    db9
    db9 is offline
    Minimum seat post insertion - Jet9 Alloy
    I'm riding a 2nd gen Alloy Jet9 (3rd gen - in my mind anyway, being the new one with the 145mm rear triangle )
    Just wondering as I'm looking for a new post - whats the minimum insertion ? just checking as I currently have a 400mm post and one of the options is a 350mm which would give me about 85/90mm in the tube.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    ? They make a Jet9 with 145mm rear triangle.
    Do you mean 142x12 ?
    If you have a 400mm & run your seat high why not use that ?
    How tall are you ?
    What seat height do you run ? What frame size have you got?
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    db9
    db9 is offline
    yep your correct 142x12.. it was late when I posted - sorry
    The reason for a new post is the offset of my existing post - moving the saddle forward has put the clamp at the very back of the rails. The reason for moving the saddle is that I had a fit done and the saddle was moved as part of the fit.
    Me, I'm 6-2, frame is size L, and running saddle at 812mm (I have a long inseam, short torso) though this height is what the fit set it at I do adjust it down depending were I'm riding.
    Carbon & Ti rule
    I would like more post in the frame, So would go 400 or 420mm myself.
    I'm 6 ft & run my seat at 800mm , Ride a Lge frame & use a 420mm post.
    Quote Originally Posted by db9 View Post
  1. Replies: 0
    Last Post: 01-08-2013, 09:31 AM
  2. 2010 5 Spot seat post minimum insertion
    By sik_at in forum Turner
    Last Post: 09-13-2012, 03:40 AM
  3. Replies: 19
    Last Post: 06-06-2012, 11:21 AM
  4. Safire: Minimum post insertion point
    By rzozaya1969 in forum Specialized
    Last Post: 03-20-2012, 08:08 AM
  5. Helius CC minimum post insertion
    By steve_b77 in forum Nicolai
    Last Post: 04-06-2011, 03:25 AM
