Thread: jet 9 set up
    Nov 2008
    jet 9 set up
    How much air pressure should I run im my RP23? 2010 model. I weigh 180-185? How much sag? THANKS
    Quote Originally Posted by leonidas 119
    when i was in that weight range, I used about 135psi.
    Fat On A Bike
    You can use the Fox Racing Shox support site to get the right sag measures the RP23 needs to have. It would vary, so I would look carefully at the instructions.
    Ofir
    4 Niners
    Dec 2008
    I weigh around 170 and use 100 in my Jet. That uses almost all the range on most rides. Using that criteria, you would probably need around 120.
