Results 1 to 28 of 28
    Ride or Die!
    Reputation: CasinoKiD's Avatar
    Niner Air 9 RDO build questions.
    Ok so I just bought a 2012 Niner Air 9 RDO frame and I'm sure I'm going to have a bunch of build questions. My first question is about the headset. I see the Niner site sells a Niner brand headset. Which is the one I need for my frame? I'm not sure if it's the Internal Tapered(zero stack) or Integrated Tapered.
    Reputation: five5's Avatar
    Niner website has an encyclopedia that is super helpful. It will give you all the details you need. Check it out!
    Reputation: knoob's Avatar
    Re: Niner Air 9 RDO build questions.
    Quote Originally Posted by CasinoKiD View Post
    Couldn't wait for the Bronson?
    You have THE SICKNESS!!!!!!
    Ride or Die!
    Quote Originally Posted by knoob View Post
    Bronson is on it's way. RDO will be my XC racer
    headset info on the tech tab here:
    AIR 9 RDO
    Niner has that info for every bike on the site.....enjoy!
    greedy
    Reputation: have2ride2day's Avatar
    Have you unboxed it yet? My frame came with the headset.
    Addicted to the Classifieds
    Ride or Die!
    Quote Originally Posted by have2ride2day View Post
    I have unboxed it and I wasn't lucky enough to get a free headset.
    This might be a dumb question but how do I know what crankset is compatible with a 73mm PF30 BB?
    May 2012
    If it didn't come with a headset then call Niner. They are usually in a small white box.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Ride or Die!
    I bought the frame through Competitive Cyclist. I just checked their ad and it states that it comes with a CaneCreek HS. I just emailed them. Hopefully they send me one. Thanks for the heads up.
    Reputation: chrisgardner73's Avatar
    I'm running XX1 cranks on mine.
    Per the Encyclopedia:
    SRAM recommended 2x chainrings: 26/39T or lower
    SRAM XX1 recommended max chainring: 32T. Q-Factor: 168mm
    SHIMANO XT recommended 2x chainrings: 28/40T or lower
    SHIMANO XTR 2x is not recommended. Both versions (40t/48.8mm chain line and 38t/46.6mm chain line) position the large chainring in a way that it may contact the frame.
    You need BB30 compatible cranks.
    Ride or Die!
    Competitive Cyclist is looking into the missing headset and says they will ship me one as soon as the find out what happened....How about ship out my HS then find out what happened
    greedy
    They will probably have to get one from Niner.
    Ride or Die!
    Next question.....
    I bought an X0 2x10 crankset (BB30/PF30 BB). My whole plan was to use it as a 1x10 using one of those new Raceface Narrow Wide, Wolf Tooth or an MRP Bling Ring. I'm reading that it might be a little more complicated than just bolting on the new ring depending on BB/crank type. Anyone know if the RF Narrow Wide, Wolf Tooth or the MRP Bling Ring would work on my crankset?
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    It should work. Did you get a direct mount ring?
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Ride or Die!
    Quote Originally Posted by J3SSEB View Post
    I haven't bought the ring yet, but it looks like a direct mount ring would be the way to go.
    I am pretty excited, I just got an RDO frame, black licorice, size medium. I want to build it up XTR 3X10. Looking for the best deals on a build kit/parts. Shimano has all these codes for its XTR parts, 980,985, etc. Pretty confusing. Anybody know which number is best for shifters, brakes, F/R derailler for the 3x10 "trail" group? The Niner spec sheet is a little vague for me.
    jimmy
    greedy
    Quote Originally Posted by jimmy View Post
    jimmy
    Check Shimano's website, they give pretty good descriptions.
    XTR
    Bicycle Addict
    Do you guys do anything special to carbon frames before you build them up? I'm going to order my Air 9 Carbon tomorrow.
    greedy
    You'll want some Carbon Assembly Paste for your seatpost.
    Bicycle Addict
    What about in the bottom bracket? Just grease or anti-sieze, or something else?
    greedy
    If it is an Air 9 Carbon, it will have an aluminum insert in the BB shell, so I would put grease in it before installing the EBB, CYA or whatever you are putting in it. If it is an Air 9 Carbon RDO, the BB shell is carbon. I used Carbon Assembly Paste in mine before installing the Bottom Bracket.
    greedy
    I also put a little grease on the outside of the headset races before dropping them in the head tube.
    Bicycle Addict
    Excellent. That's what I was thinking. Thank you for the help.
    Ride or Die!
    Here she is finally built up... 21.11lbs
    Niner Air 9 RDO size LARGE
    Rock Shock Sid XX 100mm
    Stans Arch EX Wheels/hubs
    XO Shifter/
    XO Rear Derailleur
    XO Crank Arms with direct mount Bling Ring (30t)
    Niner RDO Stem (Thomson in pic)
    Niner RDO Post
    Niner RDO Bars
    XX Brakes
    Racing Ralph Tires
    Oct 2013
    what do you think about the bike? positve and negative?
    nice bike. I have one, a 3X10. With a Reba.
    Apr 2013
    I got also a RDO frame, i want to ask you if yours came with some pieces for the cable routing, i see at Niner Encyclopedia that should be some Cable Anchor Shims, Sealead Housing Ferrule and Rubber Seal included, i did not find anything like that, but maybe that is for a newer or older frame. The Front Badge on the picture is different since the one on the file is a black one and on the Bike is a Silver one...
    Reputation: 7daysaweek's Avatar
    Quote Originally Posted by sepoga View Post
    Should be a box in the frame box with some small parts like der hanger and cable stops.
    Head badge should be silver. I think I saw somewhere that the black was preproduction.
  1. niner questions
    By kingair in forum Niner Bikes
    Last Post: 04-01-2012, 11:34 AM
  2. Niner Fork Questions, G
    By jcufari in forum 29er Bikes
    Last Post: 12-30-2011, 12:28 AM
  3. niner build help newbie to build world
    By desflurane in forum Niner Bikes
    Last Post: 12-18-2011, 04:19 PM
  4. Niner - Help W LBS Order Questions Please
    By RLJ676 in forum Niner Bikes
    Last Post: 09-16-2011, 04:05 PM
  5. Niner Cogalicious questions
    By JonathanGennick in forum Singlespeed
    Last Post: 05-28-2011, 01:02 AM
