    Jet9 alloy rear axle question
    I have a 2011 Jet9 alloy frame and am trying to figure out what rear hub to go with. The Niner Encyclopedia shows a 142 x 12 spacing. So my question is what is the difference between a 142mm QR and a 142mm thru axle? Thanks in advance. Ehren
    Purveyor of Fine 29erness
    Reputation: The Monkey's Avatar
    Dec 2005
    The newest air-formed Jet 9 features the 142x12mm rear axle spacing. Your older hydroformed frame has 135mm spacing, and will take a standard QR rear hub.
    The information can be found on the next page down of the Encyclopedia
    Hope this clears things up for you.
    Happy trails!
    Thanks Monkey. Next question: Avid 9 rear brake caliper requires an IS mount. The Sram manual says to consult your bike mfg since the #'s they show don't necessarily match the rotor size. The options are 140IS, 140, 160, & 180 (all post). With this J9 frame (2011), what mount do I need?
    Dec 2005
    You will need a IS to Post Mount adapter, that corresponds to the rotor size you will be using. Avid usually supplies these with the brakes. That frame will accept up to a 180mm rotor in the rear.
    Happy Trails!
  1. Jet9 alloy or Rip9 alloy
    By Lost Biker StL in forum Niner Bikes
    Last Post: 07-19-2013, 09:20 PM
  2. RIP9 or JET9....Alloy
    By Espo61 in forum 29er Bikes
    Last Post: 07-05-2013, 08:07 PM
  3. New to me Jet9 alloy
    By fordohio in forum Niner Bikes
    Last Post: 05-07-2013, 10:34 PM
  4. RIP 9 (alloy) rear axle options
    By silent713 in forum Niner Bikes
    Last Post: 05-05-2013, 11:54 AM
  5. Jet9 with 10mm rear axle - anyone using?
    By db9 in forum Niner Bikes
    Last Post: 08-03-2012, 02:53 PM
