Ok - I'm having memory issues.. and my notes that I usually keep in the tool box have moved somewhere and I cant find them..
Any suggestions about rebound settings on my alloy Jet9 (gen2?) or a method on subjectively determining the setting.
Sag is set (front and rear) Fork is Reba XX /20mm axle and +air pressure is 10psi greater than the -ve chamber.
Currently have the rear rebound set 1/2 way and the front 3 or 4 clicks away from full fast..
Feel as the back end is kicking a bit but then the roots are a bit more exposed this year and purhapes I'm faster as I get older (but then probably not )
Hints ?
