Results 1 to 2 of 2
    Dec 2012
    Niner Carbon Fork stem torque
    So I recently put a set of Crank Bros bars onto my Niner Fork. Whenever I'm pulling hard on the bars, going up a climb or just accelerating hard, I hear a creaking type noise coming from what sounds like the fork. The stem is clamped to the steerer with 8 Nm. Spec is 9 Nm, but I'm worried about going tighter, because, well, carbon. Am i safe tightening that a little more? Could the sound be from the bar/stem interface instead? Any thoughts at all?
    If you had a pet monkey that knew karate, what would you name it?
    Reputation: herothedog's Avatar
    Tightening to spec should be no problem. In addition get some Fiber Grip and put some on the stem/steerer interface.
    Amazon.com: Finish Line Fiber Grip Carbon Fiber Bicycle Assembly Gel, 1.75-Ounce Tube: Sports & Outdoors
  1. Niner Carbon Fork stem torque
    By NedsDead715 in forum 29er Bikes
    Last Post: 07-10-2013, 07:27 AM
  2. Niner carbon fork - spacer above the stem?
    By trumpus in forum Niner Bikes
    Last Post: 03-01-2013, 08:43 PM
  3. Stem change- torque for the fork cap?
    By Sickmak90 in forum Beginner's Corner
    Last Post: 07-07-2012, 05:47 PM
  4. Maximum torque of stem on Niner carbon fork
    By Ryder1 in forum Niner Bikes
    Last Post: 09-30-2011, 07:25 PM
  5. Maximum torque of stem on Niner carbon fork
    Last Post: 09-30-2011, 03:02 PM
