Results 1 to 7 of 7
    spr
    spr is offline
    Jet rdo headtube angelset
    Hi All,
    I want to reduce the headtube angle to 70 instead of 71.5 in the front(cane creek angelset ,offset of 1.5).
    My propose is to increase confidence when going down by reduce the headtube angel and reduce BB hight for better stability.
    Did someone do this change?how the bike behave while climb a steep technical climb?for long XC/epic ride?
    Thx
    Reputation: brightsky's Avatar
    Dec 2008
    Not possible with the Jet 9 RDO. It has an integrated headset.
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    Actually, many early Jet 9 RDO's were built to use press-fit cups. We have one in the stable with a Works headset and a Fox 34 lowered to 120 mm to make it an aggressive trail slayer for the wifey. I've ridden it a couple times and it's a real weapon in this form. BTW, the Works headset is easier to setup, lower stack height and less maintenance than the Angleset.
    Here's a pic with the Works headset but before we swapped the Reba for a 34 -
    Dec 2008
    Sorry, I forgot that the v1.0 had a zero stack setup. The 1.1 and 1.2 version are integrated.
    spr
    spr is offline
    Thx
    How do i know which version is mine?and what angelset do i need?
    I have 9X135 on the rear
    Dec 2008
    Look down where the fork crown and the frame meet. If you see an aluminum bezel, you have a v1.0 frame. If there is just carbon between the crown and the frame, you have a v1.1 frame with an integrated headset.
    Here is a picture that should explain the difference visually.
    I think they stopped making v1.0 sometime in 2012, but there could have been stock for a while.
    spr
    spr is offline
    Thanks for the update
    I have the v1.0 with the internal headset.
    What kind of angelset from cane creek should i order (i want 1.5 dec offset)?there are 6 different options
    AngleSet
    Or maybe the works?there are 10 different options
    Full Headsets - Most Common Sizes
  1. Replies: 2
    Last Post: 08-20-2013, 11:19 PM
  2. Replies: 3
    Last Post: 08-17-2013, 02:37 PM
  3. Need assistance regarding headtube...
    By trev2401 in forum Cannondale
    Last Post: 02-02-2012, 08:20 AM
  4. Reign XO Headtube
    By moutnbiker in forum Giant
    Last Post: 09-30-2011, 11:50 AM
  5. Headtube twist
    By febikes in forum Frame Building
    Last Post: 06-22-2011, 08:26 PM
