Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 76 to 100 of 107
Thread: Jet9 RDO woe
  1. #76
    I built up my Jet 9 RDO using left over Jagwire shifter housing (which I think is 4.5 mm OD and I used 110 mm with the aluminum ferrule and Niner frame ferrule) and had plenty of ghost shifting problems as the suspension soaked up bumps. I ended up using 110 mm of 4mm OD campagnolo 11 speed shifter housing (as that's all I had available) with an aluminum ferrule at the BB and the Niner frame ferrule at the chain stay. Rode the bike today and had no problems at all.
    I think it comes down to the diameter of your shifter housing and how well it fits into the ferrules and remains seated during suspension travel (assuming the length is equal).
  2. #77
    My gloves stink
    Reputation: Appendage's Avatar
    Just run it on the outside
    Quote Originally Posted by PlanB View Post
    I'm currently running a continuous housing on the outside of my chainstay and it's the lightest-action shifting this bike has had yet. It was supposed to be a temporary solution but I might just leave it like that.
    I just bought a used RDO via the classifieds and had to assemble it. After reading all the tales of woe in this thread and staring intently at the RDO's nether regions, I decided to run full length housing OUTSIDE, along the top of the chainstay. Today I rode 22 miles in very rocky territory and everything worked perfectly. I tried to provoke it into ghost shifting but it was rock solid. If there's a drawback to this approach, I don't see it. Time will tell.
    Notes:
    1. The housing must able to slide fore and aft along the chainstay as the swingarm cycles through its travel. Do not anchor it firmly to the stay. Right now I'm using a single cable tie about midway on the stay, tight enough so the cable tie doesn't migrate but loose enough so the housing can slide under it. I plan to replace the cable tie with a wrap-around chainstay protector and run the cable inside it.
    2. This arrangement relieves the sharp bends in the housing. Shifter action is light and easy.
    3. Installation is easy. No wrestling with short, stiff segments of housing that have to be just the right length, special ferrules, etc.
    4. I'm running XT 2x10. Cables are not crossed at the head tube.
    Now I just have to figure out how to plug the holes in the chainstay. Suggestions?
    I dreamed I ate a 10 lb marshmallow. When I awoke, my pillow was gone.
  3. #78
    Reputation: kuykendallc's Avatar
    Can someone post a picture of what the shift kit is supposed to look like installed? When I install the 110mm piece of housing, there are way too many bends and the shifting is terrible in the 4 biggest cogs. Thanks.
  4. #79
    My gloves stink
    Save yourself the heartburn
    Quote Originally Posted by kuykendallc View Post
    Dude, it's a bad design that's not worth the trouble. Run full-length housing outside the chainstay (as described in the previous post) and shift happily ever after.
  5. #80
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    Here is how I do mine & have not had any problems.
    The cable length I use is 120mm
    Attached Thumbnails Attached Thumbnails Jet9 RDO woe-green-rdo-cable-010.jpg
    Raising money, my friend broke his neck Mtbing, Please Share link. http://givealittle.co.nz/cause/elliottkeys/donations
  6. #81
    Quote Originally Posted by Appendage View Post
    Looks terrible, will only do that as a last resort.
  7. #82
    Quote Originally Posted by muzzanic View Post
    Thanks muzz, looks like a cork screw, is that correct?
  8. #83
    Nov 2007
    I agree that the external housing on top of the chainstay looks lousy. Especially with the new derailleurs that don't require much in the way of chain slap protection on the frame. Unfortunately it's the only reliable set up I've found with this design.
    My plan for next year is to go back to the internal full length housing from the bb chuck to the r. der. The problem with that set up was that the housing tended to move around shortening the crucial bit between the chuck and chainstay and causing shifting issues for some. As well, the plastic frame inserts would pop out and allow the housing to start sawing into the carbon chainstay....
    To remedy this I'm going to run the housing through the chainstay using the original plastic sleeve inserts and then create "bumps" on the housing that would prevent it from sliding around. I'm thinking it wouldn't take much (maybe a few wraps of hockey stick tape on the housing?) The housing is anchored securely at the bb and derailleur end and these two points take all of the force from shifting. The "bumps" on the housing just prevent gradual migration from suspension movement.
    Can't see why it wouldn't work. The shift kit -- at least in my experience -- is prone to failure and I no longer want to risk using it. The external routing is ugly. Hopefully this will solve both issues.
  9. #84
    My gloves stink
    Seems like a good remedy but you're still going to have the added friction caused by the corkscrew between the chainstay and the chuck. I also would anticipate rapid wear of the housing liner in the corkscrew. What price beauty?
  10. #85
    I had the full length housing until a few weeks ago and switched to the shift kit. Have had shifting issues since. The mechanic that installed the full length did not use plastic sleeve inserts and the housing started wearing away the carbon (I also don't know if they were thrown away or not). I will try setting the shift kit up properly again. Hopefully it works.
  11. #86
    Carbon & Ti rule
    Yes kind of.
  12. #87
    Nov 2007
    True. I do think the external run on top of the chainstay lightens the shifting somewhat by taking out some of the kinks. It would be nice if the housing could somehow run on the underside of the chainstay. The lower linkage gets in the way though.
    If my " bump" on the housing strategy does end up being reliable I think I might drill out the headbadge/BB chuck and run one big piece of housing. This would make cable changes a simple task. As it is now I dread doing it. Especially during a stage race or something. Lose a cable endcap and a frayed cable turns into a major overhaul...
  13. #88
    My gloves stink
    I keep looking at that lower link and wondering if it would be possible to machine a slot for the housing to pass through. That would make it possible to route the cable on the bottom of the chainstay. Not willing to risk it, though.
  14. #89
    little mad riding hood
    Quote Originally Posted by kzodwallop View Post
    to all those having shifting troubles, we both setup our Jet 9 RDOs like this after kzodwallop discovered that the campy 11 speed shifter housing (4.0mm OD) worked.
    We have not had any shifting trouble since. We both had ghost shifting prior. I think the housing was not properly seating in the ferrules.
    I rode mine 20 miles over fast rough terrain on Friday and had zero problems with it.
    -- kzodwallop's wife
  15. #90
    My gloves stink
    Don't think of it as ugly
    Think of it as beautifully simple, easy and effective.
  16. #91
    Finally took the rdo out after doing the muzzanic method. Shifted terribly at first and then was perfect after everything seated.
  17. #92
    Reputation: goodoljake's Avatar
    I have a new XL with XTR 2x10 set up. followed routing instructions exactly and have a couple issues. 1) dropping down into the 11 tooth on the cassette is very difficult. 2) Also, seems i have chainline issues with the smaller two cogs in back and the small ring up front. the actual angle causes the chain to hit ramps on the larger ring up front. finally. planning to swap drivetrains with my hardtail to put sram on here and the shimano on the hardtail. please advise if anyone has had the same issues resolved with a drivetrain change. i know it sounds crazy, but i am a pretty decent wrench and have never had this issue with any other set ups and am simply stumped.
  18. #93
    Nov 2007
    Quote Originally Posted by goodoljake View Post
    Every 2x10 set up I've ever used (on a variety of bikes) has had issues with using the bottom couple of cogs while in the small ring. Chain rubs big ring, sometimes the big ring will try to pick up the chain etc. They aren't really "good" gear combos anyway.
    As for you having trouble dropping to the 11 cog... not sure... I'm thinking you've already checked the usual stuff like: hanger alignment, high limit screw etc. Must be a chain tension issue somewhere.
    Either way - I wouldn't scrap the XTR stuff just yet. It's definitely workable. I have two friends running XTR double set-ups on RDOs with no problems. It's winter here so their actual riding has been minimal but initial set up and shake-down rides went just fine. Have faith!
    Question: which PF30 adapter are you using?
  19. #94
    I just built up my new frame and am having some issues as well. Went with the jagwire L3 housing. First off this housing does seem larger as I cannot match it up into the niner ferrules. Second I went with just under 120 of housing length, probably closer to 115, as I could not get it to bend at the 120. I finally got it all set up and set the whole drivetrain up. It wasn't terrible, abut it definitely was not smooth. I took it for a quick ride and shifting was not great. Figured the new system needs to seat correctly. I have all 10 spd xt with xtr rear mech and a triple up front.
    Decided to take it out for a quick trail ride to see if I could get it to set right. Could not go into big ring out back without shifting and grinding problems. Kept out of that for awhile but keep trying to get into work occasionally. Pedaling very lightly uphill and snapped my brand new xt chain. Not sure where the torque came from but it definitely ripped it apart. Coasted home and here I am today.
    Put a kmc quick link in and am trying to figure out the shifting again. It seems very violent on the up shifts and just really jerky. Perhaps this is where my new chain snapped? Still in stand and scratching my head.
    Do you think that I just have a shifting setup issue outside of the cable routing? Will try and align der. Hanger and set up rear dérailleur again. Any thoughts on what is going on here? Have not had any ghost shifting issues yet, probably due to lack of use more than anything. Thanks for the help.
  20. #95
    Carbon & Ti rule
    It sounds more like a gear setup problem than a cable one.
    Quote Originally Posted by Wildebeast View Post
  21. #96
    Nov 2007
    The shifting should be smooth. It will require more force at the shift lever than some set ups and the ferrules may fail, but it should smoothly shift into whatever gear you select if you've set it up correctly. The routing sucks, there's no denying it, but it can be made to work acceptably. I also can't see it having anything to do with your chain snapping.
    I would start by checking the Jagwire housing. They do make a 4.5mm diameter housing (I think it looks "braided") that would cause seating issues with the ferrules and inconsistent shifting.
    Also, did your chain break at the connecting pin? Could be that it wasn't installed correctly (they can be tricky.)
    Lastly: order the new shift kit. You're running the set up with the proprietary ferrules and exposed cable in the chainstay right? The new solution looks like a winner.
  22. #97
    trail "cleaner"
    Reputation: AZmtncycler's Avatar
    I would recommend you go to this thread and swap over to full length housing and be done with it...
    Jet RDO cable routing -- shift kit failure...
    No dabs allowed!
  23. #98
    I know I don't have the braided lines and it is just the generic shift housing I bought 10' at the lbs. I do have the special ferrules and have tried to set up everything according to the niner tech video and all of the great tips on here about the 110-120 length. Will try and see if hanger is straight and everything else as it seems to be unrelated to the cables but rather with the shifting itself.
  24. #99
    Daniel the Dog
    The internal cable routing sucks and the kit is a PITA to install. Niner needs to dump the internal cable routing and go with external so us garage mechanics don't have to fight our bikes to get it to shift correctly. Niner needs to throw in the towel and run the cables externally!
  25. #100
    My gloves stink
    It doesn't matter if Niner throws in the towel. Just run it external.
