Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 140
  1. #101
    4 Niners
    Dec 2008
    Must be a bicycle built for 6.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  2. #102
    HA Hexatandom
  3. #103
    4 Niners
    Dec 2008
  4. #104
    Nice! Sex Bike!
  5. #105
    It's going to be a long night!
  6. #106
    The build may take longer than you think if you enlist the help of your friend Jim there on the back of the workbench ; )
    I love my Kermit MCR
  7. #107
    Haha it will be done sober, maybe a celebratory Stone IPA when it's complete.
  8. #108
    Reputation: JSumner13's Avatar
    Sober build?.......No fun Your frame looks great. Can't wait to see the finished product!
  9. #109
    Large MCR 9
    X9 drivetrain and brakes
    X0 crank
    Thomson Layback
    Thomson 110 -10
    Reba RLT 15mm
    Fizik Aliente Gamma
    Niner Flat Top Carbon
    King Headset
    Stan's Flows on Pro 2 Evos, rear Hope Skewer
    2.25 Ardents tubeless
    Still need to tune it up and set the fork up.
    Recommendations for bottle cages please!
  10. #110
    4 Niners
    Dec 2008
    https://www.google.com/webhp?sourcei...=1685&bih=1118
    Velocity bottle cages. Weigh around 30 grams and cost between $2-8 depending where you buy and hold bottles extremely well and are almost indestructible. Also they come in many colors although the green one doesn't match up with Kermit a Red/White/Black would look good on your bike.
  11. #111
    Oct 2011
    looks greta. i'm a fan of the specialized rib cages.
  12. #112
    4 Niners
    Dec 2008
    Actually, with the White:Ardent, Niner, Fork, Seat. I think the white one would really coordinate well on your bike.
  13. #113
    To anyone running SRAM cranks, are you using the spacers in your bottom bracket? Instructions say not for 73mm BB but I still have a slight wiggle in the crank.
  14. #114
    4 Niners
    Dec 2008
    Sounds like your bb is not exactly the right size or maybe you are getting bad info about it's size so I would stick a spacer in there and see if it solves the problem. If it is a 68 you should actually stick 2 spacers in there.
  15. #115
    To me it reads that if your bike has a 73mm shell you don't use spacers, but a 68 you do use spacers. Everywhere I have looked says the mcr is a 73mm, my measurements tell me the same. I guess I'll put them in and see what happens. BTW it is a GXP truvativ/SRAM BB.
  16. #116
    4 Niners
    Dec 2008
    Is it possible that the first gen MCR had 68 and you have an older frame? But you say you are measuring 73 so that can't be it. I have 3 cranks with the GXP system and no issues. Actually 4 my wife's bike has GXP also. Is the left and right side loose or both sides?
  17. #117
    It doesn't seem to be a side to side slide. Just when you grab the pedal on either side if feels like the bearings are loose in the BB, not a loose crank arm.
    Pics FWIW
  18. #118
    4 Niners
    Dec 2008
    The non drive side looks wrong. Mine there no noticeable space between crank arm and BB. Did you tighten the non drive side bolt to the proper torque? That almost looks like your bearing race is outside the BB.
  19. #119
    Got her fixed, pulled the crank, greased the hell out of it and torqued it to spec which felt tighter than what I was doing with a plain ol' Allen wrench.
  20. #120
    Shook it down yesterday, 24 miles. Definitely gotta dial a few things in before I ride again. Also the damn front dérailleur is walking down the seat tube. Going to try a different derailleur spacer and see if that will fix it.
    Suggestions on what brand of spacers people have had success with would be appreciated!
  21. #121
    May 2012
    It took almost two months to get everything, but finally happened. Upgrading from a 1998 Voodoo Wanga, so it's quite the culture shock. Two words: like butta.
    Size M
    RS Reba 100mm
    XO kit from Niner (came w/ XTR front derailleur) with Formula R1X brakes
    XTR pedals
    Stan's Arch EX wheels and Stan's hubs
    WTB Wolverine Tubeless
    Attached Thumbnails Attached Thumbnails Niner MCR photos/builds-niner.jpg
  22. #122
    Lightly salted
    Reputation: fuenstock's Avatar
    My first 29er. I built it up last night, ready for a weekend ride!
  23. #123
    May 2012
    Looking to build a MCR 9
    What would be the best build while keeping the complete bike price under $3,000?
  24. #124
    4 Niners
    Dec 2008
    mtbcville:
    If you have time to make bids on ebay you can build an awesome bike for $3000. I would spend the money for Stan's Crest wheels and skimp in other areas if going with new parts.
    Other good values in my opinion:
    Cane Creek headsets
    Truvative/SRAM stems
    The Niner aluminum bar (not cheap, but worth the money) Spring for the carbon one if you have money left over.
    SRAM X7 is a very good value
    SRAM Stylo OCT crank This is one step up from the regular Stylo but has really nice bearings.
    as far as chains and cassetts, etc. the lower and middle SRAM groups are the best bang for the buck.
    Salsa lip lock seat clamp is reasonable price and very very good.
    I would get the best deal in hydraulic brakes. They are all good and they are all expensive. You can find deals on ebay all the time on brakes. Even though some are better, they are all good enough.
    I generally recommend the XT front deraileur but am not sure if the new 10 speed stuff is compatible-all my stuff is 9 speed and the XT front works great with SRAM and can be adapted to any size seat tube and top pull or bottom pull. M970-971 depending on the type of swing your frame needs (I am thinking the m970 since that is what I think my Sir needs).
    You didn't say if you were going rigid (Niner Carbon Fork) or Suspended which I assume from the budget that that is the goal. I like the Reba RLT a lot and for a little less $ the Recon Gold and for still less the Recon.
    I would blow the money for the Cannondale Flash 29er seatpost ($175). It is the best invention since sliced bread and makes loads of difference in user comfort.
    Tires, seat, pedals, and grips are personal preference items
  25. #125
    29er
    3k, totally doable
