybody tried to throw a trail stem on one of these? I'd really like to get the bike to be more playful/manualable and I think a shorter stem might help? Probably better would be a dropper post but that goes against just about every other decision made about how the bike was built (it's a hair over 20lbs as is). Worried about regretting getting rid of the thing but I guess I'll just have to see how much I'm impressed by the RIP. I feel like the only one on rides with a hardtail single speed anymore and while I can keep up and hold my own, it's doing a number on my knees and lower back.
  71. #371
    May 2012
    Here's me riding it. After watching this again I dunno if I want to get rid of this thing. For fast flowy trails I really don't think I'd rather be on anything else.
  72. #372
    Jun 2005
    Come to Philly -- there are plenty of us on hard-tail one-gear bikes. The geometry of the One9 is such that a short stem might put you over the front tire in a way that is undesirable. It's an easy swap so you might as well try it, though. Get a cheap Dimension 50mm and if you like it, upgrade.
    As for the dropper, who cares about rules? Sure some purist will bust your balls, but you can laugh as you rip down the hill. It'll add a pound to your very light bike, but big deal. Get a haircut and don't eat that spaghetti. There are lots of ways to shave weight.
  73. #373
    Reputation: socal_jack's Avatar
    Dec 2008
    Recent ROS9 build, really having a lot of fun on this. Handling blows away my RIP9(2010), may have to dump that frame.
    Official Niner Single Speed Thread-5724f5ab-7fbd-491b-b491-ec8c459945d3_zpsu3r8mcxl.jpg
  74. #374
    Carbon & Ti rule
    Cool bike.
  75. #375
    Dec 2008
    Cool bike.
    19 lbs of ass kicking fun!
    Attached Thumbnails Attached Thumbnails Official Niner Single Speed Thread-img_2111-3-.jpg
  77. #377
    Aug 2005
    Air9 Alloy, Beer EBB, buncha OE parts recycled off my Jet 9. Fun stuff, will probably pick up a Reba to lose a pound off the front end at some point.
  78. #378
    My SIR9 gained a little FAT this summer. Here's my SIR Fatty SS B+ Experiment... ride report to follow.
    Official Niner Single Speed Thread-fullsizerender-2-.jpgOfficial Niner Single Speed Thread-fullsizerender-5-.jpgOfficial Niner Single Speed Thread-fullsizerender-3-.jpg
  79. #379
    Nov 2012
    What did that end up weighing? Im building mine out very, very similar. Also, what seat post is that?
    Thanks! And it goes without saying, but... Nice ride!!
  80. #380
    Reputation: chris1911's Avatar
  81. #381
    Reputation: coke's Avatar
    Really enjoying my new one 9. By far the best cornering and climbing bike I've ever ridden.
  82. #382
    Let's make it 3 in a row
  83. #383
    Aug 2015
    "My SIR9 gained a little FAT this summer. Here's my SIR Fatty SS B+ Experiment... ride report to follow."
    Hey there quelocotony, Really keen to hear how this project is going - I have just bought a Sir 9 and am running a Lefty, about to build SS specific wheels and thought 27.5+.
    Keen to hear your thoughts. Are they 2.8's front and rear? Are you running SS specific Hubs?
    Cheers,
  84. #384
    I decided to give rigid a try
  85. #385
    Nov 2015
    So I am for sure buying a one9. Just do not know what size to get and bike has to be ordered. I am 5ft10in. Have a large cannondale trail 29 that seems to fit fine but rode a trek superfly in large yesterday and it seemed huge... any help?
  86. #386
    Comparing the geometry of the Cannondale and Niner, with particular attention to the reach and stack height is your best bet.
    (I usually make spreadsheet that shows the differences)
  87. #387
    4 Niners
    Dec 2008
    I am 5'10 and all my Niner's are medium and fit great. If you get a too large frame there is almost no way to make it work well for you. If you get a frame a little too small then you can use a little more setback and a little longer stem. Also, according to Niner's sizing chart you would be best on a Medium.
  88. #388
    Nov 2015
    Thank you. Just wanted some input
  89. #389
    Quote Originally Posted by Nickhepler2 View Post
    I'm 5'11.
    I had a medium cannondal trail SL 29 SS and never could get comfortable on it. Rideable, but was just a little too small.
    I have a medium niner air 9. It's rideable, but have to expose a lot of seatpost and it feels a little small.
    I have a large niner One 9 RDO and it feels perfect with 80mm stem.
    I'd recommend a large.
  90. #390
    4 Niners
    Dec 2008
    Niner recommends a large for 5 11 too, but he is 5 10.
    Sent from my LGLS990 using Tapatalk
  91. #391
    Quote Originally Posted by yourdaguy View Post
    Well technically I'm 5'10.5
  92. #392
    May 2010
    ross9
  93. #393
    Reputation: plussa's Avatar
    My SIR 9:
  94. #394
    Oct 2010
    Here's my contribution to the thread. I absolutely love this bike. Not sure what the weight is, but I imagine it's below 20lbs. I'll throw it on a scale soon, just for kicks.
    Official Niner Single Speed Thread-2015-12-13-16.40.51.jpgOfficial Niner Single Speed Thread-2015-12-13-16.40.37.jpgOfficial Niner Single Speed Thread-2015-12-13-16.42.01.jpgOfficial Niner Single Speed Thread-2015-12-13-16.40.17.jpgOfficial Niner Single Speed Thread-2015-12-13-16.30.16.jpgOfficial Niner Single Speed Thread-2015-12-13-16.30.07-hdr.jpg
    Attached Thumbnails Attached Thumbnails Official Niner Single Speed Thread-2015-12-13-16.29.59.jpg
  95. #395
    18.5 lbs of SS Nirvana, likely the best carbon SS machine on the planet!
    Official Niner Single Speed Thread-imageuploadedbytapatalk1450652945.973007.jpg
  96. #396
    Pretty stoked... I had my Air 9 RDO up for sale after building up a Jet 9 RDO and finally said screw it, I'm going to build it up as SS (the Air)... No pictures as yet, as it will hopefully be complete by the spring, but I just made a sweet deal on an RDO fork! So frame, fork, crank, bars and pedals are done, I already have a rear wheel so shouldn't be too hard to find a front although if Santa decides to give $$ instead of presents then the front wheel will be next.
    Think I may go with an Absolute Black SS Cog... Decisions, decisions!!!
    Somewhere lost in the Bush!
  97. #397
    I just picked up a Air 9 carbon and I'm looking to make it a single speed. How do you get the chain so tight with vertical dropouts and no tensioner?
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
  98. #398
    Quote Originally Posted by Lenny7 View Post
    You get one of these: Niner BioCentric II
  99. #399
    As Dolface said... watch the video on the page (it scrolls through) it explains it. You will still need a threaded BB insert depending on your crank. For quite a while I thought all I needed was the Biocentric II till I watched the video and now it is clear as mud!
    D
  100. #400
    Thanks, do they have threaded bb30 BB's?
Members who have read this thread: 55
