Results 1 to 64 of 64
    Reputation: dparry's Avatar
    Niner Air 9 Carbon Chainkeeper 1x10
    I have now tried 2 different chainkeepers... the paul components chain keeper and mrp 1.x BB mount... with no luck.
    The Paul mounts too high on the seatube due to the massive BB shell, and the CYA BB insert prevents a standard spacer based BB mount chainguide from working on BB.
    Anybody have any other suggestions, there must be others out there wanting to run 1x9/10 on an Air 9 Carbon?
    I need something that drops a long way down, like a high mount clamp FD
    Niner Air 9 Carbon, 2010 S-WORKS 26" HT/FSR, 2009 Ibis Hakkalugi, 2008 Strange 5 Alpine.
    You could possibly modify a Paulcomp chain keeper - all it would take is a small strip of aluminium and an extra bolt to allow the mount to slide higher up the seat tube. Part of the chain keeper would have to be flipped around (which in itself would raise the clamp a bit) but from looking at it I think it could work. You could get tricky with a MRP, by using part of the existing mount and fabricating a seat tube mount for it...
    I'm waiting on a A9C, and was intending on using the a 1.X, so good to have a heads up on this one!
    yeah, thanks... i'm going to try flipping the paul chainkeeper and see if that works...it might do it... will update tonight. I spoke to Steve at Niner, and said he couldnt believe this setup hadnt been run by the testers, and they may have to look at doing something themselves. not great for me but they were helpful!
    if you have any brain waves, let me know!
    ready to go... except for huge hole where BB should be...... aaargh!!!
    <table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/_smY785B4F4Nsj7w2YSoClVU8M_Scv1MPXzrFIGsGFQ?feat=e mbedwebsite"><img src="http://lh5.ggpht.com/_Bvxl1mfhvmU/TGS5UnH2ZNI/AAAAAAAAML4/4V1e8DNdudI/s400/photo.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/dparry/DropBox?authkey=Gv1sRgCKuo_cy__PapnQE&feat=embedwe bsite">Drop Box</a></td></tr></table>
    Reputation: TheGreek's Avatar
    Quote Originally Posted by dparry
    ready to go... except for huge whole where BB should be...... aaargh!!!
    STILL looks sweet!
    ...which makes it more frustrating not being able to ride it!!!
    30-ton War Machine
    Reputation: edgerat's Avatar
    wont work either.... this has same issue as the MRP 1.x, the CYA insert overlaps the BB, so there is no spacer option here, BB mounts wont work. i am looking at the widgit as they have some in stock and can get to me on monday! i may just get cheap ass FD until then.
    Reputation: CJones's Avatar
    Have you looked at the N-gear jumpstop?
    Sizing is here:
    http://www.gvtc.com/~ngear/orders.html
    yeah, somebody contacted me offline about that one. i really dont want to have run a bash plate and inner catcher...
    Looks like PaulComponents have come up trumps and will have an extended drop chainkeeper on website at end of month.. until then, i'll run a front derailleur. so there is a solution for those 1.x A9C runners. Thanks Paul!!
    dparry - not to derail your thread, but do you think you could post some additional shots of your build? I've got a line on an A9c in Tang and would build it with parts I already own (white fork like yours, white stem, etc.). I'm having a hard time wrapping my arms around how it might look.
    Thanks.
    Have you tried without any retention device up front?
    I used to run my Jet9 as a 1x9 using an X0 short RD and a tight chain (and non-ramped chainring from Middleburn). The chain never dropped in thousands of miles, except in a crash. Was also very clean looking.
    no i haven't thought about that... the renthal chainring is unramped also but XX is long cage der.. i dont fancy risking dropped chain, even with the frame guards on a carbon frame. sure it may work but not for me!... agree, would look clean though. if the Paul solution works, then that will be clean, small, matt black etc..
    sure, will do. i wanted to go all black but dont think the 2011 fox f29 terralogic comes in black. the white stem is a loner till i work out my stem length, then will go back to black... so all black apart from white fork. i'll put some picks up anyway for you. any particular areas?
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    We've got this new iteration of the MRP 1x coming out in a month or so. Its currently in production, shown is a pre-production version. It will be black, but you can get a sense of the overall shape and design. It features a beautiful (and light) aluminum seat tube clamp mount. Any reason this wouldn't work on the Air 9 carbon? I've only admired them from afar.
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Noah, i would think that would also work perfectly!! will the clamp etc be black also?
    stick me down for one ASAP, would be happy to do a review
    in fact if you wanted a pre prod testing would gladly help... i'm busting for a clean solution!!
    Thanks. Maybe just something from the front quarter.
    RLK
    RLK is offline
    What's the saddle? I like the looks of it.
    Nice build
    its very good, a Charge Spoon. very cheap and great value!! frequent winner in UK mags for the budget saddles. i may replace when it wears out.. but its great for now. i find myself out the saddle on this one anyway...
    architectx, does this help?
    Yep! Thanks a bunch.
    Moderator Moderator
    Reputation: driver bob's Avatar
    Quote Originally Posted by NoahColorado
    On your site you don't recommend the existing model with M960 cranks. Will this new version work with cut-down 960's?
    GUIDANCE COUNSELOR
    Quote Originally Posted by driver bob
    Any version will work "cut-down" 960s b/c the issue has to do with that model's spider clearing the guide, but if they're cut down theres no problem. Cheers
    NOAH SEARS
    MRP - Brand Manager
    Moderator Moderator
    Awsome, black will be the only production color offered? That white prototype would be perfect for my new project (an SS / 1x10 2011 Flash 29er Carbon 2)
    GUIDANCE COUNSELOR
    We'll have white and black available, but all clamps will be black anodized. So, you're in luck!
    NOAH SEARS
    MRP - Brand Manager
    Moderator Moderator
    Awesome
    NoahColorado,
    any update on ETA of these babies?
    GUIDANCE COUNSELOR
    Just waiting on the clamps to come back from anodizing...the rest is ready. Soon is the best answer I've got, sorry!
    NOAH SEARS
    MRP - Brand Manager
    OK, thanks Noah!!
    more skier than biker
    Nov 2006
    Would this work? from the The Hive/e-Thirteen: -> http://www.bikerumor.com/2010/09/03/...de/#more-21554
    Kappius Components Ambassador - Ping me a note for a discount code
    yes it would (although its slated to be $99!!). MRP, Paul and ethirteen will have solutions out soon. for me, its who gets there 1st! i'm going to interbike in 2 weeks so hoping i can swipe one there.
    Moderator Moderator
    Keep us posted...
    I'm going to need a chain guide if I go 1 x 10 next year.
    GUIDANCE COUNSELOR
    The MRP will be available to ship later this week. Sorry it took so long! Cheers
    NOAH SEARS
    MRP - Brand Manager
    Reputation: nathanbal's Avatar
    Noah, are you going to email everyone on the waiting list when these are available on your website? will they be available in different online stores as well?
    excellent, looks good!
    Any updates?
    Moderator Moderator
    http://www.paulcomp.com/ckclamp.html
    Nothing fancy but it will do the job.
    driver bob, that doesnt work (i have it!!) it cant sit far enough down the seatube due to huge flaring at the BB shell. Paul is working on one, meant to be out last month but you know how these things are.
    MRP have their solution in now just havent seen how to order. i'm hoping to get one or the other at interbike.
    Underskilled
    Reputation: CaveGiant's Avatar
    I had not realised that MRP was related to white brothers.
    If MRP make it, it is now going on my bike!
    Why would I care about 150g of bike weight, I just ate 400g of cookies while reading this?
    Moderator Moderator
    Damn'it... I'll have to measure my Flash frame (went it eventually arrives) and check back. For the time being the MRP is still the best bet, looks like it will be at least December before my bike arrives so there should be options on the market by then.
    Would the MRP 1X work on the Noir XC 1.1 team crank? It has a bash guard build in. Or should I go with Jump stop by N-gear?
    Reputation: firefighterdirt's Avatar
    bikes are gay, get a job
    GUIDANCE COUNSELOR
    [QUOTE=1max2nv]Would the MRP 1X work on the Noir XC 1.1 team crank? It has a bash guard build in. Or should I go with Jump stop by N-gear?
    You'd have to take the bashguard off and get either siglespeed chainring bolts or bolt spacers, but the 1x works with the Noir just fine.
    NOAH SEARS
    MRP - Brand Manager
    Nov 2007
    dparry, or anyone else have the mrp installed yet? i just ordered it today so i'm hoping this will indeed do the trick
    Moderator Moderator
    Quote Originally Posted by jmalcolm
    Do you have the part number for ordering? I didn't see it on the MRP site when I checked yesterday.
    no, they had them at interbike but i couldnt get my hands on one... very disappointed. especially as i saw some being handed to the Niner guys! I know the ethirteen one works.
    Moderator Moderator
    But at $100
    If the mrp is $49 (same as the exisitng 1X) then I can hold off on ordering.
    Nov 2007
    the mrp was $100 as well. they dont even have a part number yet. i just called mrp directly. just tell them you want the new 1x guide that is made for clamping on higher to the seat post. they only had white in stock which was fine for me. i think i spoke to a guy named Ryan.
    Moderator Moderator
    Ouch.. I know you've got to pay to play but damn, that's one heck of a markup !!
    GUIDANCE COUNSELOR
    Part numbers for the MRP 1x seat-tube mount versions are, 20-9-300 (black) and 20-9-301 (white).
    They're a beautiful piece of kit made with precision right here in our Grand Junction facility. They cost more to manufacture than the BB mount version - thus the higher retail @ $99.95.
    Cheers
    NOAH SEARS
    MRP - Brand Manager
    Nov 2007
    i'm fine with that, as long as it does the job. certainly appreciate the fact that they're manufactured in the USA too. I'll post a review soon as I receive it and get a ride or two with it installed.
    Cheers
    are these available to order now? where can they be bought? i couldnt find them on the MRP website.
    GUIDANCE COUNSELOR
    Quote Originally Posted by nathanbal
    They are available now, I don't think the distributors have gotten theirs quite yet, but we have them in stock here at HQ. You can order directly at 970.241.3518 or contact your LBS and they can order from us.
    Working on a brand new website, so some of our latest products aren't on the current one.
    NOAH SEARS
    MRP - Brand Manager
    Nov 2007
    MRP review
    just switched from single set up to geared and finally put the chain guide on a couple of days ago. two rides with the MRP chain guide in place. Very pleased. First of all, the set up was pretty straight forward. I was about concerned that I'd be tweaking it a bit mid-ride but there was none of that. I also expected to hear some noise. With the 10 gears I'm running in the back that seemed like a wide range for the chain to span w/out any clicking or clanging, but nope, there was none of that either. As you can see in the picture I'm running the Rotor Q-Ring on my XTR cranks. I was a bit concerned that the odd shaped was going to give me fits on the chain guide, again nope. If it fits with that goofy oval, it will fit with anything. Both rides I have on it were pretty bumpy. One was a local trail out here in VA with a lot of roots and smallish drops. The other was a long backcountry-ish, (for me anyway) epic along the Blue Ridge. Basically, the stuff you see in the background of the picture was my ride home. 7 mile downhill with lots of boulders, etc. I thought for sure I was going to throw the chain - I think I would have thrown it with a normal derailleur. Everything held in place just fine. Pretty much set and forget - as they say. The chain guide comes with two rubber shims (one is about 1mm thick and the other is probably 3/4 mm. The MRP won't fit on the A9C with either of those. I ended up just using two pieces of electrical tape as a shim and that worked fine. Barely had to tighten the guide. In fact I could slide it easily up and down to position it and didn't tighten it afterwards and it held in place throughout the rides.
    Attached Thumbnails Attached Thumbnails Niner Air 9 Carbon Chainkeeper 1x10-dscn0443_2.jpg
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Mrp weight?
    Herro prease
    GUIDANCE COUNSELOR
    75g w/o shim, +8g with thickest shim
    NOAH SEARS
    MRP - Brand Manager
    So what's the consensus for the best chain keeper for the A9C?
    I have the E13 seat tube mounted unit and it's OK... way overpriced though and I get a touch of chain rub in the extreme ends of the cassette.
    Nov 2006
    I have used the e.13 and it works great...no issues. Haven't tried the MRP.
    I've gone back to SS though on the A9C (and will be getting rid of my frame at some point in the not so distant future as well) so my 2 month old in perfect condition e.13 guide is for sale if anyone is interested. shoot me a pm
    Feb 2010
    What do you want for the guide, Im going with a 1 x10 set up.
    Reputation: chrisgardner73's Avatar
    It actually will work, but it will require a little cutting. I ran into the same issue trying to run a Paul Chain Keeper on my SIR 9. I doesn't fit the EBB out of the box. I busted out the Dremel, and trimmed the Paul down until it fit the EBB. It worked like a champ!
    I quit using it though and went back to singlespeed. Not because of issues with the chain keeper, but because I'm not smart enough to use a derailluer...
    Feb 2010
    chain guide
    So you are saying that Pauls will work, or will not.
    Quote Originally Posted by Niner Top
    The Paul keeper will work with the Biocentric EBB, but you have to hit it with a Dremel Tool to trim it down a little.
    Attached Thumbnails Attached Thumbnails Niner Air 9 Carbon Chainkeeper 1x10-photo.jpg
