    Feb 2012
    Jet9 rdo steering tube protection
    What are y'all using to help with cable rub on the steering tube. Being matte black in starting to see slight scratching.
    May 2012
    Do your cables cross in front of the head tube? I've found that if they don't cross then it puts pressure on the housing which can force it against the steerer. If that doesn't work then their done 3m tape on the steerer where it's running
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Feb 2012
    I will have to check. My brake lines are swapped due to racing mx so long couldn't get use to the front brake on the left side
    I use this on my whole frame... headtube included.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Niner Jet 9 RDO XX1 Build
    2015 Niner Bikes Ambassador; Chattanooga, TN
  1. Pro Expander Di2 steering tube
    By cherok1212 in forum 29er Components
    Last Post: 05-07-2017, 08:24 AM
  2. Spam or PSA?...Jet9 RDO protection aftermath
    By cytoe in forum Niner Bikes
    Last Post: 07-08-2012, 09:46 PM
  3. Steering Tube Size?
    By coopdad in forum Shocks and Suspension
    Last Post: 09-08-2011, 06:01 PM
  4. pressing out steering tube
    By jwdevil in forum Shocks and Suspension
    Last Post: 06-01-2011, 06:22 AM
  5. Steering Tube Diameter
    By webbaldo in forum Marin
    Last Post: 03-16-2011, 07:04 PM
