Results 1 to 5 of 5
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Jet9 RDO BB Q-Factor?
    156 or 164? Looking at SRAM XX BB30 cranksets...
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Either. Depends on how much heal clearance you need. I run the 156 on my Jet9 RDO with size 45 shoes I have no issues but I pedal with my feet perfectly straight.
    Reputation: G-Choro's Avatar
    yup. Niner will tell you both work.
    Nov 2008
    Both will fit, just comes down to preference and/or if you get heel rub. I went with the 168q on my xx1 cranks, but I'm sure I'd be just as happy with the 156q. I wear a 46/47 shoe depending on the brand and found that I only rub the chain stay if I do it intentionally (I.e. when I was deciding between both q factors).
    I've run narrow q factors on other bikes and only notice a difference when pedaling through ruts...even then it's barely noticeable. I have approx 13mm of clearance between the crank and chainstay...plenty of room for a narrow crank. Hope this helps.
    Niner says either - I, too, put the 168 XX1 cranks on. I wear 46.5 shoes, but with all the pedal float never had an issue with hitting the chainstays. I opted for the wider setup because after doing a pro fit, it really smoothed out my pedal style and feels much more powerful.
  1. What Q-Factor For XX1 Cranks and Jet9 RDO?
    By azpoolguy in forum Niner Bikes
    Last Post: 12-19-2012, 10:07 AM
  2. Replies: 3
    Last Post: 09-03-2012, 10:17 AM
  3. Jet 9 Q Factor
    By bloodyknee in forum Niner Bikes
    Last Post: 03-24-2012, 10:47 AM
  4. Q factor
    By Cygnus in forum Singlespeed
    Last Post: 01-25-2012, 03:26 PM
  5. Q Factor
    By LUW in forum Cannondale
    Last Post: 06-03-2011, 03:46 AM
