Results 1 to 3 of 3
    Reputation: ToneyRiver's Avatar
    Niner SRAM 11 Speed Hub Question
    I recently bought a Niner Jet 9 Carbon with their 4 Star Build that came with a SRAM X01 11 speed drivetrain. I put another wheel set on the bike and now I want to change the Niner wheel set to 10 speed to put it on another bike I own. Does anyone know of the part to change that rear hub from a SRAM 11 speed to a Shimano 10 speed. Thanks for your help!
    www.mtbiking.ca
    Your Key To The Epic Ride!
    May 2013
    I believe you only need to put a thin spacer on the Niner wheelset cassette body there in order to use it on a 10s drivetrain.
    You're incorrect. If it has an XO1 cassette, then the hub has an XD driver on it. He needs a new freehub body.
    IF it were a shimano 11 freehub, then you would be correct. Just a small spacer would be needed.
    I'd give Niner a call. I'm sure they have the freehubs, since they sell wheels in both configs.
  1. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 08:43 AM
  2. SRAM 10 speed part question
    By dwt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2013, 11:50 AM
  3. 9-Speed SRAM PowerLink on 10-Speed SRAM Chain?
    By mawiv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2012, 05:59 PM
  4. Replies: 2
    Last Post: 10-07-2011, 06:09 PM
  5. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
