Page 1 of 5 12345 LastLast
Results 1 to 25 of 103
Thread: Jet9 RDO woe
    COMBO - President
    Reputation: FASTK's Avatar
    Jet9 RDO woe
    Got my RDO back in January, moved my nearly new Shimano XTR drive train 9sp, triple over and had one good ride so far where the shifting wasn't a complete nightmare. The front derailleur shift is a manual-matic process of moving the shifter, then dismounting the bike to manually lift the chain to the next bigger chain ring.
    The rear dérailleur just ghost shifts constantly, my shop has tried all new cables and housings twice and shortening and lengthening the housing to no effect. .
    I am actively trying to sell my XTR drive train to replace it with SRAM as that seems to work for the other RDO owners in my area.
    Good news is that last night Niner responded that there is a shift upgrade kit available for the RDO to address issues.
    Has anyone had similar issues? How did you fix it? Did you install this kit?
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Bummer to hear the shop wrenches are having trouble with it. My wife's RDO maiden voyage was a rough one but it was entirely down to me cutting the rear housing too short. After I went through and did it right the second time (removed shock, cycled suspension to make sure the housing was long enough but not TOO long) it's been great. Her front shifting has always been perfect. Maybe it's a SRAM vs. SHIMANO issue? It might be that one is more sensitive to setup than the other.
    Hope they get it sorted out for you, sounds frustrating.
    JMH
    AntiHero
    Reputation: Andrea138's Avatar
    I'm gonna go out on a limb and say it sounds like you need a new mechanic and not a new component group.
    COMBO - President
    Really was hoping to hear that this Niner shift kit cured someone's woes with Shimano. Maybe someone could explain what is in the shift kit and what it is going to do help cure the issue.
    I can't be the only one if Niner has created a shift kit. Obviously addressing a real need and a demand.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Quote Originally Posted by FASTK View Post
    Really was hoping to hear that his Niner shift kit cured someone's woes with Shimano. Maybe someone could explain what is in the shift kit and what it is going to help cure the issue.
    What chain are you running ?
    I have found with a KMC chain you have to be closer with your setup or it doesn;t change as nice as a XTR chain.
    But other than that had no problems ( with 4 RDO's ), That said all needed to have the derailieur hanger setup square before I could get nice changing.
    On all bikes I go back after 3 of 4 weeks of riding when things have settled down & reset the hanger.
    I think your luck will change when you get someone good to look at it, If they cant even get the front shifting right there is little hope of them working out the back.
    Also check that the free hub has no play.
    Daniel the Dog
    XTR doesn't work with Niner. Sorry. Please send it to me right away.
    Muzzanic< can you tell me more about aligning the RD as i have not had any problems with my XT set up
    but for a 10 speed it does seem lumpy when changing gears????
    Carbon & Ti rule
    Quote Originally Posted by MTBkid SA View Post
    Maybe the best tool a mtb rider can own.
    With your rear wheel in & done up tite, You undo the rear derailieur from the frame & screw in the tool.
    You adjust the rod in to just touch the rim( I start at the top of the wheel & use the valve stem as my point of reference ), then slide the adjuster unit in towards the wheel, Then turn the tool around the wheel 90 deg & then spin the wheel so that the valve is now at that point 90 deg from were we started ( The reason I allway spin the wheel & check were the valve is, Is because if the wheel isn't stright it wont through out your check ) As you slide the adjuster part of the tool to the rim you will see if the tool tryes to over lap the rim or has a gap.
    Then repeat around another 90 deg & now you will see if the hanger is stright or if it needs a small bend.
    If needed ( & I'm sure it will, you use the tool to bend the hanger little bits at a time ) untill the rod just touches the rim at 0 deg ,90 deg , 180 deg.
    This make any bike change gear so much better.
    Hope this helps.
    trail "cleaner"
    Reputation: AZmtncycler's Avatar
    indeed, one of the best tools available!
    Anytime I've got a shifting/ghosting issue that a simple cable adjustment won't resolve, I break this baby out and 9 out of 10 times, there'll be a hanger to frame alignment issue.
    Quote Originally Posted by muzzanic View Post
    Hope this helps.
    No dabs allowed!
    Reputation: Nickbm3's Avatar
    Hope this helps.
    Excellent advice... Ive had an ever so slightly bent hanger cause issues on my own bike as well as on friends bikes. If you can't do this procedure on your own, I believe most local shops can do it for a low price ($10 around here). Without a straight hanger you'll lose your mind trying to get proper shifting!
    "That's a niiiiiiiice biiike boy! That a Huffy!?"
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Option to an alignment tool... Assuming the rear derailure hanger in question is replaceable (as most are these days), just keep a fresh spare - and whenever your rear derailure gets too finicky swap the old hanger for a new one. If the problem goes away, there you have it.
    Not that I wouldn't like having that nifty gadget. I'm a sucker for tools.
    Carbon & Ti rule
    Quote Originally Posted by Miker J View Post
    Replacing a new hanger with a new hanger isn't going to change anything.
    I'm yet to see a new hanger on any bike be 100 % true to the wheel.
    Keep on Rockin...
    Nov 2003
    Ok...
    I was thinking of when the "suspect hanger" may have been in a bit of a banger. That said, the real tool is likely the best way to go.
    Daniel the Dog
    I bet the cable are run wrong through that goofy cable system.
    I think Andrea and Muzzazinc are right--needs a fresh set of hands to look at it, including cable running. Should be no problems with a nearly new XTR 9sp setup (assuming cables and housing are new). My 2x10 and my wife's 3x10 work beautifully.
    The poster formerly known as 800_lb_gorilla
    Keep on Rockin...
    Nov 2003
    Since I've been riding a RIP I can see Niner knows what they are doing as it's a great bike. However, I think their cable routing is overly complex. Maybe Niner is looking at this thread and will take note. Maybe just running the routing under the bottom of the TT and down the rear seat stays (for the rear der. and brake) would be more direct. Specialized's method of routing everything under the downtube gives the cleanest look but takes more cable and its not the most direct. That method does give the added benefit of allowing the cable to act as sort of "protector" for rocks thrown up at the down tube from the front tire.
    Nov 2007
    On my first RDO ride this weekend the bike was ghost shifting (in the rear) a lot at first. I had pretty carefully cut the housing to a length that I thought would be perfect. But no... it seemed way too short and caused ghost shifting when the suspension compressed heavily.
    Then it just stopped. When I checked it out on the trail I noticed that the little cable inserts that go into the chainstay where the housing enters had slipped out. I shoved a wee bit of the housing loop at the rear derailleur into the chainstay to give more slack under the BB then put the inserts back in to keep the housing in place. It's been good since. With the housing able to move a little it sort of "found" how much slack it needed under the BB.
    Just a thought before you rip the housing out. See if you have any slack to spare at the derailleur and shove it in.
    No idea what this shift kit thing is but I'm curious.
    COMBO - President
    Thanks all for the suggestions, Niner shipped the shift upgrade kit out on Friday, I'll let you know what it is soonest and try to snap a photo too. Shop is now checking RD alignment as suggested here.
    COMBO - President
    Running Shimano's XT chain.
    BTW, I also have a Niner RIP setup with 9sp XTR, it runs perfectly. Its been keeping me riding while the RDO is at the shop.
    Feb 2010
    shifting woes
    I also have been unsuccessful at getting the RD (SRAM X0, 10speed) to swift well on my RDO. I did my cables as per Niner website. I meticulously measured & re-measured the rear housing length and then used the small plastic inserts that "fix" the housing within the chainstay. Result: no ghost shifting, but shifting was very slow & took lots of extra half-shifts to get adequate RD movement.
    My mechanic reworks all the cables, & this time skips using the small plastic inserts on chainstay -- says he was informed that they were not necessary. Results: shifting response is better (not good), and now there is ghost shifting with heavy rear suspension travel.
    Question to others: did you use these inserts that "fix" the housing within the chainstay, or skip this to allow the rear housing to "float"?
    I will have to inquire about this shifting fix kit & recheck RD alignment.
    COMBO - President
    Here the aforementioned Niner RDO shift upgrade kit for my Jet9 RDO. Looks like plastic tube and plastic grommets for the frame holes.
    Won't be installed until later today or tomorrow, hoping and praying for a good outcome.
    29ers Only.
    Reputation: Niner Bikes's Avatar
    Dec 2004
    Ninerds -
    We at Niner appreciate your feedback and input when it comes to our bikes - it is based on this feedback that we have created a Shift Kit for the Jet 9 RDO. This kit is designed to make your bike set up easier by eliminating the need to determine rear triangle housing length.
    This kit includes a 110mm piece of 4mm shift housing and two ferrules that are designed specifically to fit into the chainstay. You will then have bare cable inside the chainstay.
    These kits are ready to send out to anyone that currently owns a Jet9 RDO - shipped on request to your dealer, at no charge. If you do not have a dealer nearby (or distributor if you are not in the USA & Canada), send a self addressed stamped envelope to:
    NINER BIKES
    ATTN: Jet9RDO Shift Kit
    1611 S College Ave Unit 202
    Ft. Collins, CO 80525
    We recommend that everyone with a Jet9 RDO uses this kit, it makes set-up and tuning precise and trouble free.
    Thank you for oyur support.
    Thanks,
    Ralph
    Attached Files Attached Files
    Passion. Commitment. 29ers only.
    Follow all things Niner Bikes on Facebook!www.ninerbikes.com
    COMBO - President
    Ok RDO Owners,
    Got my RDO back from the shop with the shift upgrade kit installed. Everything working well during my 10 minute test ride. I can now understand where the issue was in the chain stay. The shift kit reremoved about 18 inches of cable housing.
    My FD is fast and smooth, not related to the shift kit, just better setup. The RD is now clicking cleanly into gear is much less effort at the shifter.
    The real test will come this Saturday, so I'll update then as well but so far so good.
    NMBP
    Reputation: gfs69's Avatar
    Good to hear! Now let's ride!
    Jun 2010
    How do you have setup the shiftercables in the badge btw?
    Do you have them crossed or not?
    Let me explain what i mean. If you sit on the bike does your rearshifter cable go in the hole in badge on the left or the richt.
    I am asking this because if you cross the cables they also cross internally in the frame. Does this effect shifting or not?
    I have installed them non-crossed.
Hot Deals
Contests
Latest Mountain Bike Articles
